Why hello sirs! My old build thread went down with xenofags sellout. I'll skip all the actual previous work and start at where I am now with a very vague introduction, since I plan on doing so much more I figured WHY NOT?!
Some of you probably remember the build, but it's so common very few will remember the details.
it started like this:
B16A 9:1 pistons
T3/T04E 57 trim
dog turd drag manifold
dsm 450's
etc.
ran like a champ until the turbo started smoking and blowing oil out of the dp.
picked up this from a member here for $260 shipped
decided to continue running the blown garrett because i'm not very environmentally friendly
picked up great mid-range from the new manifold.. it actually helped spool time too
then I came across this beautiful HX35 brand new.. for $170 shipped.
had some problems with fitment.. not only was the wastegate palcement an issue, but the compressor wasn't clearing the cross member
got this idea from Whitey and MADMAX
used 3" stainless steel.. more info about this in my thread in fabrication
everything fit first time.. had my local exhaust shop weld it up at no cost
turned the EVO intercooler into a backdoor entrance.. spent $30 total
did some tuning
and this is how she sits
Things that I will be updating on over the following weeks:
3" V-band down pipe (running 2.5" since it's all I had at the time)
3" Thermal exhaust (was waiting until I make the 3" downpipe)
reducing IAT since the sinktrap is close to my IC backdoor entrance
DIY water/meth injection system
traction bars made w/ weirs kit
upgrading to ectune ;D
ostrich rom emulator ON THE WAY
quick spool valve prototype. being machined
Dragger clutch from mike@LSD ON THE WAY
780cc injectorselectronic boost controlaluminum radiator
