Author Topic: 94 Accord/F23/250HP/14PSI Update: BLOWN  (Read 28747 times)
skaterdudz02
« on: July 21, 2010, 10:05:12 PM »
So far, I pretty much have everything I need to get this shit done. After building up that little pocket rocket hatch, I've decided more power and more displacement for the Accord.
This is my 3rd build on this one. First, auto, stock motor, 2nd, rebuilt stock motor w studs, and now onto my 3rd.
1st build never blew, 2nd, 20psi for 6 months daily busted ring, and now for the 3rd.
F23 motor
headstuds
new gaskets n such
clutch, flywheel
cheap turbo
3 inch downpipe
450cc injectors
10 psi
250 sound achievable?
Do I really need more pics?
« Last Edit: September 15, 2010, 09:38:35 PM by skaterdudz02 »
Re: 94 Accord/F23/250HP/10PSI
« Reply #1 on: July 21, 2010, 10:40:37 PM »
A RHMT build thread can NEVER have too much porn. Unless it's rawr's or complex's page, which will include gay porn. Since yours has NO PORN, you still need to post more pics...
BTW I think 250 won't be hard for this setup. Here's a mildly powerful stock-bottom F22 I've seen in person:
http://www.ht-archive.org/showpost.php?p=28671639&postcount=57
« Reply #2 on: July 21, 2010, 11:38:19 PM »
More pic's of the down pipe!
2slow
« Reply #3 on: July 22, 2010, 01:31:27 AM »
How much can an accord really take on stock bottom end?
da_dude
« Reply #4 on: July 22, 2010, 01:56:56 PM »
You should be good with your goal. But do I see the downpipe welded onto the turbine housing?
d16z6 turbo - 11.3 @ 124 mph
« Reply #5 on: July 22, 2010, 02:07:35 PM »
400 has been done for a spell...
Back in the days I made 305/307 for around a year and TRIED to blow the f22b1 up... Broke a ringland turning the boost to nog without tuning, but blew a coupler in the proccess to where it would only make 19psi... NOT enough to lean it out and make it ping hard enough to consume itself... LOL.
Heres the piston I did fuck up...
(Yes thats a hole in the bottom off the pic  LOL)
2slow
« Reply #6 on: July 22, 2010, 06:00:22 PM »
Good to know i wanna trade my turbo civic for an accord in good shape, and do a rhmt setup but i did not want to be limited to 10 pussy psi or lower like a stock civic.
skaterdudz02
« Reply #7 on: July 22, 2010, 06:38:07 PM »
Honestly, that's why I'm only just going to stud the head. These motors are just so beefy internally it's almost as if they were meant for boost from the factory.
Plus the f23 mains are bigger and today I pulled the pan off and definitely notice a stronger girdle than the f22.
Here are more dp pics as requested. And btw, I am no expert on welding, but I get the job done. Welds look better in person then anything. MIG ftl.
« Reply #8 on: July 22, 2010, 07:03:03 PM »
Fuckthat, shits tite
skaterdudz02
« Reply #9 on: July 22, 2010, 09:58:26 PM »
Not as tite as your shit spiker.
Anyone running 3 inches with a t3 setup?
How did you weld it up your adapter plates?
Use V band?
mycarslow
« Reply #10 on: July 22, 2010, 11:01:11 PM »
Should. Be sweet . Ever thought about a h22 head on there ?
5thgenlx
« Reply #11 on: July 23, 2010, 01:07:16 AM »
250hp will be easy with that setup. my f22 will push about that when its done at 12 pounds on a t3 super 60. i always get happy seeing people realize the awesome that is the f series engines boost potential. kudos
« Reply #12 on: July 23, 2010, 11:48:51 AM »
how well did the auto hold up to boost on your first setup?  I feel like giving mine a shot.
I'm also dropping an F23 into my car (same as yours, just a 97) when I get some additional scratch to spare.
skaterdudz02
« Reply #13 on: July 23, 2010, 07:04:57 PM »
I've been in the game on boosting f series blocks now for about 5 years.
I put 25k miles on the auto setup with a rinky dink turbo that spooled super quick. 7psi by 2k was intense. Tranny never blew. Daily drove the thing, had really no problems. In fact, it shifted 10x smoother when I was in boost then without.
Motor is almost complete, all I need now are some gaskets and it's good to go.
« Reply #14 on: July 23, 2010, 07:10:01 PM »
The wastegate recirc is going to affect flow out of th eturbo a bit, but the 3" will help. Too bad ya couldnt run it "over" the DP and dumped it further down at a better merge angle.
Looks good man
« Reply #15 on: July 23, 2010, 07:12:20 PM »
dp is welded to the turbo with no flange? Thats fucking gangster!!
skaterdudz02
« Reply #16 on: July 23, 2010, 07:13:26 PM »
Looks good man
I'm aware it'll affect it somewhat but I figured that would be the easiest way to get my A/C lines to clear without affecting. Plus, I'm going to welding in a bung for the WB. It's got an 8psi spring in it, so we'll see how it goes.
skaterdudz02
« Reply #17 on: July 23, 2010, 07:15:42 PM »
I know that shit is fucked up, but hey, it's not as bad as everyone thinks. It actually saves me a great deal of money. About 30 for the flange and gasket and the hassle of exhaust leaking.
Plus, if the turbo ever fucks up, disconnect the center section bolts and swap another one in.
« Reply #18 on: July 23, 2010, 07:29:05 PM »
Fuck that theres not 1 thing wrong with it.
« Reply #19 on: July 23, 2010, 08:32:30 PM »
Not on the nig nog setting, and since no other boost setting matters your argument is invalid.
« Reply #20 on: July 23, 2010, 09:30:44 PM »
At 10n 15 PSI???   Taht close to the turbine???  I heard the same thing regarding mitches car. I was right....Youre invalid. Nigger
« Reply #21 on: July 23, 2010, 09:40:42 PM »
On the nig nog setting the wastegate stays shut, so there is no disruption of flow.  Are you saying you are afraid of the noggle switch, fat man?
« Reply #22 on: July 23, 2010, 11:45:32 PM »
Awesome.  Since my setup will consist of a rinky dink turbo that spools super quick, that should be pretty fun if the tranny holds it.  Were you just running an FMU that whole time (I know I've seen pics of the FMU in the engine bay before)?  I'm still debating to fuck with an AFC hack for a bit or to just install the adjustible FMU I have and adjust some shit with the AFC.  OBD2 isn't very nice like that.
2.3L + SOHC + boost = win.
« Reply #23 on: July 24, 2010, 04:14:39 AM »
Youve seen how afraid of it I am son
« Reply #24 on: July 24, 2010, 09:26:18 AM »
Yeah, you were pretty concerned that your EBC solenoid was connected correctly.  Shadow, Russ, and I were looking at each other like, wtf?  Why doesn't the fat man say fuck it and just cut all the lines to the wastegate like a real man?
skaterdudz02
« Reply #25 on: July 24, 2010, 10:50:48 AM »
The tranny will hold, just do a small flush and get what you can out and put some lucas or some shit in there to help it. Just make sure when you start beating on it, that the tranny fluid is somewhat warm.
I used the FMU for over a year with check valves, then decided to try a chipped P28 on Neptune. That worked well for awhile, then the ecu blew for some reason, so then I ran stock ECU on about 3lbs with no problems for 6 months before I swapped. All times with stock injectors.
« Reply #26 on: July 24, 2010, 01:10:27 PM »
Fmu+ 3psi= super FAIL!
« Reply #27 on: July 24, 2010, 01:33:13 PM »
Shadow, Russ, and I were looking at each other like, wtf?  Why doesn't the fat man say fuck it and just cut all the lines to the wastegateS like a real man?
Thanks for the lol..
jarebear667
« Reply #28 on: July 24, 2010, 01:46:03 PM »
i have a spare head if anyone needs one f23 vtec buy it up for cheap!
shit looks gooooood
midwest HMT!
« Reply #29 on: July 25, 2010, 02:04:48 AM »
shit looks gooooood
If you'd said "I have a spare bottom end if anyone needs one" you'd have some more money in your pocket right now.
