General Category => Forced Induction => Topic started by: turbohf on October 08, 2010, 02:24:49 PM
Title: oil change intervals?
Post by: turbohf on October 08, 2010, 02:24:49 PM
so yeah. how often you do it? and you use regular or full synthetic?
btw here at my dealer we do Mobil 1 at 7500 miles...
Title: Re: oil change intervals?
Post by: 92CXyD on October 08, 2010, 02:32:26 PM
In my Previa every 15k b/c I use Royal Purple and it has 9qt. capacity. (7qts in the pan and 2 in reservoir). ;D
Post by: danz on October 08, 2010, 02:37:01 PM
drag car gets oil changes pretty often.
old DD boosted car got oil changes every 3000ish km.
longest i ever went was 5000km on full synthetic, which included 8 track days, probably 35-40 passes
Post by: kgx on October 08, 2010, 02:42:01 PM
7500 or after a track day. roadcourse oil temps kill even synthetics pretty quick.
i use german castrol. AFAIK, it still tests as the best or near the best oil out there.
Post by: bigdaddyvtec on October 08, 2010, 03:06:39 PM
Slut: Royal purple every 1500-1750
Rodeo... 3500-5000
Post by: bigdaddyvtec on October 08, 2010, 03:07:33 PM
the German Castrol is good, Not close to the best though
Post by: ratcityrex on October 08, 2010, 03:13:28 PM
rotella 15w-40
about every 2k. But thats like every 6 months
Post by: Kain on October 08, 2010, 04:33:54 PM
the newer modern oils generally can be left in the engine longer than the typical 3k mile.
Post by: 2slow on October 08, 2010, 05:28:56 PM
HOLY SHIT NO WAY!!!!!!!!!!!!!!!!!!
Post by: ryan89crx on October 08, 2010, 05:34:44 PM
OMG amazazing!!!!
I beat the piss out of mine, so it gets changed every 2500 or so. Synthetic in the Explorer gets it close to 4k, and the Trailblazer probably 5k+(whenever the dash tells me to lol)
Post by: snm95ls on October 08, 2010, 05:38:15 PM
I haven't changed mine yet...
Post by: jarebear667 on October 08, 2010, 05:58:01 PM
the daily prix like 5000ish, my turbo honda beating the hell out of it and track days under 3000.
Post by: brine04 on October 08, 2010, 08:34:26 PM
My slut hasn't ever run long enough to get an oil change. Daily gets 15w40 Rotella T every 10000km.
Post by: kgx on October 08, 2010, 09:14:46 PM
what's currently the best? i know GC destroyed mobil1 in a 5k oil analysis done on a 3SG.
Post by: jabberwock on October 08, 2010, 10:34:54 PM
Conventional oil, 5 to 7ish k per change.  Slopped out D.   O0
Post by: 92CXyD on October 08, 2010, 10:47:40 PM
I know its kind of old but here is the oil test I have DL to refer to. Oil%20Tests (http://www.scribd.com/doc/2428355/Oil20Tests#keyhptl03l8j76rsx1kgts)
And just found this of interest: http://www.carbibles.com/engineoil_bible.html (http://www.carbibles.com/engineoil_bible.html)
If you are using the right oil filter you can change your less often.  ;D
oil filter article: http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html (http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html)
Somewhat updated version of this article: http://minimopar.knizefamily.net/oilfilters/index.html (http://minimopar.knizefamily.net/oilfilters/index.html)
Post by: Teg2boo on October 08, 2010, 11:30:41 PM
You guys really change the oil of your car???
Post by: BoostedSchemes on October 09, 2010, 01:03:55 AM
i go to about 3-5k on all my cars regardless of what oil i run, regardless of how i drive it
its just a fucking car you fags
Post by: bigdaddyvtec on October 09, 2010, 04:19:29 AM
http://www.animegame.com/cars/Oil%20Tests.pdf (http://www.animegame.com/cars/Oil%20Tests.pdf)
 O0
Post by: 79fairmont on October 09, 2010, 09:15:07 AM
The turbo mustang I change twice a year. It runs 15-40 rotella. The daily beater I change every 5000 or so.
Post by: jabberwock on October 09, 2010, 10:10:34 AM
 O0
So if you can keep sand out of the oil pump, you'll be ok with any oil.
Fancy oils might have super neat pressure characteristics, but don't they also make you discover new leaks in the engine?
Post by: michigan_soler on October 09, 2010, 10:37:01 PM
When I get bored... 2k-10k... I look at it to see if its still gooid quite often though
Post by: bigdaddyvtec on October 09, 2010, 11:32:49 PM
 O0
When you have something that fails (Mobile 1), costs you money in valvetrain and find something that doesnt (RP)... Then find specifics showing how hard the bandwagon Mobile 1 is alkong with empirical data as to exactly how much better your new choice is (based on research).. Its win. The shit costing a bit more than Mobile 1 and deciding to change itmore often  and actually take care of the motor (Not ewxactly a 120K mile D16 or GSR) makes sense...  Sand i n it or not.
Dumbfuck.
Post by: snm95ls on October 09, 2010, 11:34:40 PM
But this guy on the internets said that Royal Purple blew up his engine...
 :P
Post by: Hotrodlincoln on October 10, 2010, 12:49:15 AM
Schaeffer oil
/thread
Post by: DasPoop on October 10, 2010, 04:13:45 AM
Oil I always use is Total. It used to be Elf but was merged. Doesn't get nearly as hot and looks great even after heavy use
Other good oil to look at is Fuchs.
Post by: turbob16hatch on October 10, 2010, 04:42:23 AM
I use castrol gtx, why you ask? It's cheap.  :-\
Post by: caged on October 10, 2010, 04:46:00 AM
I use castrol magnatec because thats what we use at work and its free and ill be fucked if im buying oil. :noel:
Post by: jabberwock on October 10, 2010, 08:54:53 AM
Fuck emissions.
Get oil with zinc and phosphorous.
What are Rotella T's zinc levels vs RP?
No one uses Mobil 1
dumbfuck
Post by: jabberwock on October 10, 2010, 09:17:02 AM
It appears from my little bit of research that new cams have not been tempered, they're still made like they were years ago.  Reusing an old cam with new oil seems to be ok with flat tappets since old oil had high zinc and this tempered them in a way.  Now only certain diesel oils and racing oils still have the high zinc.  So break new cams in with high zinc oil and then you can theoretically do whatever.
synthetics suck
Post by: Robb on October 10, 2010, 11:19:47 AM
Here we go with the mobil1 bashing again. Sigh. Seriously you guys do realize there are different blends for different weight oils correct? With that being said, PORSCHE recommends Mobil1 0w-40 in all their cars. Take into account, the minimum replacement price for most of these engines is $15k. Do you seriously think the company what has tthe best reliability ratings out of ANYONE on the planet right now, does so with crap oil in their warranty-guaranteed engines? I have replaced ONE engine in seven years due to oil failure, as it turned out the lady thought she only had to change the oild every 25k lol, and that engine made it to 50k before spinning the int. Shaft out the block. BDVT, you have experienced a catastrophic engine failure at the hands of mobil1, and that sucks. But there are several thousand 600+whp 911 turbos out there who have never experienced problems, and run 0w-40, which for the record I run in all my cars, and have for the last 6 years. I would agree that most the other blends are gov mandated detergent crap, as is most everything. Most synthetics are manufactured to the SAME specs (its called base stock, google if you don't believe) with the important stuff added later, like phosphorous, zinc, etc. How much of the good stuff depends on how they want to sell it.
Personally, owning nothing but turbo cars and driving a total of maybe 15 miles a day, I change my oil every 2k miles. Reason= contamination. Extra fuel from the warm up phase, and moisture build up from never getting the car warm enough long enough to vaporize it being the key reasons here. I also use bg107, which is basically a can of more o the same additives used to bring the oil to spec in the first place.
Post by: snm95ls on October 10, 2010, 11:40:04 AM
Is the valvetrain in a Porsche the same as DOHC VTAK Hondurs?
Post by: Robb on October 10, 2010, 12:35:29 PM
No, they aren't. Its an inferior design to the honda, since the cam lobes themselves don't have designated oil supply from oil bleeding off the rockers. They rely on splash from the oil returns in the head, despite the dry sump.
I recogzine the fact that spiker's engine isn't typical, and he is welcome to his opinion as I am mine. I'm simply stating a perspective, not throwing in lab results.
Post by: snm95ls on October 10, 2010, 01:09:32 PM
Twas an honest question with no other motive than to explore the differences between the engines.
So they do no use a roller follower?
Post by: bigdaddyvtec on October 10, 2010, 01:47:28 PM
SIr:  I dont give a shit how something performs in 90 percent  of what its in when my shit is in the other 10.
FUCKYOU
Post by: jabberwock on October 10, 2010, 03:33:37 PM
I wonder.. are OEM Porsche valvetrain parts perhaps hardened for use with modern lower zinc oils?
Diesel oils... million mile engines with slopped out clearances and heavy reciprocating masses, ignition system?  Detonation.  Skeet in your mini wheats.
Post by: turbohf on October 11, 2010, 03:08:44 AM
pics of fucked up cam/rockers tomorrow?......  :'(
Post by: bigdaddyvtec on October 11, 2010, 06:02:42 AM
None. But Its not a terribly unique situation and pics arent hard to come by. Exhaust rocklers (esp VTAK) were HAMMERED with Troughs worn into them BAD on the VTEC lobed... Cams themseloves were fucked too, but the rockers were the most visibly impacted component.
Intakes were a lil messed uup, but nowhere NEAR like the EX.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb376%2F98vtec%2FDSC05246.jpg&hash=ceb392814a2aff71481598a94ce6949fb7f6a94c)
Post by: turbohf on October 11, 2010, 12:50:53 PM
sorry, i meant ill have some pics. my VTEC lobe on exhaust #1 is chewed...  :-\
Post by: bigdaddyvtec on October 11, 2010, 01:44:41 PM
That nasty brown example is not in my motor by the way... LOL.  :mexi:
