The victim for this build is a '92 Civic CX. I picked it up for free from my brother in law after he wrecked it twice in the nose. I drove this car back from Fairfax VA. to Casper Wyoming.
Some times running on 3 cylinders b/c of a hole in the sparkplug boot.
After driving my hatch for about 3yrs as is and at one point even achieving 44.5mpg or 667miles on one tank of gas in town. I wanted to compete in my local auto-x events with a little bit more power. So I got a d16z6 w/ trans. out of a '94 EX coupe w/ unknown mileage.
Installed it w/ an Egay 6-puck clutch and chrome moly lite flywheel (11lbs.) and a cheap SS headers to make my exhaust easier to hook up. I had a buddy who gave me his homemade 2.5" exhaust which I installed. I originally had no catylitic converter but after walking behind my car and about died from the fumes I installed one.
These pictures are of the SC14 I bought for $250. These s/c come out of '95 to '97 Toyota Previa. I got the idea to use one of these when I read about 1g MR2 use these to upgrade from their SC12 to SC14 on 1.6l 4age. And I own a '96 Previa AWD S/C. These pictures show where my original planned location until I realized I would have no room for my driver side cv-axle and the pulley was too close to the shock tower. Notice the a/c cluth pulley.
The next two pictures give you an idea the size of the SC14.
I realize the only way to get this in was to take out the a/c system.
I started cutting the radiator support to make more room.
But after looking at my wife's hatchback the iI found tons room if I use a scissor jack to push the bottom of the rad support away from the engine back to its OE location.
Wires and hoses going every where. 1g bov, intercooler, piping, and coupler from a buddy for $65 helped. Three of those couplers are not being used I had the pipes welded including using my old cold air intake.
Intercooler and s/c outlet manifold and air filter. These SC14s comes with oil dipsticks. I could mount it upright. Looking at the bypass tube and valve I had to duct tape them closed since I did not have way of controlling the bypass yet.
I wired the SC14 clutch pulley to the original a/c compressor clutch activation switch. And jumper-ed the pressure switch plug. Now the main power to my s/c was the a/c switch on my dash. I used the original a/c tensioner pulley assembly. For the idler pulley I just used a longer bolt through the bottom bracket holding s/c. Long enough to use spacers to space the pulley out to line up with belt and pulleys.
I ran a hose (spare rad. hose) from the bov to the air filter assembly
I originally used 450cc DSM inj., resistor box, and a V-AFC. I know that the v-afc is junk but I did not have any parts to use to chip my ecu.
I drove this setup for 4 month with very little problems. Until I lost rod #4.
Built another motor
Which I'll post here when I start taking more pictures.
Motor plan includes:
D16z6 block already filled with devcon
Block decked 0.020in and bored and honed to a p2w of 0.004 to 0.0045in.
D16z6 crank stock
Vitara ycp pistons 75.5mm o/s w/ new Honda 75.5mm Rings. (for the rings thanks Jargon pistons from a HMT member's name I lost from the whole website snafu)
Used TT rods w/ new ARP 2000 bolts. (also from a HMT member's name I lost from the whole website snafu)
New stock bearings.
New Water pump
D16y8 cylinderhead will be used with a lite port matching. (thanks to Teng Vang I forgot his hmt name but thanks mang.)
Stock ported D16z6 intake w/ 788cc injectors. (thanks to Super Dipper).
I'm using a slightly modified H23a tb which helps a lot when not under boost compared to stock tb.
I'm planning on designing a new intake mani w/ 4 tbs and a plenumn w/ a 3" inlet. It will have provisions for 2 rows of inj. and larger fuel rails.
I plan on having a turbo on top of this setup or twincharge system I like to call it.
I plan on either using one of these:
The green turbo is a used Mercedes diesil To4b unknown comp. w/ less than5k miles b/c the motor was replaced with a new turbo and the motor ran out of oil but did not damage the turbo.
The red turbo is a T0468 with a S-trim comp. New never used
The silver/natural turbo is a T0445 unknown comp. New never used
All three turbines are O-trim and have a split turbine housing.
I'm either going to use the red turbo with a blockoff plate on the inner port of the turbine housing or buy a T70 and sell these three turbos.
I'm also designing new inlet and outlet manifolds to the SC14 for both better flow and to give more room to clear the exhaust mani.
I'm either going to make a sink trap of the 4-2 part of my header and mount the turbo at the same height as a top mount mani. would w/ 3" downpipe and a wg on the sink trap pipe or get a top mount mani. made for me.
I am open to ideas but keep in mind I am on a tight budget.
