General Category => General Discussion => Topic started by: reddevil on February 25, 2010, 02:47:52 AM
Title: Help or Hurt... 205/55/16 to 205/50/15 tire size...
Post by: reddevil on February 25, 2010, 02:47:52 AM
So I am currently trapping 117.xx @ 6900 rpm at the finish line with the 205/55/16 tires.
Calculations say if I change to 205/50/15, I would hit 108.5 @ 6900rpm. Slightly larger tire 225/50/15 I would hit a about 112.xx @ 6900 rpm.
So.....
Technically I get out of the hole a bit quicker, but will the fact I need to shift to 5th be benificial?
I am making about 400/400 power....
Title: Re: Help or Hurt... 205/55/16 to 205/50/15 tire size...
Post by: crttaz on February 25, 2010, 06:32:04 AM
real question should be 23" or 24" slicks.
Post by: d-rail on February 25, 2010, 06:48:51 AM
real question should be 23" or 24.5" slicks.
Post by: caged on February 26, 2010, 02:41:53 AM
real question should be cv shafts??
Post by: Atticus on March 02, 2010, 01:48:57 AM
preload
Post by: 98vtec on March 02, 2010, 01:51:57 AM
spinning halfway down the track raises MPH
Post by: caged on March 02, 2010, 03:56:13 AM
preload
Preload + semi slicks still= broken axles with this hp on early wrx or legacy gt Axles.
I would stay with the taller tyre so you dont loose tyre length (not width).  Shifting into 5th before the line would be a waste of time UNLESS you plan on more hp. You could just put some 4.4's in next time you do a gear or syncro. What are your 60fts?
Post by: Urban Indian on March 02, 2010, 04:34:42 AM
preload
Nobody cares what you think Eminem
Post by: reddevil on March 02, 2010, 06:28:05 PM
2.0 cause of bad tires and early season slick track.
This tranny has done 1.75 60' times in the gutted wagon.
Post by: Atticus on March 03, 2010, 11:42:14 PM
preload
I take it its not a 20 min job like a civic.
How strong is the tranny/diff ?
Post by: caged on March 04, 2010, 04:10:08 AM
Na its all easy to pull out. We havnt had a diff problem yet but have stripped the teeth off 5 third gears, killed heaps of syncro's on track days and blown a few other gears. I found that using a twin plate clutch hurts 3rd gear more. We broke 1 front and 1 rear axle on 1 launch, also broke about 3 more axles that day on semi slicks. This is with between 380 and 480whp on a 97 STI sedan.
Post by: reddevil on March 06, 2010, 03:44:54 AM
Oooooh they hurt.
Mainly because I could not hook up.  My 60's were never better than 2.0....
I had ONE chance to break 12.5, but because I have never shifted into 5th at the dragstrip, I missed 5th and ran 12.6 @ 102.
The rest of the runs I was hitting redline right before the damn traps so shifting was a waste.   Redline = 112.35 using 205/55/15 tires for me.
I felt I had one Awesome run in me.....  wow what a hookup in third!   what pull!
Then I shifted back into 1st....  The ONLY time I have ever done this.   >:(  To top it off, I was against a new camero, it would have been SO FLIPPING awesome to stomp it with my best run ever...  Instead I did a 16.6 @ 109....
So....  Back to the crappy 16"!
Post by: caged on March 06, 2010, 05:21:51 AM
Its got potential if it ran 12.6 @102 and a 16.6@109. keep working on that 60ft and get some low 12's :noel:
