General Category => Hybrid/Tech => Topic started by: turbocivichatch on September 15, 2010, 03:34:47 PM
Title: crank comparison
Post by: turbocivichatch on September 15, 2010, 03:34:47 PM
have a ? about d16a6 and z6 cranks need to know if they are the same specs!!!!
crank is worn at the keyway on my z6 and i need to get back together
Title: Re: crank comparison
Post by: ryan89crx on September 15, 2010, 03:39:39 PM
Some early '88 a6 cranks had a smaller snout than the majority of a6 cranks. As long as you don't have one of those, they are direct replacements for each other.
Post by: 92CXyD on September 15, 2010, 04:28:14 PM
yeap  :yes:
Post by: Foowee on September 18, 2010, 08:15:37 AM
I've seen people weld up a slopped out crank keyway and re-cut it with a dremel.  Just takes skill and patience.  It might be less work than pulling a trans, dropping a crank, n resizing all your bearings.
Post by: Towdogg on September 18, 2010, 12:35:11 PM
FLAT RATE BITCHES!!!!!
Post by: DasPoop on September 18, 2010, 06:42:09 PM
toss the balancer on and pound a fat nail in it the keyway then get in there and cut it off with a dremel if you want flat rate. round peg in a square hole will make contact on at least 4 sides and if your lucky makes a new key period  :noel:
