General Category => Engine Management => Topic started by: walter on April 26, 2012, 05:49:56 PM
Hi, i think i could be have problems with ground loops, i fried 2 ecus already , i dont know how but after works good, get CEL. tried a stock ecu and not cel and looks ok, i will chip it but i dont want to damage this other one....
What code is it throwing a cel for?
it's solid Cel once key is on, as a fried ecu.. not datalogging working of course.. relay is going crazy , i was thinking about wiring (stock) but once i plugged oem ecu everything sounds good... it's a EF OBD0 to OBD1.
U swap distributer wiring around? Do u have another obd1 Ecu to plug in and try?
nm.. cannot read
Do you have an Ostrich? If so, try with a chip to see if you still have the problem.
Yes, right now im runing with D16z6 OBD1, i made my own distributor wiring harness, i think that's not the problem because as i said , tested with stock obd1 ecu and not cel...
Yes, i do, i will burn a chip and test it again. i will let you know. thanks!.
