Author Topic: Seat Belts, I mean Limit Straps... How to  (Read 45865 times)
« on: March 18, 2009, 12:34:26 AM »
For those of you who would like to dig at the track, keeping a flat footprint is key.  If your front is lifting, your geometry is changing.  Here's how to stop it.
Get two center rear seat belts, some scissors and a lighter.  Shorten them like in the picture:
Get a hacksaw/whizzwheel and cut off the part in the red circle:
Take the non-buckel end you just cut and slip it over the rear stud on your shockhat:
Now bolt the buckel to the back of the lower fork:
If you're a dumb riceboy and somehow mount these so they fray, tear, wrap around your axel, and send you into the wall, I take no responsibility.  But if you bolt these on and get three tenths for $5, like I did, you're welcome...
« Last Edit: March 18, 2009, 12:46:25 AM by Foowee »
Re: Seat Belts, I mean Limit Straps... How to
« Reply #1 on: March 18, 2009, 12:56:22 AM »
fuckin pimp right there
« Reply #2 on: March 18, 2009, 01:00:19 AM »
Thats fucking hot
« Reply #3 on: March 18, 2009, 01:20:38 AM »
any questions from tech?
No, but if they would have asked.  I would have said, "they're dot legal."
« Reply #4 on: March 18, 2009, 01:24:31 AM »
Fuck I'm going to the junkyard this weekend i'll add these to the list.
« Reply #5 on: March 18, 2009, 01:29:40 AM »
oh thats good...
kinda reminds me from my stupid shit back in the day when i used to use metal pipes to replace my rear springs.  I would actually install the spring back so i can still pass tech,
« Reply #6 on: March 18, 2009, 02:15:31 AM »
Fuck you Fowee!!!!!
d-rail
« Reply #7 on: March 18, 2009, 02:25:38 AM »
I could see that working great. But if you had one of those 1 in a million things where it locked up an axle and shot you into a wall at 110+ it may hurt a little.......
« Reply #8 on: March 18, 2009, 09:53:29 AM »
At full extension set your camber to 0 degrees for maximum hook.
« Reply #9 on: March 18, 2009, 10:30:45 AM »
Sticky ?
« Reply #10 on: March 18, 2009, 10:31:50 AM »
you can buy brand new lap belts for $10 in most parts stores and they come with new mounting hardware and choise of color. ;D
Some of auto-x guys use chains on their camaros and mustangs. :somb:
« Last Edit: March 18, 2009, 03:43:19 PM by 92CXyD »
« Reply #11 on: March 18, 2009, 11:36:30 AM »
meaning, measure how much the front end lifts up at launch and then make sure camber is set to exactly 0 at that point?
« Reply #12 on: March 18, 2009, 12:41:43 PM »
Or put the straps on, jack the car up so it is hanging on the straps, set to 0
1slow91hf
« Reply #13 on: March 18, 2009, 03:17:37 PM »
almost as pimp as JDs rear system he designed  :noel:
« Reply #14 on: March 18, 2009, 03:22:23 PM »
Going this weekend to get some, I need to align the slut anyways..
« Reply #15 on: March 18, 2009, 03:44:28 PM »
what? :?:
explain please! ;D
« Reply #16 on: March 18, 2009, 06:51:26 PM »
so do you want to adjust these so there is a little lift allowed or do you want them tight when the car is resting on it's own weight?
Play with them.  My best pass had a bit of slack.  After that I added tension so it wouldn't lift at all.  I think the whole package is what you're after...  these are just a variable.  If you have a solid rear suspension I'd say you'd want some slack.  If you have some squat in the back you could probably run them with tension at ride height.
Before:
http://hyperperformance.smugmug.com/gallery/6224832_phn2y#393793292_4JX7r-A-LB
http://hyperperformance.smugmug.com/gallery/6224832_phn2y#392959547_db2R3-A-LB
After:
Here's my first and best pass with the straps:
sunbean tiger with a 347 V8
« Last Edit: March 05, 2010, 01:42:28 AM by Foowee »
« Reply #17 on: March 19, 2009, 05:16:50 AM »
need 50-60 psi in the rear tires.
« Reply #18 on: March 19, 2009, 05:17:54 AM »
Think about the bushing deflection under power, hanging is for bad nignogs.
« Reply #19 on: March 19, 2009, 10:41:28 AM »
i picked up an extra spare to run with mine for skinnies in the rear this year
excellent write up.  love the dot leagal
« Reply #20 on: March 19, 2009, 04:53:52 PM »
not very safe since spares are only rated for 55 mph.
155/80/13's @ 60 psi, just remember to air them down before driving home unless you want some scary drift action.
« Reply #21 on: March 19, 2009, 06:21:21 PM »
my track is 1/8th mile and i will change them when i get there
« Reply #22 on: March 19, 2009, 08:08:11 PM »
Seatbelts are also very useful for engine swaps. Great idea
« Reply #23 on: March 19, 2009, 11:11:01 PM »
nice work
CivicOCD
  • Let me dumb it down for you
« Reply #24 on: March 20, 2009, 12:52:34 AM »
that is fkin awesome.
I wish a dragstrip was closer to my house...sigh
going to get some anyways even though using it during aformentioned engine swaps will most likely where they see action
"quotquotFaster, faster, until the thrill of speed overcomes the fear of death."quotquot
-Hunter S. Thompson
« Reply #25 on: March 20, 2009, 12:55:10 AM »
We have three in the area.
I was see Fowee run at Thronhill, a redneck track :)
« Reply #26 on: March 28, 2009, 03:53:24 AM »
exactly what i was looking for.  excellent
« Reply #27 on: March 28, 2009, 10:12:24 PM »
nice, we used to use a similar limiter strap when drag racing snowmobiles
caged
« Reply #28 on: March 30, 2009, 12:44:55 AM »
Rhmt is collecting up great library of information. Nice work  :noel:
« Reply #29 on: March 30, 2009, 03:10:48 PM »
