General Category => Engine Management => Topic started by: speedjunky01 on July 26, 2010, 07:19:42 AM
So this kid has a DA integra running a t3 in it and the tune is trash. I offer to work the tweaks out of it and I grab my ostrich1 and try to connect to ecu but it just won't
-all 28 pins are in red facing the ecu wires on the front of ecu
-ng60 in turbo edit, baud is 125000 in TE and device manager
-it is the right com port
Unsure of what else to check been googli g and reading pgmfi but not much luck. Anyone care to help a te noob out?
try 11XXXX Baud
What version of TE? What are the messages in the console?
The newer think it's 3.19
Walter yeah its 112500 or whatever it's supposed to be set to for ostrich v1
I'm slow this morning... You need to set it at 920k not 125k.
You should use the last version of ng too it's ng_63 now.
http://forum.pgmfi.org/viewtopic.php?f=7&t=20342&sid=1db956d7308bee223bdbd84829a87d86&sid=1db956d7308bee223bdbd84829a87d86#p122419 (http://forum.pgmfi.org/viewtopic.php?f=7&t=20342&sid=1db956d7308bee223bdbd84829a87d86&sid=1db956d7308bee223bdbd84829a87d86#p122419)
Will update and try it again later
Any other ideas?
That's will work for v1.0, unless you updated it's firmware to make it as fash as a v2.0
Also, you fail? Try to upload with Tunerpro if TE fails you.
as always thanks for the info sir
Informative but also makes me feel like a worthless dumb cunt the perfect JD post
yeah for the ostrich 2 only i though?
i did update the ostrich when i got ectune but that shouldnt affect it should it?
Bah, you make me feel like an asshole.
still having issues wtf :(
-ostrich v1 firmware is v10.20.0
-TE v 3.2.1 thats the newest one i could find
-tried all baud rates no go :P
-tried restarting TE after any change, still to go
-got ng63 no change :P
really not sure where else to go, if should still connect to the ostrich even though its not plugged into the car shouldnt it?
Try this one just for fun. Old version of TE that I patched to work with 920k Ostrich.
http://forum.pgmfi.org/viewtopic.php?f=56&t=14452&p=92515&hilit=920000#p92515 (http://forum.pgmfi.org/viewtopic.php?f=56&t=14452&p=92515&hilit=920000#p92515)
what kind of wizardry is this :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o
now to get it to work with the new one lol
also the fastest baud i have is 921600 dont see 920000
Sweeet :)
Me > people who are working on TE 3.x :P
TE is a closed source open source project. I can't work on it lol
Did you unpair the ostrich from ectune?
Didn't know that even had to be done thought it was just plug and go
hook it back into ectune and reset vendor in ostrich info. If you did not do this, that is your problem...or atleast part of it. With the ostrich paired to eCtune, you will not be able to use it with any other software until you unpair it. Once you are done with TE, simply go back into ostrich info and lock the ostrich back to ectune in order to use ectune again.
worked like a charm turbo LS=tuned O0
now show me some titties mother fucker! O0
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2F4gifs.com%2Fgallery%2Fd%2F162981-2%2FCupping_boobs.gif&hash=9fd42e4031fdad0a032cce9c978a8d42c326cab4)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2F4gifs.com%2Fgallery%2Fd%2F164214-1%2FNude_bowling_jiggle.gif&hash=c136503d3f6afe3cc32fe22cda0c7ee3f7116b24)
