General Category => Forced Induction => Topic started by: gdout90accord on August 13, 2010, 01:32:34 AM
well my brand new turbo is smoking, will it be the oil drain? heres a pic
http://img.photobucket.com/albums/v417/GDOUT/6da74d45.jpg (http://img.photobucket.com/albums/v417/GDOUT/6da74d45.jpg)
i have a adjustable oil restrictor on the feed line which is 3/4 closed and it still smokes at high RPM. With the restrictor half way closed it smoke on idle. lmk what u think. thanks
Drain looks fine.
Whats your oil pressure at?
Are you using a fram oil filter?
Also what turbo are you running and how much psi, if its ebay and u r running over 15psi i wouldnt be surprised that it is smoking. Also im not a fan of the adjustable restrictors just my 2 cents. Also is your turbo sucking the air in front of that alternator or is it below it and the picture is deceptive?
Drain looks fine.
Im using the slutty Fram bitch, whats wrong with them?
turbo is a real garrett t3t4 60 trim and using s2000 oil filter. only running 10psi and turbo is below that alternator.
Drain looks fine.
They flow like complete shit and cause ultra high oil pressure.
http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html#warning (http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html#warning)
Drain looks fine.
Interesting read that confirmed what I always knew about Fram's crap. BTW sidenote the KNN filter is just Mobil 1 filter with a 1" nut on the end for easy removal and provisions for safety wire. ;D
How do you know it's the turbo? Probably rings...
Whats your pcv setup
What size feed line?
And we're going to need a better picture than that. The drain line itself may be ok, but the angle of the turbo might be off.
In other words are you using a catch can or just stock pcv system?
feed line is 3an with that adjustable restrictor and as for the pcv system, both pcv and vc port to catch can inlet and just a breather filter on the outlet of the catch can. the angle of the turbo is not straight down but kinda clocked a little bit.
Where is your intro post?
heres a smaller pic
The way you decribed the pcv system it sounds like you still have your pcv valve there. If so you need to get rid of that shit
Yea I still have da stock pcv valve connected to the catch can, I guess ill take it out and see if it helps.
DING DING DING!
Well theres your problem now punch yourself in the nuts six times
well ive had the same set up on the last turbo/manifold set up and never smoked like it is right now
Ok well then you need to do a few different things. First get rid of the adjustable oil restrictor, then fix pcv setup, after that punch yourself in the nuts, once done with that you need to post porn before anyone else will help you any more
