General Category => Hybrid/Tech => Topic started by: MAJORAHOLE on April 12, 2010, 02:42:27 PM
Title: Mitsu idle problem
Post by: MAJORAHOLE on April 12, 2010, 02:42:27 PM
got a 1.5l mitsu mirage ive been driving while working on my civic, well the idle is shitty once its warm, could this be the EGR? or what else?
we've had this car for 8 years, and its always done this, and for a while it might stall after its been idleing at a light, and you go to step on the gas.
idk wtf the deal is, maybe clogged cat?? or would that be consitently shitty idle no matter engine temp?
suggestions?
Title: Re: Mitsu idle problem
Post by: hatchboy on April 12, 2010, 02:49:50 PM
suggestions?
go back to Ohmt pop tart.
Post by: MAJORAHOLE on April 12, 2010, 03:12:40 PM
duly noted... and i will reply with a "fuck you"
Post by: hatchboy on April 12, 2010, 03:28:06 PM
you are the 2 timer homo.
Post by: MAJORAHOLE on April 12, 2010, 03:36:13 PM
 how about something helpful/usefull/not full of fail, or stfu.
Post by: jarebear667 on April 12, 2010, 04:07:51 PM
this is a problem with all mitsus do a search on a mits based site instead of just coming here and begging becuz ohmt left you answerless because they are a bunch of faggots and losers
Post by: MAJORAHOLE on April 12, 2010, 04:21:49 PM
first, i didnt aske this at ohmt
second, i tried a dsm site awhile ago, and also with a local self proclaimed "dsm genius" who didn't know shit apparently.
third, just because i didnt get my post count transfered over from Ohmt doesnt mean i dont know shit
you 2 GD trolls should just stay there
Post by: Robb on April 12, 2010, 07:20:07 PM
Its a lost cause. You just need to give it to me.  :P
There are many things that can cause a shitty idle on the 4g15, the most likely being the idle control motor itself, or the ecu.
unhook the vacuum lines to the egr and loop them on the valve, /egr.
4g61t.org is where you need to be.
Post by: MAJORAHOLE on April 13, 2010, 08:31:08 AM
thanks for the info, its not ahorrible thing, just gets annoying.
Post by: jarebear667 on April 13, 2010, 11:19:15 AM
posslible biss screw.
Post by: Robb on April 13, 2010, 11:21:47 AM
4g15 doesnt have one.  The idle set screw is on the throttle body bracket, and does nothing more than push the plate open/closed.  Not like a dsm where the BISS opens a channel in the TB. So there's nothing to leak.  You are correct in your thinking, that perhaps there is a vacuum leak, but suprisingly unless its a big leak they dont seem to affect the 4g15/ecu like a 4g63. Different coding in the ecu I suspect.
Post by: MAJORAHOLE on April 13, 2010, 12:56:11 PM
maybe because its non-maf? idk. i'll be lookin more into it tonight and see what i can find.
btw, its only under load, not in park
Post by: Robb on April 13, 2010, 02:45:45 PM
SD? Are you in canada? we didnt get those in the US so yeah whole nother ball game.  Hop on one of the AUS mitsu forums and read for about 2 minutes and you will get your answer.
Post by: MAJORAHOLE on April 13, 2010, 03:17:29 PM
im in northern indiana???
Post by: Robb on April 13, 2010, 03:51:10 PM
Grey market car.  The MAF system used on the mirage is very close to the 4g37, but the MAP system isnt like anything else.  Like I said, hop on the australia mitsu forums.
