General Category => General Discussion => Topic started by: HiProfile on December 28, 2011, 11:37:47 AM
Title: Santa came late this year...
Post by: HiProfile on December 28, 2011, 11:37:47 AM
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg842.imageshack.us%2Fimg842%2F848%2Fev1402.jpg&hash=73f46f6402ebd2dbeaf12508b3185b216d5e501e)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg163.imageshack.us%2Fimg163%2F4203%2Fev1401.jpg&hash=4b75c8b329f8380976e164bd130f22ab1ce0fec5)
Title: Re: Santa came late this year...
Post by: 92CXyD on December 28, 2011, 12:38:05 PM
LOL, nice can ya send some super cheap?  :noel:
Post by: Teg2boo on December 28, 2011, 12:44:53 PM
You plan to decap and resell I guess?
How many do you have in that bag? From the picture I estimate about 100  O0
Post by: malichite on December 28, 2011, 12:46:13 PM
NOG price on a set?
Post by: HiProfile on December 28, 2011, 01:21:14 PM
88 total. I plan to decap then flowmatch them like ID does. I just bought a fuel lap FPR and marren damper for my test rig. The only prob is they won't fit Hondas until I turn down the inlet, then they'll fit just like stock. I have a couple uscar-to-obd1 adapters, so they will be plug and play on Hondas. I'll definitely be running these on all my personal cars.
For price I'd have to consult with Sewell, we're going to be running a racket. Definitely cheaper than any other cleaned/matched high-flow saturated injectors.
Post by: chris on December 28, 2011, 01:25:02 PM
good work sir
Post by: malichite on December 28, 2011, 01:28:40 PM
What is the planed flow of these bitches?
Post by: 92CXyD on December 28, 2011, 01:56:44 PM
Super nog prices for the ogs?  :noel:
Post by: crxvtec91 on December 28, 2011, 02:56:22 PM
How much will they flow?
Post by: malichite on December 28, 2011, 02:58:34 PM
Post by: crttaz on December 28, 2011, 04:26:42 PM
Post by: HiProfile on December 28, 2011, 04:46:39 PM
The only one I tested so far flowed 705cc, but at cold temps so they may flow more. As-is they'd be ID800's if ID was to name them.
In other words, enough for 400whp at ~85% or so. Regardless you can do the math at RC's website.
Post by: 92CXyD on December 28, 2011, 04:52:01 PM
ID800?
I was hoping closer ID1000 or higher.  :noel:
Any possibility of any higher flowing ones?
Post by: malichite on December 28, 2011, 04:53:28 PM
In for Noggle price!
Post by: theidealone on December 28, 2011, 04:55:06 PM
Id be interested in a set. Itd be nice if someone could reproduce the 2000s.
Post by: tekno on December 28, 2011, 06:18:50 PM
I want a set. They going to be cheaper than racetronix? ???
Post by: ratcityrex on December 28, 2011, 07:11:51 PM
Post by: chris on December 28, 2011, 08:16:15 PM
even cheaper than oczc
Post by: HiProfile on December 28, 2011, 10:22:22 PM
Here's the thing, I saw someone selling modded crown vic injectors, which are the same or smaller. They flowed 840cc, so I'm just hoping the 20* temps affected my bench drastically.
In any case, once I get Tom his injector controller, he'll be able to get you noglets "ID1000" size injectors. Probably bigger, too.
If you mean their $49 Siemens 80lb'ers, they'll be cheaper and spray better. Just keep in mind I'm going to be turning down 88 injectors, cutting off 88 restrictor caps, then flow matching 88 injectors at 3 different duty cycles. Price will be determined, mainly because I don't want to bend you nogs over a barrel, nor do I want to work for free. :P
Post by: ratcityrex on December 28, 2011, 10:42:35 PM
Sweet!! Keep a nigga updated!!
Post by: HiProfile on December 28, 2011, 10:56:08 PM
I forgot to mention I turned down some Denso and Bosch injectors I plan on running in my DD. My grampa's lathe works well so far. So the machining side of things will be fine once I get the lathe a live center.
Post by: theidealone on December 28, 2011, 10:56:52 PM
Ill be in for a set. And if Sewell can make something close to 2000cc, Ill be in for a set of those as well.
Post by: turbohf on December 28, 2011, 11:10:21 PM
i dont see the problem there?
better question is: will they fit the green 1991 Galant VR4 parked in my driveway?  :noel: :Jew:  if i bought some i would be lookin for 550+whp E85 injectors... (already have 450/560/680cc injectors for it)
Post by: HiProfile on December 30, 2011, 12:08:41 AM
They should fit a VR4, but you may have to shim the fuel rail. They will be 48mm from rail to seal, DSM's are ~43mm.
Denso 24lb'ers before:
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fspeedlab.saleen.com%2Fstore%2FVendor1%2F246%2FTake_off_Injectors_246.JPG&hash=11a50ede9571bfaf146aa00b61104b324a30347b)
After:
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg254.imageshack.us%2Fimg254%2F1871%2Fdensopurple24lb.jpg&hash=f1e25b460188495ec02fd715a9fe90b82df75ea7)
I always wanted a purple injector. ;DDD
Post by: Joseph Davis on December 30, 2011, 02:52:14 AM
If you are still using mineral spirits I'm pretty sure that that flow number is low.  If those are the 040 core it's a nominal 820cc at 43.5 psi.
Post by: slappynuts on December 30, 2011, 04:28:29 AM
If you really want to know send them to me,we have an actual flow bench. I just got done decaping 100 injectors on the lathe and then flowing/matching them.
Post by: d112crzy on December 30, 2011, 04:39:20 AM
FUCK YOU!
I want a set!
No chance of getting high-tech and matching them according to dead times, amirite?
Post by: HiProfile on December 30, 2011, 09:58:29 AM
I just said I'd be matching all 88. I won't be going as crazy as ID has, but just ask Tom about how extensive they test them currently. You'd be surprised.
Post by: crxvtec91 on January 03, 2012, 10:43:11 AM
Update?
Post by: HiProfile on January 03, 2012, 11:51:02 AM
We're thinking $449/set for Tom's larger injectors, $425 for mine. :evil:
The price will probably be HALF that or less for 4.
Post by: 92CXyD on January 03, 2012, 11:57:10 AM
So about for $225/4 for Tom's large injectors?
How large is large?
What batt offsets would be used for these?
When will they be available?
Post by: sewell94 on January 03, 2012, 12:39:38 PM
FUCK YOU!
I want a set!
How do you think they "Match" the dead times?? Its not that high tech, lol.  Marketing :)
Post by: HiProfile on January 03, 2012, 12:46:18 PM
We're still unable to accurately test flow. Tom and I are kinda working together but independently. His should be the same as ID1000's, so ~880cc. Mine should be ~725cc. A member here has offered to test some on an ASNU bench.
Batt offsets will basically match ID and FIC's numbers since they're virtually the same cores. Not exactly, but very close. The injector controller I'm building will let us flow with deadtime figured in, so it can be tested "dynamically". Had to get at least one buzzword in there. Tom told me they don't even check deadtime anymore, they just flow/match them dynamically. Marketing is right.
Russ, you'd have to PM Tom about price. I know Tom was going to include top hat extenders. I will say you're near the ballpark.
Post by: Joseph Davis on January 03, 2012, 12:49:33 PM
Highway robbery without a sweet sticker
Post by: HiProfile on January 03, 2012, 01:00:34 PM
In that case I'll someone drop-ship this if anyone complains:
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fwww.707decals.com%2Fproduct_images%2Fj%2F217%2Ffuck_you_heart__48417_zoom.png&hash=60efe079527fa9bed570a4a946d45375a20bde77)
Post by: Joseph Davis on January 03, 2012, 01:14:23 PM
I can make that a reality.
Post by: sewell94 on January 03, 2012, 01:31:16 PM
I didnt say that they dont match deadtimes.  The amount of data points is smaller now, ie from 10 to 3.
Simplified spoon feeding comming up.....
Basically if you match an injector at full flow, and then match and injector at 2 more points, say 3ms and 7ms. They will be matched by deadtime.  There really only is 2 variables in how much fuel an injector will flow when pulsed , how much they flow and how long it takes for them to open and close, ie latency/dead time/ blah blah.  If the injectors all flow the same at full flow, that means the injectors flow the same so your down to the other variable, latency.  There is some other stuff(like high and low slope on the new ford ecus, etc etc) but for old honda ecus this is the basics of it.
Post by: tekno on January 03, 2012, 02:16:46 PM
hurry up and sell me a set  ;)
Post by: 1991civicsi on January 03, 2012, 02:31:53 PM
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi28.photobucket.com%2Falbums%2Fc224%2Ffrankrizzophotos%2FIMAG0192.jpg&hash=4f4f87ed22c4f7498803a87f14768a30d958945d)
My late Christmas gift.
Post by: jabberwock on January 03, 2012, 02:41:04 PM
If (set == 8 )
  iBuy();
else
  fuckYou();
half price for half the product oh yeah!
Post by: malichite on January 03, 2012, 02:49:13 PM
If (set == 8 )
  iBuy();
else
  fuckYou();
x2
Post by: theidealone on January 03, 2012, 03:08:47 PM
Whats the possibility you guys could do 1600-2000cc injectors??? Im gonna need a set for the hatch. I think its time to start putting this hoe back together.
Post by: HiProfile on January 03, 2012, 05:04:53 PM
I'm going to try pressing the plunger into the armature like some other companies do. It should increase flow a lot, but I don't have much hope for it tho.
The chance of making it possible means you have to do this very precisely and/or in large batches. I don't have a supplier let alone the money to invest in a pallet of injectors.
Post by: Joseph Davis on January 03, 2012, 07:50:35 PM
High and low slope is just a method of dealing with alinearity as injector pulsewidth decreases.  Set the high slope to match injector flow, and breakpoint/low slope is a quick and easy trial and error, but low slope is always a little higher than actual flow.
