General Category => Engine Management => Topic started by: arsenio on February 01, 2010, 01:20:59 PM
Title: tuning for older toyotas
Post by: arsenio on February 01, 2010, 01:20:59 PM
what is on the market for 80's toytas?
any chip action?
Title: Re: tuning for older toyotas
Post by: Joseph Davis on February 01, 2010, 01:27:45 PM
Generally, no.  Most (all?) are not external ROM, aka chippable, ECUs and they are certainly unsupported.
I've seen some GM ECM converted turbo 22R trucks, and Honda stuff finds its way onto the 3S a lot.
Post by: arsenio on February 01, 2010, 01:31:07 PM
what about some 5mge shit. brah! do it!
Post by: Joseph Davis on February 01, 2010, 02:38:09 PM
You like weird engines.
Post by: arsenio on February 01, 2010, 02:40:29 PM
no. the cars i like just happen to have them.
maybe i should just do a rotissary swap in a toyoya.
Post by: Joseph Davis on February 01, 2010, 06:24:26 PM
Weir did a rotory swap into a 1G MR2, you should be able to find it in fab.
Post by: bigdaddyvtec on February 01, 2010, 06:26:10 PM
My roomate has a chance to pick up a SR5 4x4 turbo toyota that with it comwes another turbo 4runner with another good motor but is tboned... 2500  yes or no???
Post by: Ntrain2k on February 01, 2010, 07:53:45 PM
Try to jew him down, but yes.
That can be a bit of fun as long as you don't noggle it.
Post by: PhilStubbs on February 01, 2010, 08:50:41 PM
i was going to post this very same thing soon. my dad has a 91 camry that he wants me to boost. looks like i may be finding a way to stick a p06 in there with a honda scribitor
Post by: Joseph Davis on February 02, 2010, 01:01:33 AM
They make power fine, but there's an inherent static balance problem with the motor.  If you operate it 3-4K+ for any amount of time the bearings go away.
Post by: kgx on February 02, 2010, 02:00:17 PM
The 5sfe requires a fair bit of work to run a p06.
1st, the injectors need to be rewired from batch fire to sequential, the distributor needs a spacer to fit the 5s head, rather than being cut down. The TPS on the manual tranny cars is nothing more than a switch. You'll need to replace it with one from an automatic car.
As far as the distributor goes, it would be easier to run the stock toyota distributor. It has the 24 tooth and 4 tooth signal, just inverted. A simple opamp inverter gets that out of the way, and all that's left is a single notch cam sensor. A notched washer on the cam gear read by a hall sensor would do it. Feed the hall signal directly into IC10 on the p06 to bypass the vr conditioner board.
I've got an NA mr2 harness I've been procrastinating on building for a guy in hawaii. Harness is done, but I need to get a distributor to fit.
Post by: PhilStubbs on February 02, 2010, 07:59:42 PM
hmmm...... sounds kinda easy. the car is an auto already so there is one problem down.
i wonder if there are any problems with trying to get the auto tranny working properly when using a p06?
Post by: kgx on February 04, 2010, 04:06:10 PM
http://www.apexology.com/files/Electrical.pdf (http://www.apexology.com/files/Electrical.pdf)
^^wiring diagrams for the 91 MR2's 5SFE. 91 camry should be similar/identical. i think there's a seperate control module for the tranny, but i don't remember offhand. usually, the engine ECU is only repsonsible for the engine in toyotas. other ancillary stuff usually has its own ECU (ie cruise control, ABS, cooling fans, intercooler pumps, EHPS, etc), however i know the V6 ECUs also control the tranny.
Post by: PhilStubbs on February 04, 2010, 08:03:33 PM
guess i could have been more generous with the info. its a 91 4cylinder auto. he doesnt care much for going fast since he is older than JD, but oddly has more hair. he just wants to do it for fun. its also cheaper to get into the massive old car show here in daytona if you drive in. the car isnt old enough to get in, but with enough custom work, they will allow it.
Post by: DmC on February 04, 2010, 08:17:41 PM
Eww Arron Cake just spun on a dildo when he read that.
Post by: nock on February 05, 2010, 07:42:14 AM
megasquirt, fuck it all
Post by: nock on February 05, 2010, 07:44:20 AM
and ITB setup for some wow factor.
Post by: PhilStubbs on February 05, 2010, 07:50:20 AM
ITB's and boost seem like a waste of effort.
Post by: Joseph Davis on February 05, 2010, 07:59:25 AM
As is the entirety of motor sports.
Post by: Robb on February 05, 2010, 03:28:50 PM
I don't think there are many people willing to dial in Camreys other than serial killers.
I have access to a sweet 88 camry ALL-TRAC that needs some boost... they actually weigh in 100lbs less than the 91 celica alltracs...
Post by: nock on February 05, 2010, 07:44:00 PM
truer words have never been spoken
Post by: PhilStubbs on February 05, 2010, 08:31:07 PM
im not a toyota fan, i thought the all-trac's came boosted.
Post by: Robb on February 06, 2010, 01:52:15 PM
Celica alltracs were boosted, corollas, camry's, and previas' are not.
Post by: PhilStubbs on February 06, 2010, 04:04:04 PM
teeyan foewer
Post by: AstroVannin on February 06, 2010, 04:31:58 PM
Might be useless information here.... But my Tercel (1991) used an AFC hack with some Celica 315cc injectors (originals were 155). It was only ever OK... never Great. Always weird timing issues.
For this Tercel, I got an AEM F/IC .... To me it looks like the right anwser since its got fuel and timing control without one affecting the other. I thought it looked like a good deal since it has its own MAP sensor and comes with a generic harness.
Maybe thats the anwser to your tuniong woes ?
Post by: t_cel_t on February 19, 2010, 04:48:47 PM
thats weird, there was the exact same deal here in lacross, wi like last year.
