General Category => Hybrid/Tech => Topic started by: Jorsher on June 29, 2010, 04:20:34 PM
Title: Rear mount bolt
Post by: Jorsher on June 29, 2010, 04:20:34 PM
Not really a question or a big deal, I'll just find a bolt that works, but curious about this:
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fwww.acuraautomotiveparts.org%2Facura%2Fjsp%2Fmws%2Fcatimgs%2F13sk701_b47.png&hash=b0f1ffb4724e206dfd89c5d48ee50d5033cbb1af)
 24     90188-SF1-010     BOLT, HEX. (12X61)     002     1993     INTEGRA
It says there are 2 of bolt #24 required.  It's a long 19mm bolt that couldn't possibly go anywhere else on the diagram.  The top one threads in all the way, no problem.
The bottom one, since the mount is "thinner" at that bolt, the bolt will not thread fully in.
I'm just going to find another bolt that will work, but what the hell is up with that diagram?  My engine is rocking and breaking exhaust frequently along with wearing down a hole in the valve cover.  I'm not sure that missing bolt is the problem since there are two others holding the block to the mount, but, it's the only thing I can think of.
Title: Re: Rear mount bolt
Post by: crxvtec91 on July 03, 2010, 05:02:59 PM
What dont you get? Its 2 19mm bolts, and one is longer then the other one.
Post by: DasPoop on July 30, 2010, 09:41:14 PM
if it threads in to deep how about a bunch o washers or perhaps swap them around if its too short? its a honda just go to the bone yard and grab one stick it in your pocket and call it a day  :noel:
Post by: HiProfile on July 31, 2010, 12:03:16 AM
But Honda is basicly saying the 2 bolts are the same P#, meaning same length. Bone mentioned they have the d-side tranny seals on another diagram wrong (zc instead of normal b or d seals), so they aren't always perfect.
I'd definately add that bolt, but it's most likely bad mounts causing issues. 3M Window Weld time (napa). If it's exhaust studs not the exhaust pipes breaking, it's a warped header flange.
Post by: Jorsher on July 31, 2010, 05:37:59 AM
But Honda is basicly saying the 2 bolts are the same P#, meaning same length. Bone mentioned they have the d-side tranny seals on another diagram, so they aren't always perfect.
I'm glad someone knows what I'm talking about.
It'd take a ton of washers to make it fit, just making sure I wasn't crazy.
Anyway, I put the bolt in and it's stayed in so far and has stopped the engine from rocking around.
Post by: HiProfile on August 01, 2010, 09:22:47 PM
Well then check to see if the top #25 bolt is in. It goes through the tranny from the passenger side, iirc. If putting the lowest bolt in fixed it, something's telling me the top is missing.
Post by: Jorsher on August 02, 2010, 12:32:35 AM
You would think that, but nope.  Was only missing the bottom bolt when I took the engine out.
Put it back in, threw on the too-long bolt Honda says to use, and threw some loctite on the end...
Has held in for a few weeks now.  If it ever falls out I'll grab one from the hardware store that is the proper length.
Post by: HiProfile on August 09, 2010, 01:02:11 AM
Well then you are a lucky bastard living to such an awsome hardware store. IIRC every bolt over 6mm on Hondas are fine threads, and larger bolts use super-fine threads. They tend to be m#x1.25mm for m8's and larger, or maybe m10's. The only way I found taps for them was by chance - someone selling a "vintage" japanese bike tap set, m10/m12/m14x1.25mm. Fastenal and McMaster are my only go-to places besides Honda.
Post by: Jorsher on August 09, 2010, 12:18:45 PM
I don't know if the place here has it.  Probably not, if they're that odd...  Either way, we have a Fastenal here.
