Author Topic: 10-20 LED circuit for Wideband AFR meter  (Read 11232 times)
« on: March 30, 2009, 02:12:23 AM »
Just curious, would anyone want info to build a $10 circuit to view their wideband's AFR's? I stumbled across one trying to find a cheap LED bar graph, and I got this idea. The only problem is the old skool widebands w/o linear outputs won't get a linear representation, and have to adjust it a lot more to get right. FYI you can use multiple chips, and each chip used can drive 10 LED's. I'm sure if you could convert the tach signal to DC voltage, you could also do something like the lude/s2k bar graph tach.
http://www.national.com/mpf/LM/LM3914.html
Re: 10-20 LED circuit for Wideband AFR meter
« Reply #1 on: March 30, 2009, 08:31:52 AM »
Yes yes yes,  Hi, Si, Wi, Da, Ja, yeah ;D :yes:
« Reply #2 on: March 30, 2009, 10:09:48 AM »
My LC-1 has configurable outputs. I just set one of the outputs to 10-20 AFR 1-2V. Then bought a 5V DC display off ebay for like 8 shipped. Hook'd it up and got this:
« Reply #3 on: March 30, 2009, 11:44:40 PM »
Any links to your display? That looks liek a good cheap solution.
I'm guessing its very similar to this, as it appears you adjusted the decimal spot.
http://cgi.ebay.com/Universal-Digital-LED-Volt-Current-voltage-panel-meter_W0QQitemZ200324147749QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item200324147749&_trksid=p3286.c0.m14&_trkparms=72%3A1240%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
THe issues I see with that display are speed and size. Most only show 1-3 readings a second, while the chip I linked to would move the LED graph in real time. You are also limited to where you put it, while the LED bar could be put virtually anywhere. I was also thinking of using various red/yellow/green LED's for various ranges like the crap narrowband gauges.
« Reply #4 on: March 30, 2009, 11:46:44 PM »
« Reply #5 on: March 31, 2009, 12:10:52 AM »
That's the one I have, but I bought it from someone else. And mine was cheaper, like 10 or 12 shipped. Mine was setup to read 0-5V IIRC, but you can change that one up with the included resistors. Yeah I moved the decimal on mine for it to say 10-20 instead of 1-2. On mine, the reflash rate was too fast if anything. Probably 7 times a second, maybe 10. Definitely not too slow.
« Reply #6 on: March 31, 2009, 10:44:19 PM »
I found the display for 16 bucks shipped from a chingchong dealer. I can't tell if you can adjust the decimal placement.. what do you guys think?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=300302092773
« Reply #7 on: April 01, 2009, 01:17:08 AM »
Well it would simply display 1.00 to 2.00 AFR's if you can't adjust the decimal. It wouldn't be too hard to convert in your head. :P
I think I'll be getting one of those for my "tuning kit", since my O-Meter doesn't work half the time. If I'm lucky, I can get it repaired/replaced & sell it.
walter
« Reply #8 on: April 01, 2009, 10:00:48 AM »
does i t works only with LC1 WB?
« Reply #9 on: April 01, 2009, 10:02:52 AM »
No it work with other WB O2 including bosch 17014's :yes:
« Reply #10 on: April 02, 2009, 12:41:09 AM »
I think he meant wideband controllers, not the sensor itself.
That all depends on the controller's output. If you can program the wideband output where 1v= 10:1 afr and 2v= 20:1 afr, it would work perfect. Otherwise you'll be stuck doing lots of conversions in your head. Obviously the LC-1 has programable outputs, and DIY's like techedge & 14point7 units do too. Many others have an oddball fixed non-linear output. For those only the 10-LED chip would work, but would be off in certain spots.
« Reply #11 on: April 02, 2009, 01:28:18 PM »
i think i'm going to get a techedge unit.. shit's fucking ballin and cheap with the currency exchange the way it is right now.
« Reply #12 on: April 02, 2009, 03:55:10 PM »
Same here, the DIY Techedge version (2Y) w/o sensor works out to $100/ea shipped if I get one for both cars. Its an updated version of a unit they've sold for years, has 3 analog inputs, RPM, and 3 thermocouple inputs. Then just ~$15 for a display like above... :evil:
FYI WBO2.com charges ~$80+shipping for a sensor, while Amazon has them for ~$50.
« Reply #13 on: April 02, 2009, 03:56:42 PM »
I go to my local parts store and by them for 50usd part # 17014
« Reply #14 on: April 03, 2009, 10:43:14 PM »
FYI, old school riceboy lightshow narrowband air-fuel meters work great for this.  A JAW could be set up to light the particular LEDs you want it to at a given AFR.
