Pages: [1] 2 3   Go Down
Author Topic: true antilag with crome free  (Read 27156 times)
speedjunky01
« on: July 20, 2009, 09:22:57 AM »
well seeing as how the two step only builds 1-2psi and just sounds gay off the line, so did some digging over in pgmfi.org
this will only work with a p30 base
hit control K and enter the fallowing script
_rom_fill(0x58e6, 0x590d, 0x00); _rom_fill(0x6a99, 0x6ac0, 0x00);
this allows ignition timing to go to negative numbers,
also make sure vtec speed check is NOT disabled
now the slightly confusing part,
set where you want antilag in the add extra features menu
go to your low cam ignition timing and above that RPM retard ignition until it reads -6 from 0" all the way to the maximum PSI the ecu is reading
now go to your low cam fuel tables and select the same area of the map as the low ignition tables, hit CTRL + J and adjust fuel by +10-15% (play with it until you hear pop pop pop :bigok:
all you have to do is make sure your launch control is set above your vtec activation point,
EXPLANATION
when you are standing still, the car will run off ONLY the low cam map since vtec speed check is working, so it will retard timing and add fuel off the line creating a true anti-lag. however once moving the ECU will allow vtec to be activated, so you will never hit that area of the map while moving because vtec will activate and switch over to the high cam
video and amount of boost built will be posted tomorrow
all credit to boosted k20 over on Redirection
if you  O0 already know sorry to repost but im sure it will help someone
Re: true antilag with crome free
« Reply #1 on: July 20, 2009, 09:56:17 AM »
I have been doing this for a couple years now, it does build some boost, but it is NOT true antilag. It will also work with a P72 base, I put both scripts you need (for either or) in the BIN directory that was posted up here at rhmt. Edit: link added http://www.realhomemadeturbo.com/forum/index.php?topic=3485.0
If you have heard true antilag you will know that this is not that.
One more thing 15% is pretty rich and it typically takes longer to spool at that level. I find 5%-10% depending on the motor turbo setup. You have to play with it some to get it to spool up quick and hit hard.
The most I have seen is 15-16psi but that was what the waste gate spring was set for, it may have made more with a stiffer spring, hard to say.
« Last Edit: July 20, 2009, 09:58:00 AM by dvst8r »
speedjunky01
« Reply #2 on: July 20, 2009, 10:23:42 AM »
i knew some  :mexi: in here already figured it out, but figured why not post it. good tip on the fuel amt too, ill play with it some to dial it in
here is a vid of it at 5600rpm, you were right takes its time to spool up
« Reply #3 on: July 21, 2009, 09:36:14 AM »
what vers of crome are you using?
speedjunky01
« Reply #4 on: July 21, 2009, 10:24:09 AM »
1.18
« Reply #5 on: July 21, 2009, 12:04:26 PM »
« Reply #6 on: July 21, 2009, 01:07:02 PM »
old school i was wondering were my check boxes were for the vtp and vts were
speedjunky01
« Reply #7 on: July 21, 2009, 01:11:56 PM »
1.18
No way.
why is that lol?
IDK have the newest version too, but it keeps craping out with windows 7. 1.18 is good old reliable for me
plus i can datalog with it
« Reply #8 on: July 21, 2009, 01:52:09 PM »
1.18
No way.
why is that lol?
No big deal that versions like four years old is all.
« Reply #9 on: July 21, 2009, 01:52:26 PM »
Damn good post.
and you can datalog with that old version of crome free?    interesting
speedjunky01
« Reply #10 on: July 21, 2009, 02:05:57 PM »
Damn good post.
when is I gonna be khoolz yet?
« Reply #11 on: July 21, 2009, 05:02:25 PM »
It's the old hacked version?
speedjunky01
« Reply #12 on: July 21, 2009, 05:45:38 PM »
who told you  :o
91' LS-VTEC
« Reply #13 on: July 21, 2009, 05:48:31 PM »
yep, that's what I'm thinking.
-d112crzy
speedjunky01
« Reply #14 on: July 21, 2009, 05:52:24 PM »
bastards!!
im about to be fucked by J-C
« Reply #15 on: July 21, 2009, 05:54:01 PM »
bastards!!
LOL yeah right you could email him telling on yourself everyday for the rest of your life and never hear back from him. Your safe dude.
« Reply #16 on: July 21, 2009, 07:22:39 PM »
who told you  :o
You admitted it yourself. NO ONE with a legal copy uses 1.1.8. Plus, the datalogging button is visible on your screen shot and it's the only version(that most people know about anyways) that is hacked. And you would have admitted to having purchased crome.
speedjunky01
« Reply #17 on: July 21, 2009, 07:47:38 PM »
who told you  :o
1.53 was hacked as well, but im not l337 enough to do that shit
« Reply #18 on: July 21, 2009, 09:21:30 PM »
Wasnt that before all the retarded ignition problems got worked out?  I popped a ringland at 10psi  :-[ on my LS with that shit...
speedjunky01
« Reply #19 on: July 21, 2009, 09:24:59 PM »
so far all is well on my 236k z6 at 11psi out of a t3/t4, if it pops then that will be karma ll
« Reply #20 on: July 21, 2009, 09:55:54 PM »
1.53 is hacked as well
i paid for Crome YEARS ago(im completely legit), but i have both hacked versions on my laptop for some stupid reason, lol
« Reply #21 on: July 21, 2009, 10:22:09 PM »
I know. I've had the hacked version as well. I also paid for mine.
« Reply #22 on: July 22, 2009, 12:58:11 AM »
bastards!!
Yet if you're sued by Hondata he sends the second or third largest contribution to your legal defense, then never responds to emails attempting to thank him.
Guys, don't help any n00bs with the cracked shit.  You guys have it because you've been around for years, contribute to the scene, and I believe that 90% of you have paid for your copies as you state you have.  n00bs need to pay their dues, and John deserves their money.  He may be frustratingly hard to get ahold of sometimes but he's a good guy.
speedjunky01
« Reply #23 on: July 22, 2009, 01:14:52 AM »
bastards!!
not putting john down in any way, very thankful for his hard work, I plan on buying crome for my built motor, the stocker can blow up on free shit that has glitches
« Reply #24 on: July 22, 2009, 01:19:22 AM »
The free version doesn't have any less glitches than the Pro version, just fyi. Pro just has more options.
If you're going to spend money on software, I'd put it towards eCtune.
speedjunky01
« Reply #25 on: July 22, 2009, 01:59:22 AM »
yeah ive heard great things about ECT tune both in stability and it just plain working smoothly and without hickups
buddy of mine is running it on his car i like it a lot from the little bits I saw
plus with a demon and it being wireless would be sick
« Reply #26 on: July 22, 2009, 07:25:16 AM »
Yeah I paid for mine. I wouldn't feel right using cracked pgmfi software.
And maybe it's because crome is all Ive ever use and I get around glitchs without thinking about it but crome really doesn't have glitchs anymore. most of them are called user error.
« Reply #27 on: July 22, 2009, 08:48:26 AM »
+1
BangBusMaster
« Reply #28 on: July 23, 2009, 12:52:38 AM »
Crome is solid in my book.
Its funny to think that the current v1.5 is light years ahead of the original Hdata 4b setups.  And those were marketed as super badass and complete. Pffffftt.
speedjunky01
« Reply #29 on: July 29, 2009, 12:38:13 PM »
got a vid up
for flames forward to 0:40
crome free antilag
builds almost 8psi with open DP
Pages: [1] 2 3   Go Up
