General Category => Engine Management => Topic started by: DasPoop on August 19, 2010, 09:59:20 PM
Title: Dumbass me looked down at the wrong time
Post by: DasPoop on August 19, 2010, 09:59:20 PM
I was wiring up a harness and if at all possible can someone take a pic of an obd0 drivers side shocktower plug the harness side? more or less showing the injector wire locations. I normally stick my tool in the hole so i know where the new pin goes but for whatever reason i looked down and didnt and I cant find the image after google searching or on mitchell
Thanks in advance
Title: Re: Dumbass me looked down at the wrong time
Post by: turbob16hatch on August 19, 2010, 10:03:41 PM
If this isn't answered by the time I'm back from the shop i will have pics up.
Post by: Joseph Davis on August 19, 2010, 11:36:38 PM
The only 88-91 in the parking lot is mine, and it's LOLOLOL not OEM wiring.
Check a Helms in the Hybrid/Tech section, they have actual pin/plug location charts.
Post by: jabberwock on August 20, 2010, 08:28:23 AM
Double check and cross reference pinouts with wiring diagrams, sometimes they liked to throw in random colors of wires for no apparent reason.
Post by: Joseph Davis on August 20, 2010, 09:01:33 AM
Not everyone can be as stale and predictable as you, you non screwdriver shipping motherfucker.
Post by: DasPoop on August 20, 2010, 11:09:37 AM
i have the pinout locations but not what went in what pin. all i need to know is where the factory 2 dpfi injectors plugged in I have 1 of them pinned in the right location and I removed the tandem valve wiring in the plug leaving 3 locations. I know its not one of them but i am not sure which of the other 2 it is.
Post by: HiProfile on August 22, 2010, 12:10:05 PM
So is this at the obd0 ecu connector? Or at the engine bay connector?
At the ecu, mpfi/dpfi is shown here: http://hondaswaps.info/obd0-dpfi-to-mpfi-comparison-pinouts.html (http://hondaswaps.info/obd0-dpfi-to-mpfi-comparison-pinouts.html)
If you need the pinout at the engine bay harness, I still have my dpfi-mpfi-obd1 harness I made. It uses an obd0-1 adapter from boomslang, so it has an extra connector in the engine bay to add some extra wires. It's just 30 minutes away in my storage shed, which I don't think I'm visiting today.
Post by: DasPoop on August 22, 2010, 01:17:33 PM
I just need a pic of a stock dx drivers side obd0 harness plug specifically the upper right pins because those are the injector power wires and injector wires.
Post by: 2slow on August 23, 2010, 11:45:36 PM
Can you not look at the colors of the pinout for some  reason
Post by: DasPoop on August 23, 2010, 11:50:07 PM
got it all straightned out and since i dont have a dx car to look at i couldnt just look at the colors on the other side
