General Category => Forced Induction => Topic started by: JACER63 on June 02, 2012, 09:04:52 PM
finally got her here to start the twin build i have planned... will be updating along the way...
some of the specs..
383 stroker sb chev..
10.5 to 1
afr heads
team g mani,950 carb
turbo 400, manual shift 4200 stall (just found out...) 2/13/13
ford nine out back... 31 spline,4.88 fd,32x17.5 et streets
yada yada... will make a proper build sheet when i start the project..
she fits~~
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb008.jpg&hash=a46a813055062c7a2a4114ddee4a070d895330cb)
moved it to my little shop at the palace..
from dads much bigger shop...
ill get er done...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb007.jpg&hash=cd4b2bd09d686b7aa0d3b65558f938ac3619f82b)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb002.jpg&hash=8bd4fc77bb6665442bbdab09c284461f9fa90c0b)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb005.jpg&hash=b47b37101bd202177ae66f41680bcf2a52a4178a)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb003.jpg&hash=609f9aa3207dd07335d8938a0c42070c9a8a0146)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F07mmm-1.jpg&hash=19ed000a11c08e4dcb88ca580d50ffcde0aed262)
for now thats all... will be starting soon... :?:
love chevy 2's
Damn, full chassis car!
Big money right there.
What block?
What block?
Reread the first post, 383 sbc. :noel:
love chevy 2's
qft :noel:
whats the plan?
What block?
I restate my question. What block?
I know it's a 383. lol
generic ass answer like "its a B-series"
350 block
Small block 400 crank.
Will have to come by and check this out. Looks bad ass.
I want to see it do wheelies!
What block?
70's 350 bored and stroked as aj stated.. lil motor in my mind for a v.
have had the car for about 15 yrs since the inital setup...lol took ten years to just paint it.. went 12.20's , then 11.50's, and wih this last motor from DG, BEST OF 10.901 @ 126.. all with no transbrake, straight up flat foot ... 1.51 60's...
dustin, plans are for a twin setup, dont know what yet, just getting started.. need to raise the front a touch, she real low in the front.. room is real tight really with the frame and,front cage tie in's...depending on the budget,might go full efi, that would be the best way. stay tuned.. work will commence soon, doing a ton of research...
jace just get a ms3 wont break the bank and will do what you need but dont expect more than 600hp reliably out of a stock 350 block. idk if you have heard of them but http://www.competitionproducts.com/ (http://www.competitionproducts.com/) its damn near the sister company to the engine shop i work at and i suggest a little M out of all the aftermarket sbc blocks i deal with on a daily basis i am partial to them based simply on build quality. shoot me a pm as i can refer you to my boss to see if you can get some backdoor badass used parts for dirt cheap after we cycle them out.
That's why I asked what block it was.
Can ya get me a homie hookup on a cam, timing set, push rods, lifters, and roller rockers for a 302 (5.0l) for mu '82 Mustang?
Call me or PM, mang.
I like to be able to get this motor fixed for real cheap so I can sell the car and make some good cash. :noel:
the cam packages are like 89$ roller rockers are 150ish at comp products
iam pretty sure the bottom end will suffice for my goals.. is fully built with eagle/je goodies and such.. it is a 4 bolt main. das, i will look into ms3 and such.. might just setup the blowthru, with a msd btm for now etc... i figure it all out real soon.. work is fucking taking all my time right now..
FUck that.
Blow thru.
Fucking faggots
Going to need to have a shitload less converter in it too ;O)
Why twins?
Promod
twins are where its at nig nog!
This car needs twins less than even yours does.
This car needs singe 88 and a wet shot on it. O0
Car needs a 25.3 cage, 10.5w's and twin pro mod 88's. :P
spiker, with the layout twins will be much easier to do imo.. there really is not much room,because of the front tie in's..if you werent so far away from me or not , come by sometime.. (in south hill) would love some input/suggestions..havent ordered shit yet.. need to plan it out efficiently.
and also it will look wicked mean.. and sorry the stall is 5200 (typo)
dvstr8r... will prolly add some triangulations (spelling?) to the cage... right now its a 14 point.. might put it back to street form..
Unless you are planning on going 8.49 or quicker the cage as is will probably do fine (not enough pics of the cage to say for sure).
I was just adding ridiculousness on top of spikers post.
The other reason twins are a good idea (aside from packaging reasons) is they do lite earlier and spool quicker. The downside is obviously cost of two chargers, and the maintenance of two chargers.
Will you be staying with the current engine and just adding boost?
yeah the engine will basically stay the same.. might go efi though.. dont know yet.. motor is strong so i wont be going thru it until it shits the bed..will take some pics of the cage and what not soon.,..
heres some more pics...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb016.jpg&hash=408a4428e1d7c7ccc1b7c74d66e2f0a93649d45c)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb015.jpg&hash=f76a29cd3f2f05ca2619bc78b0884a6472895c1a)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb014.jpg&hash=05099e4aac2b86c589ca6f32e3e284e78678cc5a)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb012.jpg&hash=607f05ad18ad72b5122937ae67d0f343e2041431)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb011.jpg&hash=e3b5bf5fefab4169f175d4515dbb2b92018b5e48)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb010.jpg&hash=3da4b00e2aea41b08b697bfb2433ac9df2a09d16)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb009.jpg&hash=0d42007ed7d0e9765ff30957fc8d8cbef6655d4e)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb018.jpg&hash=ed34b14f6539e72cb1e64db9a5c735d31f7c5ad0)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb017.jpg&hash=969871db23bc7b716bce9c5f63349cd683e66ade)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb013.jpg&hash=0720993bbb22f3f7aa72822f5f287602195fb310)
Other then a window net, that should get an NHRA sticker for 8.50.
I would say either a single S480, or a pair of GT35R's or if you want to do budget a pair of HE351cw's.
I would say either a single S480/96mm 1.32 T6, or a pair of GT35R's/T4 .82 or if you want to do budget a pair of HE351cw's.
Hx52's we stay holet
Hx52's we stay holset
Yeah cause he351cw's aren't holset's... ::)
Niggers.
A pair of HX52's would need a whole different build, and a single hx52 wouldn't be enough.
Don't you love working on cars that are like spotless clean. You can spend all day under that thing and not even get your hands dirty.
One more thing, going turbo you are probably going to want to get out of the 5.13 rear gear set, and move up towards a 4.10 or even a 3.73. Turbo's need the load.
Niggers.
HX52s would just be more betterer ;)
Im thinking thats the avenue I'm going to go with my 00 SS....
+1
Niggers.
They would look cooler, that is about it.
They would take longer to come up on the line, make big heat in the transmission in the process, and then you would have to run them at like 10psi in order to not run faster then 8.50, and need to spend $10K on going to an sfi cage, and probably another $5k on the safety equipment that expires every couple years. It becomes very expensive very quick to run quicker then 8.50's. If that was the goal of the car there is still no way I would recommend hx-52's as they have very limited options. I would recommend a pair of BW S468's or S475's depending on how fast he really wanted to go.
My original suggestion of an S480 96mm turbine 1.32 T6, is only $850-900 brand new. Even old used HX-35's seem to go for $250ea+ these days.
YEs, Its nice. O0
yeah the car has a net..just removed for now..gonna add some bars here and there to add strength..and pc of mind
went with some cxracing t70 t/4 .70 a/r cold .96 hot iirc.. went cheap for intial setup then will update the turbos .. ordered some shaorty headers and gonna do topmounts..well see.. pics coming soon!
Sounds a little loose on the turbine housing, it may struggle to build boost at the line, but that will depend as much on tune, stall and cam as anything.
well i dont have a transbrake as of yet..still debating.. anyhow, this car has always left off the footbrake and throttle.. has had a 1.50 60' off idle basiclally.. those turbos will be for mock up and general troubleshooting, for leaks and such... there is a great article in this months car craft, they did som cam testing with twin t76's from cx racing.. good article.. basically trying to equal the top mounts they used, to clear the tie in's. and yes, i hope my stall is not to much, iirc its 5200 but i do have a backup, 4600 i think.. and also 4.88 and 4.56 gear sets..
looks very nice!
well recieved some of the parts so far.. at least i can start some mock ups..
cx racing t70's .96 ar hot/.70 ar cold 3in v-bands.. these are for mockup and first tune,check shit out deal..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb020.jpg&hash=8c30eb55f5380670510aeedce2f471d5cd3fdef9)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb019.jpg&hash=1a7480d2bcc5d183854c62f3c77826024d67ce35)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb021.jpg&hash=c8e88ff861e4cd3d3616c0454fbd4973ffbe0c56)
i went with these 44mm gates from godspeed for pricing, 109 shipped ea. and came with all the vbands and hardware..ill give it them a shot..if suck...in the trunk they go..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb022.jpg&hash=a93d95a5ae960d54a92f9f4471db6f8aab8c8297)
and im going to use these jeg's block huggers for mani's..cut off the 3 bolt flange, and modify as needed for my t4 flanges,for the topmount setup..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb023.jpg&hash=641b0f962f6c422412909116e94df695108a081c)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb024.jpg&hash=8ecc7cefe8f5ee384c9cf8c0bb5a33a43cb0fa1a)
these flanges..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb025.jpg&hash=fbce350faba95cc3a31f34219375fbe2b6a0c8dd)
and my dog roxy, 3yr old akc lab... lazyday man..fully asleep and snoring..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Fttttgg.jpg&hash=7d01793db3b847cdd728fb553660bc863a630383)
more to come in the next few weeks.. need to still order a ton of shit, but it will slowly be had..
fab pics of what i have will be in a week.. hoping
well started on some of the fab for the mani's... dri vers side...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FCopyofaemwb027.jpg&hash=7862c6af44091452b7dbe2aa01b61d3f769a7b4a)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FCopyofaemwb026.jpg&hash=a173923b4881914c45053334f5d87a364ec27aec)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb031.jpg&hash=c173f55af04f59994d52d5494b2ac99aaa9af358)
damn need to clean up the inside of the collector...lol
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb032.jpg&hash=00ed599f2ce77d41f6139d019c2904a9fc8068bc)
flangness...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb037.jpg&hash=ad55e89e860b58136e2932230a8125402cfb7c42)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb038.jpg&hash=46c071a438f0e5c20bf99ab699c9081030033a31)
getting somewhere... alll tacked, need to scoop up the tig from pop's shop and finish up..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb035.jpg&hash=9eda86b27c878aca86956164ba4a33ab2518b949)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb034.jpg&hash=d152bbe0027ace8f10108ee6a92593576af5fafa)
gonna start on the pass side soon... will post up more fab in a bit...
Sweet. What's internally done to the motor? Roller cam? Rods and what heads are on it? What intake is that and how even are your plugs specifically 2,8,3,5. If they are not very even the situation will only get worse under boost. I would also suggest.a 4 hole tapered spacer asthey are all the rage and for very good reason.
I just had to junk a block that was in a wissota latemodel at around 630hp because it cracked a no. 4 sleeve so be cautious. Dart shp blocks are an awesome cheap alternative as they have. 350+ sleeve thickness at stock bore.
motor is just a basic 383 eagle stroker kit.. afr 195 heads, and team g weiand mani... cam is just a hydraulic flat tappet.. .550 lift.. all plugs looked great, so no worries, i will be most likel;y changing the cam and valvetrain to either a hyd. roller, or solid roll. and changing the springs out to match..dont care if the shit blows, i have 2 more 3 fiddy's and 1 400 sbc in tow...
das, were you referring to the carb spacer , as the 4 hole ? because there is a 1"spacer but its open plenum style..
now remember i'm no pro at tigging, but these will work for a backyard shadetree kinda build... plus its fun to try and learn the skill... practice,practice...yada yada.. the welder is a lincoln squarewave 175 #6 cup...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb046.jpg&hash=ba61b67f7a87ead76621f6688921b91f725c1ee3)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb040.jpg&hash=da27aa8ce3c7b3575d21b127e507a65214dcb425)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb045.jpg&hash=878dd70cafc42983aafa3f73369417e955f63e5f)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb044.jpg&hash=068ec7c6ef6dde0d2fe361f36ef6c7f98c8b7203)
now i need to finish the flanges and wg tubing and such.. more to come....
How thick is those flanges?
Are the stud holes opened up a little to compensate tor thermal expansion? :noel:
russ , irrc they are 1/4" flange on the headers, 16 g tubimg ... and no i did not have to open up the holes bolts still fit nicely...it was tight though.. :noel:
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fstatic.summitracing.com%2Fglobal%2Fimages%2Fprod%2Flarge%2Fwsn-004150_w.jpg&hash=a2cf045dc24bb62dad3d0487118a9d7136a416c6)
Call Wilson they will set you up. We also make these in house so maybe i can get you one back door. among other things
let me know mang... looks stellar
das, are those 1" or 2" and whats the cost per say... :Jew: also are they billet, aluminum, ?
small update.. the driver side mani is done.. now on to the down pipe..and dump
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb054.jpg&hash=a4c1491edf7720ce70f080ce919a282558ed7aed)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb052.jpg&hash=c1c4ec11391b5185f1f38e6c2398a8c21b254b0a)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb051.jpg&hash=4f523d67543f57f06459a8f65257c2f96f9f815c)
also finishing up the flange for pass side...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb056.jpg&hash=db0e8f1a08c6463e49c5d8caad8045aa918e719a)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb047.jpg&hash=60aa71488d9a1a39d52cbfa0b65ee6883e805786)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb048.jpg&hash=9965cbd1443dedb256a01a7898fd129d6afd8b5a)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb049.jpg&hash=979167f5997de2741bb67d74983da738214ad45b)
the pass side was a bitch.. had to remove the collector,and shorten the runners, then replace a shorten collector.. reweld, and blah..
tons still to come....
dude that shits badass. What size turbines are those
What are you doing for your fuel? What's your setup?
cx racing sweetness, .96 a/r..
currently, its a holley "blue" good for 12 psi.. shit is outta here.. need to decide if this is going to stay carb, or efi.. the latter would be beneficial.
If your dumping the carb, let me know!
AJ will do.. its an A.E.D prepped 750 holley w/manual secondarys.. nice clean carb.
i will be upset if you ditch the carb :( oh and the spacers are 129 for a 1" 189 for a 2". lmk if you need help modifying the carb for blow thru
das, that might be an option if the pricing is right.. after all said and done, a f.a.s.t efi unit is appealing.lmk nog
some more small add on's , both gates are done ,except for final routing, and started the drivers down pipe.. 3 in"
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb073.jpg&hash=973c3b3c8b4b09eebb40edbc10378304521b2bfe)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb074.jpg&hash=8cb8fb1db3eac61427b1f6dfc0cd8e31d963f749)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb075.jpg&hash=c8fed48e5f1cda7d099928d2c3f844acfc8ab5d2)
this will be 90'ed and go back towards the firewall and run a lil longer.. havent decided yet..
pass. side..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb076.jpg&hash=89f957c313a0d0dc4898b712027db2b6865f8045)
some random pics..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb077.jpg&hash=e88eced4fa2cfd1bad91970eface3e9e1488d314)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb081.jpg&hash=f7560426d9fbfa7d79ae02987bde31b5bba44d15)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb048-1.jpg&hash=0951a90bc9257c0ad195c09926e812c1cdda2fc0)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb072.jpg&hash=a33e4cdc2f3944f34d0602a3778bee132bcfadfb)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F224666_10151118337299086_1151196489_n-1.jpg&hash=4239d7b93ec57fd1ea8f4d2226f16954072c5715)
oh and fuck off
will post soon enough on more work to be done.. interfooler is next.. and piping..
stay tuned gents, and stay thirsty my friends..
lil more...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb082.jpg&hash=67a9315170e9a42ef7679dbeeffa090313c4e22c)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb087.jpg&hash=b5d0e7467352c6e33b06294277b3292a93418975)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb085.jpg&hash=c170803f0984e2fc63753dba94c173588dec0364)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb086.jpg&hash=14aa5ee264f7c3a99e04e86abafe982762ae0a54)
ignore the slip fit.. just checkin clearance..blah
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb083.jpg&hash=8a0303b9b5d19de8ecb9c7c711b44a0205b06440)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb084.jpg&hash=760856163651070d364920da497e70828accdde6)
more after labor day sucka's...need some fam time..
FUcking sicker than AIDS
I read that same write up about turbo cam shootout. Looks good man..
so sick. i hate that they fit so easily for you. mine were a cunt to make work
didnt fit at first.. had to basically build mani's out of the JEGS block hugger headers..lol 2 tanks of comp argon later..
DO WORK!
did a lil more work... painted wheels... fixed the sterring, and brake pedal.. small update...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb103.jpg&hash=b4c045f960d0b481f05258d51b2ae4c3456a7a6d)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb101.jpg&hash=cba4a247ce6ce5b97c4ee7003a14fcf8c6b0812f)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb098.jpg&hash=2a7bb64419e441bb1035df34af25ac2b0e6c0c3f)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb094.jpg&hash=bcbd611db235506d93996931ddd853e8e29e9609)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb102.jpg&hash=b986b160b8dd77a900e561f268cdc102dd1a62c2)
and this how you get thos fuckers off the rear.. lol what a pain
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb100.jpg&hash=9ef3fc99e8433824a60bb85aaaf19fd2b2448e1c)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb099.jpg&hash=76dffd8150e3c9c6009e95ebbb238760945aac13)
for now thats all... did get the rest of the piping to finish pass side dp and dumps.. update soon..
Looks sharp.
Add areospace disc brakes to the budget for the rear though... :P
small update.. intercooler is in final mock up, had to lower and move radi. forward to fit..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb111.jpg&hash=5808f576b7c106fc3686e036d0a444cf4a095a64)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb110.jpg&hash=aaf5a4af3679660e4fbb7d924f82d8f4eb9154f9)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb109.jpg&hash=92974f6f0c6acf1685f6a4f73a56996f6ebe8efd)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb112.jpg&hash=c1aaff8cb922f548ea700530ef4dfff60faf9594)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb107.jpg&hash=5c77d21e371f42e97c2c4a8d9a9a135524b9b874)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb106.jpg&hash=a3191530a83ebf1a3e105499a4382ac5a7ce8bc2)
wideband also came in..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb116.jpg&hash=be5b446df5679216a62c38a37161f9710282a59d)
now its on the fuel setup... and other small odds and ends..
update coming soon....
just more pics to add...
exhaust and dumps are done also..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb119.jpg&hash=38cb9f8d4e0c951889aff13f145e511691266240)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb118.jpg&hash=c8394f561dbdb571dab0899a1ec64eecc413c5f7)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb124.jpg&hash=6e2e5f5d2079513a4fe6e1dfb8f98c557da63875)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb121.jpg&hash=35a5a64c48f619194a30fafa9ba3658f3b1bafef)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb122.jpg&hash=cdccb475e6ecb0a85761a30dbbf27bbb5c90c6b7)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb126.jpg&hash=e9985df91e05ac5a92fc36cb403fa7a80601c1d1)
more to come...been super busy on this project.. 6 days a week , after work till 7,8 ish and most any free time..(lol)in my lil shop..i cant wait for the final assemb.
Badass!
Looks like a lot of money I do not have. :noel:
Luv to see the ripper vids when this is done. O0
Fuck your civic. This bitch better be at the nw dyno day 2013....
This one better not have boost by gear. We like to keep headgaskets.
AJ thats the goal, and the civic will be too..
small update...starting the charge pipes.. now, the coupler in the middle will be a weld.. this is for mock up..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb132.jpg&hash=ba802e4231ff19105968a19884e2dd4367645173)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb127.jpg&hash=e0d5ca77bd21f45c1515befe54193954694b46a1)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb133.jpg&hash=54099868daed6204284f36c0cd9482f199a1fda4)
will update when completed..
finished the charge pipes .. all welded up...aluminum is a bitch to weld.. lots of practice on scrap pieces before i attempted the final welds.. iam no pro at tig welding, but iam happy with th results. they should hold fine..lol
driver side..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb139.jpg&hash=fcefe41e1ec7f3306497d7584072c00d83fa0f5a)
pass side..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb138.jpg&hash=f5340d66e53dd9f7a5f08844785fb75d64f7cee3)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb136.jpg&hash=3418e2192b5067beb66f5045f4670676998e8459)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb137.jpg&hash=9df765d3679172efb7e5d90fd4a8c6e69dfcbb27)
front view.. overall iam happy the way the pipes turned out.. only 4 90's for couplers..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb142.jpg&hash=0b52e07dbe753bf95a0224d76afe466fd15550d5)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Faemwb146.jpg&hash=763ebaf7541e5b6507eb4d3598b8a9d4ef1c9b1b)
thats about it for now.. next ill be plumbing all the oil feeds, returns, and much of the vacuum lines for gates,blowoff..etc
good day!
This is all kinds of badass!
i want more updates to fap to..
I am a little afraid of the 02 sensor readings at the big end of the track when you are doing 160mph with the dumps acting as scoops.
Other then that badass, looking for updates as well. O0
Update?????????
i was excited there for a second thinking there where updates... :'(
working on a few things guys.. pics will be soon.
Fap fap fap
Beautiful. :'(
Get your fast system ordered up yet?
yep just today.. #3102310-10 iirc...fast xfi.. good to 1000hp
That turbo setup will make over 1000hp not even trying. :noel:
well then if it does. new pump and injectors then..
Or just turn the boost down, as 1000rwhp = quicker then 8.50's.
WAT?
WAT?
25.5 cage is pricey and so is the other safety equipment that goes along with it.
To the OP don't forget to fab up the chute mount now too, as I am sure this will go 150mph+ on the first hit.
ok so i ordered up the fast xfi efi master kit... damn its like christmas...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture007_zpsb9e4988f.jpg&hash=40119434c644f9f7d821ba69bc9f06d497598a2b)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture001-1_zps233b7b97.jpg&hash=13830a90e97a3f23848e351f1d023aad5d61fcc4)
started some of the removal of old mani...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture012_zpsb6df8db7.jpg&hash=7362ac21d9c5aa95dbd2fd99a0386df7a7d65f90)
cnc'ed intake runner..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture011_zpsbfff8d01.jpg&hash=e54019f9794dae368e492fb3c6ef68a99cee12f4)
new mani and shit mocked up for throttle cable..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture014_zps8ba5f0be.jpg&hash=343d52211b0309d3335408b53516eef9da4d9c59)
just went ahead and installed all the sensors, rails and injectors..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture019_zps462d2111.jpg&hash=d6f109bc19284c0f55aee21ef68b4ef57ec84f66)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture020_zps4d705d09.jpg&hash=c74ddfb521a038e0bc2a6cdbcbc50ecd93fd89bf)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture022_zpsa40ce95f.jpg&hash=e1ee6c2672b08eeb59e547e4a020096d792099fb)
thats all i got done today.. next step is do the fuel system... wiring etc..
heres the pump...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture005_zps2fd8ac02.jpg&hash=561aeba4d40fef84d9b108ae590d570f4e282faa)
so far iam very impressed with the kit.. shit they give you all the an fittings for -6,-8, and -10 an for your fuel setup.. shit..
more to come in the next few weeks...
Nice. O0
so this kit came with 60 lb injectors with are around 630 cc .. plenty for 900-1000whp?.. just curious , should i get 80 lb'ers?... fuel pump is good for 1300hp..
I was wondering how you afforded all that shit till I saw the Busch Light. Lol
let me know when your done with the stuff u pulled off ;)
No, they will only do 600-650whp.
Lookin good bro gotta swing over and see this thing
well shit i guess ineed to look into bigger injectors.. #95 lbers
anytime fucker... been waiting for you to come by...
why not some hiprofile injectors?
171702's routinely go for $680 shipped, actually. One is being strapped to a friend's LQ4 currently.
Because that faggot will only send four. >:(
More like 750, with no margin of safety. Well, that's with my SBF hat on. Mr. Ed made 538whp at 95% duty off a set of 42's aka 440cc.
Then make a second order. Simple enough
Good luck with that. Jeff "I GAVE YOU FOUR INJECTOR - NO MORE INJECTOR FOR YOU!" Danek aka the Injector Nazi doesn't play those games.
JD he must like me more, sending me 8 injectors soon :noel:
171702 is a 75mm compressor vs the 80mm 177287 that I quoted above.
Survey says you're right. S475 != S480, I was wrong.
With that being said,either turbo would make more then 1000hp and take him well beyond the 8.50 his cage is good for.
ok guys need some input here... this would be the best way i can come up with for the fuel rail set up.. now this is all mocked up with some of the old an lines off the old setup. the rears of the rails would be linked with a -8 an loop. then as the pic shows.. come around and out to the reg. now the blue an fitten you see on bottom od=f the reg goes back to the tee on pass side feed. then the by pass -6 silver an out the btm of the reg back to fuel cell.. this work or what? pics...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture025-1_zps2180a0b3.jpg&hash=c5bbc861a5dcafc07adc83926d2f0f86633e2407)
give me some feedback guys.. space is tight on the rear of mnotor to firewall..and also the -8 feed is on pass side.. would like to run rteturn on drv side..
one more thing who here has experience with the xfi tuning software, irrc its C-com wp XFI 2.0... (paging Dr. JD) . need some tips soon....
Most of the big power cars run 1/8th due to looser rules and less abuse on the drivetrain. 6 point in a car that runs some 4.70's... happens all the time.
This seems to be more of an Eastern trend, out West even promod stuff typically runs 1/4, I am honestly not certain if there is any 1/8th stuff in that Seattle area.
So if I have this clear, the fuel pump feed is coming up the passenger side of the car (opposite that of the regulator), into the open "T" into the picture, feed all of the injectors (through a rear loop not pictured) and back to the regulator and then the return will run down the drivers side? Correct?
If that is the way you are doing it then you can either remove that open T on the passenger side, and run it as you have it, but block off one of the side ports on the regulator.
Or you can do it the same as above but run a line from the T on the passenger side, into one of the side ports of the regulator.
Or the ideal way is you move that T back behind the engine, have each rail fed from that T behind the engine, and then the front of the rail each gets fed into it's own port in the regulator, and then the return as is.
and yes your correct on this setup as i explained.. well i would run it like you say but the motor is real tight to the firewall... and yes the open tee would run under water pump and connect to the open side of reg. i may still try to mock up the way you said just to see if i can fit it, if not just delete the tee and block that side of reg port..this will still work ? in my understanding its just a super long honda fuel setup, with the reg on the end..
Basically, the reason that guys like to Y or T it before the rail, is it "supposedly" gets better distribution, then done as a long Honda style setup. However I am not sure I buy it, as if there is pressure then there is volume. However velocity may be significantly different one end to the other, but not sure how that effects making power.
U need a mallory fpr like i have run-8 to it then two 3/8 or-6 out to each rail has a -8 bypass return
The fpr he has will work just fine.
PLENTY of people make well over 1000 with the "loop". Its fine. Fuck that T fitting.
Did you actually read what I wrote there?
I just gave the theory of why others don't do the long loop, no where did I say it wouldn't work. Like I already said if there is pressure, by definition there has to be volume.
Now if you have something to actually add, like datalogs of fuel distribution vs fuel velocity I'm sure we will all be the greater for it... Nig O0
And for some reason you think id wastr my breath talking to you you ra tard ? Lol fuck you. I was talking to jace you less than american nigger lol ♡
I have the long loop on my car and it works just fine. The bests setup I would think would be the suply Yed to both rails and then the 2 rails feeding the fpr. Thats all I got so fuck u
LOL, I'm a pretend American nigger this weekend up at Mt. Baker. :mexi:
If no one can provide you logs of pressure drop across the rails for your fuel line ID and diameter, then you need to use a T. The ID is like a plenum, and if the injectors can drink it dry before more fuel comes in, pressure drops.
well got some more work done today.. actually it took several days to complete.. started out with the front of the fuel system.. after all yours guys input i decided to run the loop.. saves on fittings and hoses to boot. hers the front fuel ....
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture038-2_zpsa8b992a3.jpg&hash=c7b3e8205ad864b330d10cc73d8cdedf06ca4935)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture039-2_zpscc9efb69.jpg&hash=ad2cc83af71dfcd5dca3dc4d387a4daac7db149a)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture040-3_zps87f80334.jpg&hash=a1c5d603a4ea5722017f8e8200d2cd8962c0728d)
then i tackled the pump mount ... needed to build a half bracket..fuck (50-60 times) back and forth under car to check shit..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture027-1_zps194ac44b.jpg&hash=b55652a92db8097d59e9e9336f538c416261e8c0)
and then install...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture028-1_zps59374362.jpg&hash=194af53120f287d7713a0cc8c339bd83a422a55f)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture029-1_zps5d76f9b9.jpg&hash=e8e4807f79c8b32da6c821839cc7859cdd8b5efd)
and wired the relay and such...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture030_zps09bc25a8.jpg&hash=179bde817cbefab7bde2d1a4b0ae1e677bf439ae)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture032_zpsdf00d6d3.jpg&hash=af6bba2dcf9a1c4ca99785db79b12d02e4d13c58)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture033-1_zpsecde0ef2.jpg&hash=5382a795fd18c857f75d27cda51063612d5059de)
then checked fitment of full harness... fuel injector main mocked up
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture034-1_zpsff06b5e9.jpg&hash=cf495345f09764255048a3a95f33ad91f4d517b9).
full harness....
more to come next week...
quality sexy work. :noel:
Jesus fucking christ that chassis is sexy as fuck.
You better bring this to the dyno day or I'll kick you square in your teeth!
iam trying to get her done.. still need a tophat and 21" 4 in aluminum charge pipe, 3in to 4 in reducer coupler, 4 in to 4in coupler,.. catch can(s) and some miscellanious shit.. and run a -6 return back to tank.. all 5 gallons of it.. lol
this will be fired up in the next three weeks.. hopefully
Will the darkest man in the pacific northwest be tuning it?
i would love him to. but the budgets tight..and have not informed of his much needed help.. the software looks easy to use.. but atmost iam a semi novice tuner..
where's the crx light..
got some small arts i needed today..
boost gauge.. 2 5/8
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture042-1_zps1f40c6eb.jpg&hash=172d84e0a69d9ae717ce444e2f733756f6eaea51)
and the fittings to complete the rear fuel system..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture045-2_zps8faf0bae.jpg&hash=9281251b1f95b969f35ebb185c8c3b6aba6f049e)
and a shot of the trunk and fuel cell.. last pic has the 30 amp breaker for the pump..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture044-2_zpsfb5f9ead.jpg&hash=ec39da8eee8aee1a6d6b4e8757a1a147a4ebe718)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture043-1_zpse0735a4a.jpg&hash=f9da49fdf0e1d5d9622672e584eadd8dbbb019cc)
more to come soon...
Last checked in from Budhapest IIRC LOL
I have used those Jegs brand AN fittings and had bad luck with them. Especially the ones that swivel. I have found that it is worth it to spend double for Earls, Russell or whatever. Just my $.02.
what was the bad luck? did they leak or something? looks and feels like the other earls fitting i have ...
My summit ones are junk.
Fuck Earls. I like XRP... My Summit ones are used for PCV and oil... High pressure sahit gets XRP... Theyre bigger internally too (flow)... But I drill all mine ouat anyway (Straights)
my whole car is summit fittings and working great
so are mine
This is what 800cc injectors say to 630cc injectors:
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimageshack.us%2Fa%2Fimg163%2F4203%2Fev1401.jpg&hash=b2d39758fa782c81c96dacb19f98e537443e0f1d)
Looks great so far!
hiprofile.. may need a set of inh=jectors soon..
well started the main harness work.. last sun night. 4 straight days of work is coming together..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture059_zps4f8db92e.jpg&hash=8ea7a21dc41b4cd0d17a8515d5c24feb612d999a)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture060_zpsa0cda08a.jpg&hash=063c9ddfa5d9055f141ed039d6b64e5902d9e101)
ecu mount..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture062_zps14335ce5.jpg&hash=b10e4e68225dfcc4513982f7a94065cd20a6c2ee)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture063_zpse7741403.jpg&hash=b938b110132a20f6d8c37124f15d53a79287523b)
welded and painted ..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture064_zps3d220433.jpg&hash=3c6507529ae538344bc4dc08773f715ce03572e9)
mounted up and tight
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture068_zps30407e14.jpg&hash=66f1bfdcacc0abaf93ca43b35c61c91ddc005e15)
well fuck it works for a good relay mount too...
then started running the harness...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture073_zpsfb903921.jpg&hash=00900f99fe2114c56d78c7b50427c1c953f3d926)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture074_zpsf8d71c3d.jpg&hash=7836d593c7b3446ff3b83e969d141264586861e4)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture077_zps04108412.jpg&hash=a32ddf98bf8d7e35ce8d8110ddf4901ce4564013)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture080-1_zpsd218fb5e.jpg&hash=664254537890eb6e21a87fd28dbb748f788309f4)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture069_zps56582bab.jpg&hash=fcc1a21c5db8a64d2931f744e1db296ee31115dd)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture084-1_zps0a065c4c.jpg&hash=260aea21ef29e7b963c47007b92a7cb1a6d5b5ab)
some tools .. shit everywhere
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture090-1_zps4fa574ed.jpg&hash=befce4cc4149f33d3189be68378ca0d8635c3dbe)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture091-1_zps87766ead.jpg&hash=3cfee1bf0f40c7f664dd0698b7e4cd9df5715465)
mounted the MAP.. gm style 5 bar
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture082_zpsc847229f.jpg&hash=2e96e4fae0e0db15109b96b9bc7e18fab3065580).
and finally some progress.. w/b gauge and boost gauge install..next
have more pics of other shit but for now....
well there be more to button up before the weekend comes.. wont have time till mon. to do more work on it.. then very soon this will be readt to fire..
ok fucking photobucket was being a whore. here ssome more pics
wb and dash mockup for shits
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture087_zpsb9875ef5.jpg&hash=23ac15a830dbe551123fb74a1149cde5e3aa45a6)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture086_zpsb1812581.jpg&hash=7e34ebb1b3658fc3347532db37d8b26291956e98)
well more to come..
Bump.
DO WORK!
No update in a month, bump.
Talked to him the other day. Said he has it running, but has to do a cam swap. Only pulling 6" vac at idle is making a bitch to even idle he said.
Sounds like its time to go alpha-n
He's doing the cam swap now. I have seen the pics on facebook just waiting to see them here.
sorry guys been lazy posting pics and shit... quick update.. yes did cam swap and thats done then starter decided to shit bed and eat up flexplate. parts ordered and should recieve today.. reinstall and finally should be able to run it off the jacks this sun. then i will update with all new pics and shit... the car sounds fantastic and iam pumped..
alpha-n does not su[pport boost..need speed density, hence the cam swap... removed ionner valve springs and broke in the cam.. then reinstalled inner's and ran it once when the starter shit... it did pull 14in at idle 1000 rpm..should work.. went from 108 lsa to 113 lsa.. lil less intake dur and lift .507 284d and .525 306 d exh. idles way smoother... more to come
so previously stated needed a cam swap ... went with the comp cams .507 284 in/.525 306 113 lsa. needed to remove inner valve springs for break in steps.. use air to seat valves..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture017_zps1301afc1.jpg&hash=cdf396adcdfd50cb135e054bddbc7f950b4d8d04) (http://s211.photobucket.com/user/jacer63/media/Picture017_zps1301afc1.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture016_zps0c1ff485.jpg&hash=b95671b3c4976c25d921b52691e30a42c4c72b82) (http://s211.photobucket.com/user/jacer63/media/Picture016_zps0c1ff485.jpg.html)
worked like fucking a slutty stripper in vegas...
all in order and proper holes..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture014_zps8c713508.jpg&hash=a95f9a3ed094a779e95c30b99aefc21d8b408315) (http://s211.photobucket.com/user/jacer63/media/Picture014_zps8c713508.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture013_zpsddf28a96.jpg&hash=07fffca7aa1f9e889c1c5264e4a17654d4c85682) (http://s211.photobucket.com/user/jacer63/media/Picture013_zpsddf28a96.jpg.html)
then i just repeat process for reinstalling springs...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture009_zps5110a43f.jpg&hash=090d805ceb0ad299683727d911050edfecf23c82) (http://s211.photobucket.com/user/jacer63/media/Picture009_zps5110a43f.jpg.html)
broke the bitch in 2500 rpm for 29 mins with occassional burps to splash oil; on cam yada yada
then starter took a shit .. and ate flywheel up.. as stated.. starter cracked the shoulder leaving it to move a tad and ate the fuck out of the flexplate.. and it would not disengage.. trouble
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture024_zps447805ec.jpg&hash=b7b61e0564352b2124846a99e9f14726052e8611) (http://s211.photobucket.com/user/jacer63/media/Picture024_zps447805ec.jpg.html)
flexplate damage... it was old and been through 3 starters..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture025-1_zpse4ccde80.jpg&hash=61534e0ca3f5235c3c83734be613ef687f33df73) (http://s211.photobucket.com/user/jacer63/media/Picture025-1_zpse4ccde80.jpg.html)
and new starter..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture028-1_zps805515d7.jpg&hash=56c987e3c0349adcfaa8aed50aa7e9c65e5ff4c8) (http://s211.photobucket.com/user/jacer63/media/Picture028-1_zps805515d7.jpg.html)
so now iam waiting here on a rainy friday waiting for my flexplate to arrive.. since the first one they sent wrong..gotta love summit shit is 2 days out on orders..
some random shit pics ...
this how to remove flexplatre with tranny still in car.. move the tranny back 2in and viola...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture020_zpsac61fcbd.jpg&hash=ddd4f86a86f95a9abefa5a5354a7164d1bd2eaaf) (http://s211.photobucket.com/user/jacer63/media/Picture020_zpsac61fcbd.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture021_zps00f3bcc6.jpg&hash=20c41c26051e2751c0110df79c79314d701f7540) (http://s211.photobucket.com/user/jacer63/media/Picture021_zps00f3bcc6.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture022_zps44ef4048.jpg&hash=ac30d8dd4508e63036ac3efe5ec2a1aae89c544d) (http://s211.photobucket.com/user/jacer63/media/Picture022_zps44ef4048.jpg.html)
now here's the final engine setup..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2FPicture023-1_zpscee95ca5.jpg&hash=7263a45ddaa4ff6c38cbfcb03c193c1d87a24271) (http://s211.photobucket.com/user/jacer63/media/Picture023-1_zpscee95ca5.jpg.html)
now i will try and putt this bitch around the block this sun. sat is shot i have a family deal..errr
need to dial it in and hope shits good before i trailer it 90 miles to lynnhood.. may need help on the tune?...
If I'm not at the track Sunday I want a ride
Do you have carpet on your garage floor?
yep how we roll... nah jk its a throw rug my wife had.. its nice to lay on when working on your back...
Did it make it around the block?
x2
x2
X3
not yet... just finished up the resoldering the battery lead to starter.. didnt work on it yesterday.. duidnt feel well.
x2
X3
X4
well turns out the map sensor was a lil fuckered.. ordered a new 2 bar fast.. waiting on it... then iill report..
This Nova's being a little bitch. If its not one thing its another at the end.
well got it run pretty damn good so far with the working 2 bar... finally took her around the block last night.. seems to run good.. now just need to clean up the map and hope for the best...lol burnout vids soon to come!!!!
and yes ryan, this lil whore has been acting up at the wrong times!.. ill wrestle her down though
Bump
Well? >:(
Should have called the Grand Wizard, happy to have given some advice... I just did a speed density Procharged 454 that pulled 5" at idle, had an electric vacuum pump for the brake booster. Drives and idles great at all temps.
5" at idle surprises me that you didn't go tps. Was it not an option or am I too inexperienced? I haven't dealt with a cam that big yet
As someone else stated, you can't do that to a boosted car.
I get the feeling there might be a parts combo conflict here that wasn't exactly the cam. Trying to idle too low an rpm (which can be bad for a big mechanical lash cam, i so equipped), or the wrong converter loading the motor and causing issues when dropped into gear.
People hate to gear it, but converters are fucking critical to getting a RWD car out of the hole. A serious build usually requires 3-6 converter changes, working with a good converter guy, before you find what the car wants. You ready to bleed some money and pull some trannies, bro?
Why couldn't you switch to map at 0psi kinda like an itb car? Again, curious and wanting to learn since I have yet to com across this.
Updates?
Updates?
It's still orange.
I need a link to this intercooler bitch.
Still Failed!!
well guys sorry for the lack of updates.. been super busy at work and other things... to bring you fella s up to speed..
aug 9th went to pacific raceways for a tnt session.. had a hell of a time passing tech .. master switch was being a wierdo.. finally passed and first run of the night pushed the hgs out.. lol
the car pulled hard until the hg shit.. ran a 10.188 @ 100.21 .. 6.19 116 @ the 1/8th.. soon as i hit 3rd gear the rad hose popped off and lifted..
so ordered .060 cometics and arp 12 pt studs... more to come...
you get some tuning in? or you just rockin base?
Fucking eh! Ripper vids?
have a solid base tune in it for now.. feels good on the street as of yet.. need some fine tuning done..
the motor had old felpro hg that were 4.160 bore, the motor has 4.030 bores..and was running arp bolts not studs..
ill have it all fixed in a few days..then well see what the numbers will be on sept. 7th
on a side note did get the projacks/high jacks all setup for the pits.. shit is slick
So, what your saying is..........................it runs and you haven't given us us a video yet
all i can do for now.. checking the tire pressures and shock setup..lol
http://youtu.be/f1LaJ7B6RMQ (http://youtu.be/f1LaJ7B6RMQ)
Too good.
Your neighbors dont care?
Good shit! What was that, like 4k? I want to hear some rev limiter love!!!
the car would just get away from me at the limiter... simple burnout heats the et streets just fine..rocks a be rattling off the tires..lol
Too good.
hells no.. i let all know beforehand.. you can see em' watching.. everyone is cool here...plus i do what i want around here.. shit ill fire the car up @ midnight
heres the night at pacific raceways.. by the way my wife sucks at filming.. the green 67 stang ran a 11.38 @ 123 .. my sis in law got a better perspective of the run.. waiting to upload..then ill post
she says its smoking.. lol pushed the hg out..
http://youtu.be/_lLHIbLUyBk (http://youtu.be/_lLHIbLUyBk)
she seems to think the camera captures what her eyes see and not what she points it at. that was horrible. lol
correct.. but she's hot and has big boobies.
so go fly a kite..
ok ... i tried to fix the res. but oh well... i had two chicks recording this shit.. here is another shitty vid.. does give ya an idea though
http://youtu.be/f6ZLCjZs_LM (http://youtu.be/f6ZLCjZs_LM)
fuck off
oh well...
http://youtu.be/RE0jpUvFMgo (http://youtu.be/RE0jpUvFMgo)
ok done with vids...
oh fuck off
so go fly a kite..
I never said dump her cause she doesn't know how to use a camera.
Pics of said large mammaries.
This made me laugh.
small update... studded and ready for 4.030 .060 cometics mls
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130831_150356_zpsda01a971.jpg&hash=a7921362f66fd7cf204cd85c363f27340b5f9c4b) (http://s211.photobucket.com/user/jacer63/media/20130831_150356_zpsda01a971.jpg.html)
heres the heads tautly torqued to 80 lbs..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130906_153213_zps9742370d.jpg&hash=b82e564e6385edf1457f6067639dae18d2144271) (http://s211.photobucket.com/user/jacer63/media/20130906_153213_zps9742370d.jpg.html)
then ran into some problems..
the old style rockers now hit the studs when lashed.. because the pushrods are now .021 shorteer..
so ordered up the correct pushrods and rockers.. comp magnum's 1.5 on intake 1.6 exh. pics of parts soon..
some random pics.. the high lift jacks..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130831_150704_zps103152a7.jpg&hash=d722db630a4ed069ae14156ca8decd985ccfdccb) (http://s211.photobucket.com/user/jacer63/media/20130831_150704_zps103152a7.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130831_150650_zpse35d7aca.jpg&hash=54294c2d1b414c91ec8414ea674d943662d0080b) (http://s211.photobucket.com/user/jacer63/media/20130831_150650_zpse35d7aca.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130831_155611_zps0ed9c39b.jpg&hash=3e1ccf81807080957e1ccd0ea44873a7991a4d9a) (http://s211.photobucket.com/user/jacer63/media/20130831_155611_zps0ed9c39b.jpg.html)
these are fucking so slick to use... 30 sec
oh and the wifes mammies.. lol
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130510_190521_zpsfee74df4.jpg&hash=7262ae083a08b7d0b9899328525a51015cee6f50) (http://s211.photobucket.com/user/jacer63/media/20130510_190521_zpsfee74df4.jpg.html)
more to come...
forgot the old gaskets that shit the bed.
.039 fel pro's 4.166 bore.. wrong shit.. and only had arp head bolts..
rest of the motor,walls,pistons heads are all fine.. no damage
lasted a few hits on the street.. and a pass at the track..hg hit the pushrods and was folded against them..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130910_152012_zps3f9ec66e.jpg&hash=e9feef647c23df1115dd429c4653b50c623ea3c7) (http://s211.photobucket.com/user/jacer63/media/20130910_152012_zps3f9ec66e.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130910_152036_zps0749ba9f.jpg&hash=c17439d6b0b5aac0c93713106c92113abfc0ab57) (http://s211.photobucket.com/user/jacer63/media/20130910_152036_zps0749ba9f.jpg.html)
Damn, it ate those HG's up!
yep @ 15 psi
more to come...
MOAR!
Maybe a non Facebook camera angle?
Looking forward too seeing this thing get a solid drag run
first request... fuck off
second soon enough.. 9.20 at bremerton..
Let me know when your going out there because I will be there.
Those slicks are huge!
not slicks.. dot legal et streets..
some parts showed today..
the rockers..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130911_131527_zpsd9a729cb.jpg&hash=4a245880e98e627cfe63ad21f45422f690ff0372) (http://s211.photobucket.com/user/jacer63/media/20130911_131527_zpsd9a729cb.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130911_131544_zpse21386ed.jpg&hash=eb2e6d8245beae7d18e29b73c2d030e09bb1fa73) (http://s211.photobucket.com/user/jacer63/media/20130911_131544_zpse21386ed.jpg.html)
pump back from some repair work, had some debris get by the pre-filter and boom.. 210 bucks later. my fault..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130910_163103_zps2488436c.jpg&hash=d59d166f975f197d58343e12ff03311c04796bec) (http://s211.photobucket.com/user/jacer63/media/20130910_163103_zps2488436c.jpg.html)
waiting on the pushrods to complete the work.. mon they will arrive, then hopefully bremerton on the 21st for tnt..
updates and photos will commence..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2Ffacebook_-1848506528_zps3ee21e00.jpg&hash=e3f66b819d397e0ba928bcfc4c9fe28c6c583a5c) (http://s211.photobucket.com/user/jacer63/media/facebook_-1848506528_zps3ee21e00.jpg.html)
fuck
Marriage material right there
well i guess ill add the fab of the 7.5 in cowl to the steel hood...
mock up
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130729_185234_zps952a1b1e.jpg&hash=c461973988424c28e49bf2dc36e7abb2f101c210) (http://s211.photobucket.com/user/jacer63/media/20130729_185234_zps952a1b1e.jpg.html)
and more...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130731_170607_zpsc5a8d38e.jpg&hash=91e212ed5361aed81e1032f68104938e5a0791c1) (http://s211.photobucket.com/user/jacer63/media/20130731_170607_zpsc5a8d38e.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130731_170614_zpsa0871af7.jpg&hash=af4129ed933f5fee18aa4f377d569b4a4e284ffb) (http://s211.photobucket.com/user/jacer63/media/20130731_170614_zpsa0871af7.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130731_170624_zps2cc75f0f.jpg&hash=63a3b5b210873b5332e64b30dcb10de0585e33b1) (http://s211.photobucket.com/user/jacer63/media/20130731_170624_zps2cc75f0f.jpg.html)
time to cut and start molding the glass... shit was smooth to work with..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130802_152119_zps0603b6fd.jpg&hash=eaaf4bcce64799fd824b4be0dfdfbfa5eb5d8793) (http://s211.photobucket.com/user/jacer63/media/20130802_152119_zps0603b6fd.jpg.html)
all i did was a good tight fit, then rivet the cowl through the hood and used straight resin sandwiched between the two flange and hood under the hood for the first step.then i applied some mesh the next day to it..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130802_152128_zps7e3f23dc.jpg&hash=f34c3d98072fe9f810bacdd68ecd14b336fb72aa) (http://s211.photobucket.com/user/jacer63/media/20130802_152128_zps7e3f23dc.jpg.html)
theni let it set up for a day or so.. then some touch up and blending,sanding and glaze bondo..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130803_215839_zpsf589a27c.jpg&hash=cfac1442ad9e0d39c5afc1f087b409342417fb0d) (http://s211.photobucket.com/user/jacer63/media/20130803_215839_zpsf589a27c.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130803_215832_zpsf8cba82d.jpg&hash=d5f9afcb03a8b5e2b595b487e6986b3af90954d0) (http://s211.photobucket.com/user/jacer63/media/20130803_215832_zpsf8cba82d.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130803_213944_zps4b573723.jpg&hash=bfe163ff84d85f9a259ccbc411c332ac9ee4fbcf) (http://s211.photobucket.com/user/jacer63/media/20130803_213944_zps4b573723.jpg.html)
and all primed and ready to wet sand and paint...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130912_171654_zps340a3b37.jpg&hash=63a60217fd8aef6dc8b21cdff8fe979025294bf1) (http://s211.photobucket.com/user/jacer63/media/20130912_171654_zps340a3b37.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130912_171702_zps4c2b955f.jpg&hash=b48cd6b843ddae4336e1be2413f943a5be213f92) (http://s211.photobucket.com/user/jacer63/media/20130912_171702_zps4c2b955f.jpg.html)
well more to come when parts arrive on mon. finish the motor and break the bitch in ....
Looks good.
If you would have knocked that high spot on the ridge in the front down and blended it would be perfect IMO.
Expecting 8's out of this eventually. Living the dream. Sick car, supportive fam, kickass neighboors. Count your blessings every single day. Good shit.
This thing is a couple solid shake down passes away from being out of cage. :noel:
Looks good.
that was the factory line so i had to work with it..in person it looks ok...
This
This
thats this winter's project.. adding tubing and door x'es and gussets to be 8.50 cert..
pushrods came in so i started to put it all together...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130916_152922_zpsc73c49bc.jpg&hash=efcf3f3864de31ba1bfdfbe92ebefa2a12f32e35) (http://s211.photobucket.com/user/jacer63/media/20130916_152922_zpsc73c49bc.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130916_152927_zpsb5eeac49.jpg&hash=fe674566d53c731d08ec61bd15c84741bac45a05) (http://s211.photobucket.com/user/jacer63/media/20130916_152927_zpsb5eeac49.jpg.html)
the new roller rockers.. 1.6 in 1.52 exh comp ultra magnums
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130916_155302_zps9c0fb9ff.jpg&hash=7e5c96dafaf12e79aabf1a6ed7db03e150d91d8f) (http://s211.photobucket.com/user/jacer63/media/20130916_155302_zps9c0fb9ff.jpg.html)
all installed and looking good.. the roller tip is centered all the way through the lift. all good..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130916_164958_zps89f34280.jpg&hash=be186b51f1605edabb6de2702b3ddd77ea07694e) (http://s211.photobucket.com/user/jacer63/media/20130916_164958_zps89f34280.jpg.html)
intake installed and all sealed up, dizzy stabbed and phased...
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130917_132702_zpsbb0d4d30.jpg&hash=925d7b04383f89a3ce195bff215f0c4a9373963f) (http://s211.photobucket.com/user/jacer63/media/20130917_132702_zpsbb0d4d30.jpg.html)
back to work i goooo
should have the motor all ready to fire by weds. then off to bremerton..
Make sure the tune is dead on!
This
The way this thing is looking, I would be looking at a 25.5 cert for 7.50's.
well decided to pick up some stud girdles for peace of mind..cheap and easy..
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130924_135205_zps52faccde.jpg&hash=ce01cf0d1a78c080f4f09117b7e53c32b3fca2b7) (http://s211.photobucket.com/user/jacer63/media/20130924_135205_zps52faccde.jpg.html)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi211.photobucket.com%2Falbums%2Fbb221%2Fjacer63%2F20130924_135159_zps5bf3f2bc.jpg&hash=02e8284a6dd08047f3337bc6860072d271f621c1) (http://s211.photobucket.com/user/jacer63/media/20130924_135159_zps5bf3f2bc.jpg.html)
car fired right up and ran tits.. then went to work and when i came home to laod it on the trailer, the cunt would not fire..?
checked all the usual shit and found no spark. damn pickup/module on the dual sync dizzy shit the bed.. fuck
ordered a new one as the tech guy says its the culprit.part should be here today/tom.
man iam running outta weather to shake this thing down before winter ...
Please tell me you do not run with those filters at the track.
Take a look at those and then think to yourself, would these Briggs and Stratton mower air cleaners feed 1000hp?
NOVA!
this gonna make it to the meet?!?!?
Better get your mind right! Fuck camping! You can go camping the next weekend. Don't give me the bs story that you can't make it to the dyno day. You better have that mother fucker at the dyno day or leave your key for it with me and I'll make sure I get you a printout if your numbers.
Well iam going to see if I can reschedule my trip... I sure hope I can make it.. aready booked this trip months ago.. I'm trying here..well see
NOVA
this is our day... your wife/family gets you the other 364days... its not a bad deal... ;)
Jace will bitch and moan about it untill the night b4 the dyno day. And then show on the dyno day without his nova and some excuse that his truck is already loaded with camping/trip gear so he cant pull the nova on his trailer because his tow vehicle is packed.
Hahahahaha!!!
Yes Dustin...but this is our anniversay weekend so bad timing
Yes Dustin...but this is our anniversay weekend so bad timing ON MY PART
Fixed it for you.
Lol
Bump because you never made it to the rhmt dyno day. So what's the deal. You ever get it tuned?
It runs and smells pretty fuckin nice
Need titty ripper vids now!!!!!
Fixing rear end right now.
Failed project or what?
Naw about 5k in damage when the rear let go be back together for next season
