General Category => Engine Management => Topic started by: 92CXyD on October 14, 2011, 10:16:53 AM
Looking for a source for pins at the sensor ends, other than junkyards. ;D
New preferable, or a decent easy to follow how-to reuse ones. :noel:
Free for all wiring info, reposted:
Sumitomo connectors:
http://www.sws.co.jp/en/product/connector/pdf/wp_ts.pdf
http://www.sws.co.jp/en/product/connector/pdf/wp_hw.pdf (classic 90s
Honda grey plugs)
http://www.sws.co.jp/en/product/connector/pdf/wp_hx.pdf (last entry
is OBD2 distributor plug)
http://www.sws.co.jp/en/product/connector/pdf/wp_91.pdf
http://www.sws.co.jp/en/product/connector/pdf/wp_dl.pdf
http://www.sws.co.jp/en/product/connector/pdf/wp_sl.pdf
http://www.sws.co.jp/en/product/connector/pdf/hf_hfc.pdf
www.onlinecomponents.com (and others) have an interesting supply of connectors of various manufacture... of note:
AMP/Tyco 1-178405-6 (2JZ Supra ECU plug.... actual ECU plug soldered to board, NOT harness side connectors)
OBD1 Honda plugs:
* 26 pin Ecu connector - 174516-6
* 22 pin Ecu connector - 174515-6
* 16 pin Ecu connector - 174514-6
* Large Ecu pins - 173631-1
* Small Ecu pins - 175061-1
Color codes for the above TycoAMP part numbers (not all available, buuuut)
ECU plug housing connectors:
-0
-1 white
-2
-3
-4
-5 blue
-6 grey
-7 yellow
-8
-9
Thanks JD, hope ya add this to your useful thread index. :noel:
Fuck yeah!!!
