Author Topic: weirtech traction bar to the max, bitch  (Read 34199 times)
« on: March 07, 2009, 06:41:37 PM »
a threaded 16 in rod should be perfect for an ef
the 38in bar for the x-member had about an inch extra on each side. worked out well.
added brackets to use a stock cross member bolt hole and add a bracket for the torque mount
forgot to mention: weirtech ftw  :noel:
if you do this, and you add a front tq brace/mount try to get some thick ass 2inch OD tube/pipe.  mine skewed a tiny bit.  (or buy a sleeve and slide it in.  this technique can be seen in the porn section)
got some nice 10.9 grade hardware for the LCA's too.
thanks to atticus for the gangster after welds!
some better pics.
« Last Edit: March 29, 2009, 06:55:09 PM by danz »
weirtech
    • Weir Technologies Inc.
Re: weirtech traction bar to the max, bitch
« Reply #1 on: March 07, 2009, 06:47:15 PM »
i've been waiting to see one of these.  awesome!
Atticus
« Reply #2 on: March 07, 2009, 06:52:55 PM »
funny thing is we added a 1/2 by 1/2 inch angel iron on the out side of the pipe for reinforcement
and it still has a bend in it
not a kink but its a little bowed in the middle
« Reply #3 on: March 07, 2009, 06:53:29 PM »
ive been waiting for one of the reviews as well...
good shit
« Reply #4 on: March 07, 2009, 06:56:53 PM »
yeah... fuck... i should have flipped the front tranny mount upside down.  and if/when i do another one im going to stick a sleeve inside of the cross bar.  beef that slut up real good.
« Reply #5 on: March 07, 2009, 07:03:25 PM »
I have one too that I built from weir. THe only thing I dont like about it is that I have to use a 2" pipe and with the half core i Have to gangster lean the fuck out of it. Compared to like the jk traction bar is made out of square stock so it has alot more crearnce. I could lower the bar but then it will only sit off the ground about 3" and being out in front of the tires like it is i would hit on every speed bump in town.
« Reply #6 on: March 08, 2009, 01:03:54 AM »
Speaking of Wier, has anyone seen him here yet?
EDIT: Missed him like two threads down...
« Last Edit: May 08, 2009, 09:57:37 AM by dvst8r »
turbo4life
« Reply #7 on: March 08, 2009, 02:52:13 AM »
looks sexy!
End the fake food.
« Reply #8 on: March 08, 2009, 01:22:16 PM »
bookmarked this so I can reference this build mine as soon as I order the parts from WEIR.
« Reply #9 on: March 08, 2009, 04:23:20 PM »
that fucker is pimp! id rock it
« Reply #10 on: March 09, 2009, 06:48:59 PM »
How does the radius rod brackets fit against the pipe? is it tight enought to be tiged?
Also what diamiter tube did you use?
« Reply #11 on: March 09, 2009, 07:49:35 PM »
you mean from abuse installed in the car, or a little bow from the heat of welding the 1/2" angle on there?
I finally got a minute to drag my sled out of hiding and start dropping the engine in, this was 2nd on the list of 'too do's'
Atticus
« Reply #12 on: March 10, 2009, 12:39:08 AM »
no from being in the car
« Reply #13 on: March 10, 2009, 12:46:32 AM »
I'll be ordering one of these sometime soon.
Hey Wier could you do one one of your manifold emblems  R HMT  with the r clocked slightly and a little over the H?
« Reply #14 on: March 10, 2009, 02:10:41 AM »
I'd almost say cut a thick flat bar that fits inside the tube, then drill holes to spot-weld it. That would definately help stiffen it up. You could also use that method to notch & plate the area under the radiator to drop it down an inch.
I'm going to miss my EF - the creaks & groans, the spartan interior, the 80's styling, the lack of space to do shit with it. Good times.
« Reply #15 on: March 10, 2009, 08:01:05 PM »
it only tweaked a bit because of my shitty from tranny mount design. if i used a thicker wall tube it would be fine.  or ran a car without a front tranny mount...  nothing that would effect performance just make it a cunt to reinstall if i drop it.
civiceggturbo
« Reply #16 on: May 07, 2009, 11:33:04 PM »
can you post a picture of where you mounted the joint on the lca?
Ghetto_D
« Reply #17 on: May 08, 2009, 08:53:58 PM »
are you using 1/2in or 3/4in rod ends?
« Reply #18 on: May 09, 2009, 01:31:43 AM »
Nice  :noel:
« Reply #19 on: May 09, 2009, 03:30:48 AM »
its mounted on the front radius rod bolt hole with 10.9 grade hardware.
1/2in.
buk9tp
« Reply #20 on: May 09, 2009, 04:42:25 AM »
someone should make these and sell them.
« Reply #21 on: May 10, 2009, 02:32:14 AM »
Yes.
I like I could use the front mount with it.
Weir - mind selling one for a CRX with a b-swap and mounts for a half rad?
