General Category => General Discussion => Topic started by: michigan_soler on April 16, 2010, 05:01:04 PM
well, i was doing a clutch the other day and popped out the ball joint, and started to think if there was a better way.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Frevbeergoggles.com%2Fballjoint1%2Fball-joint-tool.jpg&hash=61d816156ea2f28678b470bab1e91f9dda666317)
i use one of these but make sure the nut is over the cotter pin hole. and ive tried the pickle fork thing but that tears up boots, so fuck that. any other good way?
Big fucking hammer and hit the lower part if the knuckle.
man speaks the truth, I always just use my bfh
BFH is my tool of choice.
BFH works great. Just don't hit the threaded end, or you'll quickly mushroom that shit, and never get a nut back on.
Honda painless ball joint removal (http://www.youtube.com/watch?v=ISY8bGof3bQ#lq-lq2-hq-vhq)
heat and BFH
pimp!
i take the nut off and flip it around so the castle part is down, then thread it almost all the way on and hit it with a bfh. sometimes have to get a new nut, works 70% of the time all the time.
That's how I do mine
damn, i'll be doing that... it looks way easier.
With a fork. never messed up a boot yet. but i probably jinxed myself there.
Craftsman wrench method ftw, no reason to use any other method.
What is the craftsman wrench method?
sledge and pickel fork if i have to. ive fucked up one boot before, but that was after a long period of time. sometimes they come off easy without a sledge or fork just with hand. other times i beat the fuck out of it with the fork and sledge. ill be trying the wrench method next time i have a tought one for sure.
refer to the youtube video posted
Same as the vid posted earlier.
I should have said craftsman 1/2" drive ratchet method
hell yeah, works so good.
just jack up that one LCA, wedge something tight in there, let out on the jack and pop. all done.
too bad we cant do that for tie rods and upper control arms.
Wrench trick.
Thats how I do it to! thats the only way.
+1
No banging, works every time even on ball joints that haven't been popped out in 20+ years...
grind that center point flat and you'll be fine.
Air hammer FTW on all ball joints/outter tie rod ends :yes:
fork and bfh
that was just a pic of it that i found online... mine is flat...
Flat rate Nigga!
Undo upper control arm bolts and pry axles out....
Why pull ball jonits to do a clutch?
Any how i use a BFH when i gotta do them there balljoints....
its way easier to pull the lower out and lift up then actually having to fool around with trying to pull out the axles.
Not if you fuck them up like 90% of twats pulling them. I have had to fix more people ball joints when they said the same thing way easier then pulling the uca. well.... :?:
long pry bar on top of the LCA, stand on both ends and jump!, this works better if you're not a skinny fuck such as myself.
+1.5
BFH on lower join+jack the car up by the rotor so the weight of the car is pushing down as well :yes:
THAT IS FUCKING TITS!
Im doing my shit that way from now on.
All of my LCAs look like they caught the herp from hotrex because of BFH.
If the spring doesn't pop it, just stand on the rotor. Never fails.
i unbolt the upper control arm from the car, no chance of messing anything up and no need to mess with cotter pins. i do honda axles in 10 min or less all the time
Will be using the above tool shortly.
Redoing the front end of the 91 Sedan after snapping a knuckle Monday.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi107.photobucket.com%2Falbums%2Fm307%2Fbonespec%2F4%2520Door%2520EF%2520EX%2FSkunk2%2FP4120005.jpg&hash=506d531fdd479fa606da10adda2d251ddcf836bd)
Skunk2 UCA in that pic has 3/8" movement up/down and only has about 5k miles on it.
How the hell did you manage that?
the pitman remover never failed me yet
just pulling into a parking space.
Broke the LF on the CRX as well, but that was caused by a 2007 Accord :(
i pop mt ball joints with an ak47
that what you do when you have a herpes outbreak?
Crapsman ftw. It's crazy how easy it is, and how perfectly sized a craftsman socket wrench is for that. It goes next to the ball joint's rubber, between the lca and knuckle if anyone missed that.
One guy I know who works at a rather prestigeous Honda outfit has used a BFH for years. He wails on the side of the LCA, albeit he's bigger than spiker. It deforms the hole just enough to unstick the 2 metal parts. Apparently it's never caused an issue, besides missing a handful of times and destroying other parts... :P
