General Category => Forced Induction => Topic started by: G2 Racer on March 14, 2009, 05:50:33 PM
Someone wants to trade me a Walbro 255lph pump kit for some parts I'm selling.
The part number come up for 92-01 Integras and 92-00 Civics. Can I use this pump in my car or no?
I've heard that the obd0 pumps won't work with obd1/2 vehicles and vice versa.
92-95 is ODB1 so.....
look up the part numbers with walbro
GS-341 and GS-342 i believe are different, but 98% identical.
Doesn't matter though, i used to run a GS-341 in my del sol (required GS-342), it worked great. The only differnce between them is the fuel hose is a little bit off, but not enough to affect anything.
what is the reason is pump just receive current from ECU and ground? ???
Its the whole tank plug thing that holds the pump/tubes/wires that won't swap. The older cars - I'll just say cable trans cars - usually have a more vertical pump orientation, so the newer filter bag can't be used (kit or stock baggie).
The only difference between the pumps is the location of the inlet & outlet. The outlet ends up being off by 1/2", but the rubber patch hose they use can deal with that offset. The plugs might be different tho, my EF kit came with a plug pigtail - I never got around to installing it.
