General Category => Hybrid/Tech => Topic started by: SDRAWKCAB on April 10, 2010, 04:14:27 PM
Title: Calling on infinite knowledgeabilities
Post by: SDRAWKCAB on April 10, 2010, 04:14:27 PM
Ok my f23 had
coolant in the oil
smoked white like crazy
and bubbled in the overflow
Which are all strait signs of head gasket failure
Pulled the head today, gasket looks fine
cylinders are not cracked
head looks mint
pistons are shiny fresh which is probably from the burning coolant
Getting the head resurfaced Monday.
Iv never had a stock MLS head gasket go bad before and looked for sings, cant find any but a little black between the cylinder bores,when composites go the blow out chunks. To be honest I don't know what mls look like when they blow. Im thinking the head warped, don't have a dependable strait edge to use and out of good habits I get all my heads resurfaced.
Its also going back together with ARPs Honda HG and IM gaskets.
So Before I slap this thing back together is there anything I should look for that could have caused these symptoms other then head gasket?
Title: Re: Calling on infinite knowledgeabilities
Post by: Robb on April 10, 2010, 04:18:59 PM
Cracked block.
But its probably a headgasket.  Blown MLS dont necessarily mean "blown" out like a composite.  Thermal expansion yo.
Post by: Foowee on April 10, 2010, 04:22:42 PM
Try a fluorescent light bulb n some feeler gauges...
Post by: SDRAWKCAB on April 10, 2010, 04:34:23 PM
Cracked block.
The sleeves look great no signs of cracking. This was eating coolant hard I think it was even coming out the header when I unhooked it.
Never thought of that and I have one of those, but then I wouldn't ever think of using brakekleen cans as charge piping.
Thank you.
Forgot to mention When  I was removing the stock head bolts all of them they felt like they were torqued to like 150 ft pounds could that be from the head warping?
Anything Else I should look for?
Post by: Jorsher on April 10, 2010, 05:32:44 PM
Aftermarket studs by any chance?  My ARP ones need to be torqued to 85ft-lbs which is hard to do with the engine out of the car and you trying to hold it.
I don't think MLS gaskets are as easy to see "blown" as others.  Since the engine is apart, I assume you plan to replace the headgasket anyway.  Personally I'd just throw a new one on and see how it goes, and if you got a few bucks go ahead and get the head resurfaced.
I had an oil/coolant mixture going on, but it was due to tapping too far for the ls-vtec plug on the bottom of the head, making the wall between the oil/coolant passage a little too thin, and it not standing up to the pressure and cracking.
Either there's a crack in your engine, or the headgasket is blown... Headgasket is cheapest, so I'd start with that.
Post by: PhilStubbs on April 11, 2010, 09:22:31 PM
Flouresent bulbs arent really straight. I would just resurface it. I bet the last person that had it, blew the headgasket and just replaced it without resurfacing it. Gotta watch those mexicans
Post by: HiProfile on April 12, 2010, 04:23:26 AM
I did an h22 with the same issues, header was actually full of coolant. Head was indeed warped, never checked the block. Slapped it together (she was conned into cometic mls), worked fine till the bitch blew another coolant hose and drive a another few miles. It's like the only way to teach a girl how hot an aircooled motor can get is by pressing their forhead into the fins of a Harley evo.
Old bolts can get tight especially if they got hot. The lube in the threads and under it's head deteriorate, which makes it acidic and slightly corrosive. It mildly fuses the metal together partially from corrosion, partially from galling. ARP's usually use moly for thread lube which doesn't break down bad like motor oil.
One thing I'd check is the rings & ringlands. I did a field strip of a b18b that was blowing white clouds after a night of boosting unknown psi on a basemap. All 4 pistons' ringlands were broken like buk's dreams of becoming the next engloid.
Post by: SDRAWKCAB on April 12, 2010, 11:19:45 AM
Yeah sounds like the head warped because this thing was eating mad coolant.
I cut out the thermostat cause shit wouldn't budge after the fact.  :-X
The rings are probably fine this shit never saw boost or any kind of real power adder, the kid I bought it off had a professional fresh swapped h22. Regular honda tech fagot. After it was in the bed and I had already paid him, he asked me why I wanted a f23 instead of buying a more superior h22. I told him h22s are garbage and he just sold me the best accord motor for 150 bucks that honda makes. He looked like he just got ripped off and was like OH.
LOL at honda tech kids
Post by: SDRAWKCAB on April 13, 2010, 04:07:55 PM
They had to pull off 15 thousandths to get the shit plane. So it was warped as fuck. Well at lease I got the problem fixed.
Thanks for the help.
Post by: onlyflash944 on April 20, 2010, 05:37:31 PM
thats a sizable bump in compression, btw
Post by: 92CXyD on April 20, 2010, 05:40:42 PM
And some cam timing adjustments need to be made.  :?:
Post by: Joseph Davis on April 20, 2010, 09:55:12 PM
Retard the cam two degrees to compensate, then another three for best power.
Post by: SDRAWKCAB on April 20, 2010, 10:30:33 PM
I thought removing head/block material retarded cam timing because it produces slack in the belt?
yeah it probably raised the compression a point.
Iv been running on 93 with the base timing at 18 degrees no ping runs strong.
Im definitely loving the h22 tranny.
Post by: HiProfile on April 21, 2010, 01:05:31 AM
Speaking of retarded, who's the one gloating over buying a blown motor for a steal? lol j/k If you picture a cam gear moving downwards, it will start advancing itself. The tensioner will take up the slack on the other side, and since the crank is what sets TDC... Play with some sockets and a rubber band, it works the way we say. :yes:
So did you just get the head checked, or the block too? It's not common for a block to get fucked, but still possible.
Post by: Joseph Davis on April 21, 2010, 07:55:47 AM
Keep thinking.
Post by: jay on April 21, 2010, 08:28:20 AM
Keep thinking.
did we just find someone dumber than me?
ITS CALLED A BELT TENSIONER RETARD
WHICH MEANS YOU PROLLY NEVER TOOK A HEAD OFF YOUR MOTOR OR SWAPPED HEADS OR DID A HEAD GASKET JOB SHIT THAT EVEN I DID
GO KILL YOURSELF FAGGOT
ok im done
Post by: onlyflash944 on April 21, 2010, 02:11:54 PM
Keep thinking.
ok im done
I know dumber is a real word and all, but more dumb just sounds better.
Also, it's 'probably' and learn to use proper punctuation before we actually vote on the topic.
What I was thinking:
Probably the Funniest Cat Video You'll Ever See (http://www.youtube.com/watch?v=SUNmLuNdiL8#lq-lq2-hq-vhq)
Post by: jay on April 21, 2010, 04:03:23 PM
Keep thinking.
ok im done
dumber is the right way
prolly is something i picked up in Maryland
god damn white trash hippie farmers
Post by: SDRAWKCAB on April 22, 2010, 11:57:11 AM
Keep thinking.
ok im done
Hey JAy fuck face the tensioner pulls the slack out of the right side of the belt pulling the cam retard (Like you, you stupid fuck) toward the back of the engine bay.
I put the belt in the same location it was before. I didnt advance a tooth on the cam gear when I put the belt back on. so its running like 2 degrees retard (Like you, you stupid fuck)
BTW fuck shit Iv built 2 motors boosted 3 of my own cars not including friends and  probably done more rewires and chipped ecus then your moms given you blow jobs inbred retard.
Now For some one how knows shit why is my logic flawed grand wizard?
Post by: SDRAWKCAB on April 22, 2010, 12:08:47 PM
Milling the head or decking the block decreases the distance between the cams and crank. The timing belt stays the same length, so for every .012" you remove, cam timing is retarded 1 degree. Advance accordingly to get back to true zero.
Post by: Joseph Davis on April 22, 2010, 12:30:52 PM
Remove .025".  Do you put the belt on a half tooth advanced or a half tooth retarded?  A D16Z pulley on a D16A, very common mistake, will result in a two degree deflection that further hides/complicates things.  Other pulley/motor - or, god help you, lower cover - mismatches will fuck you further and harder.
Post by: 92CXyD on April 22, 2010, 12:32:28 PM
That's what I had to do with d16z6/y8 build after decking 0.020".
I advance 4.5 deg for the y8 cam and z6 cam difference and 2 degrees retard for the decked block. ;D
Post by: SDRAWKCAB on April 22, 2010, 12:37:27 PM
But is my knowledge correct?
BTW the car is driving great With the exception of not idling whens its cold do to all the JB weld in the IAcv O0
I did the el gauge cluster swap cause the speedo was bad and that shit looks awesome.also retorqued the headstuds to 105ft pounds
Post by: Joseph Davis on April 22, 2010, 03:38:00 PM
No, you are arbitrarily advanced or retarded depending on your build particulars.
Post by: SDRAWKCAB on April 22, 2010, 11:31:32 PM
Like I said I need to get a adjustable cam gear and advance it 2 degrees to be at stock timming.
Post by: Joseph Davis on April 22, 2010, 11:38:52 PM
I'd leave it retarded.
Post by: SDRAWKCAB on April 22, 2010, 11:58:28 PM
Well anything I touch ends up being retarded anyways.
So, I guess its alright.
BTW whens the tuning tutorial meet gonna happen I have a reliable car again.
Plus I owe you drinks.
Post by: 2slow on April 28, 2010, 09:44:13 PM
JD only drinks appletinis with  belvedere vodka
Post by: Joseph Davis on April 28, 2010, 09:49:36 PM
I'm hypoglycemic, I'll drill any sweet alcohol.  I fucking feel a lot better the next morning if it's not sweet, though, the extra sugar kills me.  I don't get hung over, but I sleep too much and end up bleary.
Post by: MAJORAHOLE on May 05, 2010, 02:08:36 PM
= hangover
Post by: Joseph Davis on May 05, 2010, 04:56:48 PM
No, a hangover is that hollow feeling.  Headache.  Light sensitivity.  In extreme cases, nausea.
What I'm talking about is something different.
Post by: MAJORAHOLE on May 06, 2010, 08:03:51 AM
you mean just kinda, not right?
like it feels weird to drive the first time the next day
Post by: Joseph Davis on May 06, 2010, 08:57:33 AM
No, I'm talking about hypoglycemia.  Not still being drunk from the night before.
Post by: 92CXyD on November 20, 2011, 02:29:43 PM
Thinking of doing a z6/y8 setup with Vitara and eagles and decking the block 0.080",
Wondering if I should retard the timing 6-8 deg or get a shorter TB?
Using a y8 cam: adv. 4.5deg + retard 8deg = 3.5 toal retard.
Thoughts anyone?
Post by: DasPoop on November 20, 2011, 02:45:40 PM
get a shorter TB?
???  What is the reason other than deck height you would want to play around with cam timing? .080 with vitaras makes them stick out of the block. What sort of thoughts you got cooking up in your garage :noel:?
Post by: 92CXyD on November 20, 2011, 03:16:38 PM
get a shorter TB?
-0.013" below deck according to http://zealautowerks.com/dseries.html (http://zealautowerks.com/dseries.html) and 8.97:1 comp.  :noel:
May change thoughts to 0.060" decking to keep the piston 0.007" below deck 8.62:1 comp and cheaper setup.  :noel:
Post by: DasPoop on November 20, 2011, 11:41:30 PM
a negative number means higher than the deck. I thought the same thing when i was looking at pistons but found out real quick it was the other way around.
Post by: 92CXyD on November 20, 2011, 11:46:52 PM
I already knew that.  :noel:
Post by: HiProfile on November 21, 2011, 10:42:44 AM
Wouldn't it be cheaper to get extended rods than paying for the severe decking?
Post by: 92CXyD on November 21, 2011, 10:56:28 AM
No, b/c I can do the bore/honing and decking at work.  :noel:
Post by: Joseph Davis on November 21, 2011, 11:48:53 AM
Why deck?  D16 + CR causes problems on octane limited setups aka streetcars.  I've yet to see a D16 streetcar with a breather that was up to the engine it was attached to.
Post by: 92CXyD on November 21, 2011, 01:27:24 PM
So you are suggesting I stick with 0.020 decking off the block to maintain my 8:0:1 compression I had before?  :noel:
Post by: snm95ls on November 21, 2011, 04:27:48 PM
That is a hell of a lot.  I wonder if they checked to cam journal alignment before just cutting away.
We have a very good cylinder head shop here that will actually check for things like that, and actually bend it back in place before surfacing it.
Post by: Joseph Davis on November 21, 2011, 05:31:30 PM
It's less effort, and not like an 8:1 D16 has any problem making power over and above port/cam restriction.
Post by: 92CXyD on November 21, 2011, 05:56:57 PM
You had a taste of what my car does with 8.0:1 and s/c.
I'm running a stock z6 with my s/c and it seems to be a little more aggressive.  :noel:
Post by: Joseph Davis on November 22, 2011, 09:24:12 AM
Your motor with the SC off is more powerful than a stock Z6, there was something right about it.  With the blower, yup they love CR, but last I knew your goal wasn't to max out an SC14.  At some point you have to drop CR to up combustion chamber volume so you can pack more airmass in there without detonating... at that point, fuck hp per psi as you're making hp and not worrying about show off forum faggotry.
Post by: PhilStubbs on November 22, 2011, 02:41:06 PM
But...... I thought 400whp at 10psi was what the cool guys do, even if you do spin a bearing first trip down the strip.
Post by: Joseph Davis on November 22, 2011, 06:00:27 PM
84mm B18x @ 8.5-9:1 CR with a topmount, GT40+ sized turbo, Vickie-X IM, 4" DP and 3" charge pipe = 400whp at 10 psi.
Post by: PhilStubbs on November 22, 2011, 07:50:06 PM
i was knocking a previous hmt owner that got a little timing happy with an h22
Post by: Joseph Davis on November 23, 2011, 12:57:57 PM
I was existing literally, and in the moment.
Post by: 92CXyD on November 23, 2011, 01:23:58 PM
Since I did nothing major with the bottom end (0.5mm o/s vitara/eagles combo), I'm wondering if the my dyi ported y8 head helped?   :noel:
Should run the new block with a devcon fill again like the last one, or not?
Post by: Joseph Davis on November 23, 2011, 05:13:56 PM
Porting, yes.  Devcon, no opinion as long as you pour it 2/3rds the way up and leave room for coolant to flow across the top - none of that at the top shit so the head can't cool itself.
Post by: PhilStubbs on November 23, 2011, 08:08:05 PM
all of my research and understanding says to not fill, post, or block guard honda blocks.
Post by: Joseph Davis on November 24, 2011, 04:05:23 AM
All my research and understanding says vagina is awesome, no matter the bad rep it's gotten on the Vortex.
Post by: PhilStubbs on November 24, 2011, 08:11:38 AM
ZING!!!
Post by: ratcityrex on November 24, 2011, 12:39:24 PM
Lol, lower comp Honda motors make good power. More room + more air = more power. Works extremely well once you throw some boost on it too!
Post by: SDRAWKCAB on November 26, 2011, 04:19:16 PM
I fucking hated that car by the time I sold it. D/B series 4life!
