General Category => Hybrid/Tech => Topic started by: Foowee on October 05, 2010, 09:06:15 AM
Title: Does anyone know an easy way to?...
Post by: Foowee on October 05, 2010, 09:06:15 AM
Drop the oil pan on a real-time 4wd honda?  I just bought a 91 wagovan n the oil light goes out slow n it's rattling like it may be a bearing.  I've already adjusted the valves so I'm looking elsewhere for the noise.  It looks like I have to remove a lot of stuff to simply drop the oil pan.  Do y'all know any short cuts?
Title: Re: Does anyone know an easy way to?...
Post by: crxvtec91 on October 05, 2010, 10:26:51 AM
Oil pump is going out, CHANGE IT ASAP!
Post by: bikewrench on October 05, 2010, 11:00:37 AM
I just pulled the motor/trans out when I had to change oil pick-ups.  rt4wd pick-up is different from other d's.
I've heard of people pulling the transfer case off of the tranny, and then dropping the pan.
Best thing about pulling a rt4wd is no bitch pin :)
Post by: ApexSilver06MR on October 05, 2010, 08:58:35 PM
its only a bitch pin if you dont have the right punch for it
Post by: Towdogg on October 05, 2010, 11:32:29 PM
Ever messed with a rusty new england car?   :-\
Post by: ratcityrex on October 05, 2010, 11:36:15 PM
Truth
I have a set just like this but they have rubber grips over them.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fwww.harborfreight.com%2Fmedia%2Fcatalog%2Fproduct%2Fcache%2F1%2Fimage%2F370x%2F9df78eab33525d08d6e5fb8d27136e95%2Fi%2Fm%2Fimage_2602.jpg&hash=b8149508fe93a1bc80983f2a7176f626bfe7e485)
Post by: Teg2boo on October 06, 2010, 12:01:10 AM
My bitch pin never wanted to get out. I think it was too rusty... It was a lot easier and faster to cut the rod  ;D
Post by: Joseph Davis on October 06, 2010, 01:05:45 AM
Truth
I'll post pics of a set of those bent and twisted up.  Bitch pins earned their name for a reason.
Foowee, just pull the goddamn engine and slip something sexier in there.
Post by: ratcityrex on October 06, 2010, 01:37:51 AM
Maybe its just a non rusted west coast thing, because a bfh and the right  size roll pin punch and 5 swings later its out and I'm trying to figure out where it went.
Post by: crttaz on October 06, 2010, 02:41:20 AM
Ask Jaker......
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi392.photobucket.com%2Falbums%2Fpp10%2Fjakermacdorey%2Fexhaust3-1.jpg&hash=d92e2c171c772cde74810681e7b2bd4fe0efb8f9)
Post by: michigan_soler on October 06, 2010, 04:54:49 AM
Bitch pin on my car is easy with a 1/4-20, vice grips and even a small hammer.
Post by: Foowee on October 06, 2010, 07:02:49 AM
Not an option in this poll son...  This is my nice interior/ac/ps/automatic/daily...
Ask Jaker......
Looks like he forgot to install his vc and front cv's. But yeah, he's probably the guy I need to talk to.
Post by: jabberwock on October 06, 2010, 08:38:59 AM
I use the T-bar on a tap handle I have for bitch pins.  Perfect fit and the right length so you can swing a hammer under the car and still hit the damn thing square.
Post by: Teg2boo on October 06, 2010, 08:48:25 AM
I was wondering how hard I can hit it with a hammer without breaking anything in the transmission? I've read somewhere that it's very bad to use a hammer  ???
I used this totorial http://www.performanceforum.com/wesvann/honda/bitch/bitch.html (http://www.performanceforum.com/wesvann/honda/bitch/bitch.html)
but forget about it. First, theres no place under the car to fit the C-clamp, second, theres no place under the car to fit the C-clamp. So it didn't work very well ;)
Post by: jabberwock on October 06, 2010, 09:20:06 AM
PB Blaster, tap handle, 2lb mini sledge.  3 6" swings from the ground and it's out.
Post by: onlyflash944 on October 06, 2010, 09:21:04 AM
Quote from: Teg2boo link=topic=15771.ms g189444#msg189444 date=1286369305
I have absolutely wailed on one, so hard it messed up the punch, and never hurt the transmission. PB Blaster that thing an hour before you beat on it
Post by: dvst8r on October 06, 2010, 11:05:08 AM
Mix a little atf and acetone, apply an hour to a day in advance, and then use an air hammer, bitch pin is butter.
Post by: crttaz on October 06, 2010, 11:56:08 PM
Air hammer has defeated all bitch pins but two.
One now uses a bolt to hold the linkage on without any slop...slot the end piece :)
Post by: theidealone on October 07, 2010, 01:21:19 AM
Wait. Twat? Slot what end piece. Ive always wondered why no one uses a bolt for this. Please, enlighten me.
Post by: Teg2boo on October 07, 2010, 01:28:05 AM
Fuck, why didn't I use the zip gun? Anyway, by cutting the rod it forced me to repair the 5" play I had on the shifter...
Post by: crttaz on October 07, 2010, 03:18:21 AM
Per CRX Lee Grimes of Koni USA.....
The linkage to the shift shaft on the tranny where the bitch pin goes through, relief slices were cut parallel with the ground. That way when you crank the bolt down it pinches onto the shift shaft.
But I have an issue with this...if you use the bolt you must remove the dust bellow or getting into 2-4-R is tricky even just bench shifting.
My bench shifter.......
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi107.photobucket.com%2Falbums%2Fm307%2Fbonespec%2FTransmission%2FP8040001.jpg&hash=e9a14e411a16e22ba942a9ed22364bb306f5f5a0)
Post by: Foowee on October 07, 2010, 03:27:30 AM
You're all a bunch of flatulent vaginas.  Why don't you fags try to hit it with your purse?
This thread has nothing to do with the bitch pin, which has never given me a problem in my life...  Man the fuck up n smash that pin like it's an o.d.ing supermodel.
So none of you kids have pulled an oilpan off one of these before?  Was it Highroller that built the tprc?  I guess that's where I'll look next...
Post by: crttaz on October 07, 2010, 03:30:58 AM
ask Jaker, quit bitching!
He's dropped the RT4WD crap off, oil pan access is easy then!
Wait, you have the autotragic!!!!  BAHAHAHHHAHA
BTW tell Dennis, FUCK YOU Dennis the Menace!
Post by: DmC on October 07, 2010, 07:45:28 AM
Fuck you Chuck quit crashing cars.
Post by: bikewrench on October 07, 2010, 11:31:47 AM
I copied this from HCW:
1. remove the engine splash shield
2. drain engine oil
3. drain tranny oil
4. remove exhaust pipe A (downpipe)
5. disconnect the propeller shaft (drivesaft) at the tranny
6. remove the tranny splash shield
7.remove the transfer left side cover from the transfer case. (where the driveshaft connected to on the transfer case, remove those bolts)
Note: be careful not to damage the thrust shim and mating surface
8. remove the driven gear from the transfer case
9. remove the transfer case from the clutch housing
10.remove the clutch case cover
11. remove the oil pan by removing the bolts and nuts
pan is out!!
here is a pic of a modified oil pan that is easily removed:
http://www.hondacivicwagon.com/bb/download/file.php?id=675 (http://www.hondacivicwagon.com/bb/download/file.php?id=675)
I was also reading about some folks taking all the studs out of the bottom of the block and using only bolts that way you can slide the pan side ways off the engine.
I bet there's not that many rt4wd owners on here.
If you suspect internal issues, wouldn't it be easier in the long run to pull the motor and have it in a engine stand.
Post by: 92CXyD on October 07, 2010, 11:36:31 AM
No but I would like to be one.  ;D
Post by: Foowee on October 07, 2010, 01:50:25 PM
I think this sounds almost as resonalble as spiker's mom's rates.  I think I'll try it.  Thank you.
Pulling the motor is not being considered as an option yet 'cause my garage is occupied with the scattered mess of the shiny car.
Post by: danz on October 07, 2010, 05:17:19 PM
Ask Jaker......
its RWD :)
Post by: Foowee on October 08, 2010, 12:56:38 PM
I was being sarcastic.  I know about Jaker's build n all of it's fat tire, fenderflared, two-tone flat black goodness...
I think my current plan is to either tack weld or stake the nuts to the studs so they'll back out in a simple fashion.
