		General Category => General Discussion => Topic started by: crxvtec91 on October 31, 2011, 11:57:33 AM
				Anyone used this stuff before?
				I probably used it w/o knowing, last place I worked we set up a few vertical lathes & boring machines from the cnc retrofit to install. The bases used special cements.
I presume you mean to fill an engine water jacket with it?
				I'd just as soon use Devcon on an aluminum block, but have to actual experience with any of it beyond Devcon in my one engine.
From all the reading I done it seems as if it puts devcon to shame. Thinking anything will help to keep the motor from scattering all over the dyno/ 1320 :evil:
				Meh, give it a year and see what the consensus is.  I remember Mase/Evans saying stock block 650whp was okay, and PLEASE keep in mind Evan's dyno reads 30% higher than everything else in North America.
Except Bisi's, of course.
I still have a feeling that under 35psi we will hit 500hp, then there is the 120shot that might kill it :evil:
This is why I plan to tow my crx with the 4dr come next dyno day. ;DDD
				Anyone else used this stuff?
