General Category => Fabrication => Topic started by: NoPistons! on June 08, 2012, 06:55:16 PM
Title: Oil pans?
Post by: NoPistons! on June 08, 2012, 06:55:16 PM
Working on one now.  Gigantic pain in the ass.  Again, nothing but a flux core, drill and angle grinder to aid my mission.  :mexi: :mexi: O0 O0  I hate spinning rod bearings and wanted to make life harder...... ::)
Anyone done/doing the same cranking up the nog?
Title: Re: Oil pans?
Post by: DasPoop on June 09, 2012, 03:19:39 PM
I was at the yard today to pick out my vg30 and it looks like the pathfinder pan will fit the subframe no problem it has a deep rear sump that might get a kickout.
the thing with pans to to keep them clean when fcing and to grind like hell to spot pin holes pin holes get sealed with silicone or boat epoxy
Post by: NoPistons! on June 11, 2012, 05:18:15 AM
Yeah.  After running a few beads i was like "i'm going to have to grind these welds down.  Fucking flux core."
I'll fill it with water first and put it on some cardboard to see if it leaks but will seal it up with black rtv anyway.  Thanks for the tippers.   I have a rear and front sump pan so i figured if i fuck one up i have another to dick around with.  Vg30ftmfw!  :noel:
Post by: patsmx5 on June 24, 2012, 02:52:13 AM
Get a few spot welds or whatever till it's at least not going to fall off. Clean the shit out of it. JB weld all around the oustide, rub the shit into the cracks. Done, it will NEVER leak.
Post by: HiProfile on June 29, 2012, 11:55:12 AM
Sometime in July I'm going to try brazing new threads onto a honda pan, since they strip if you look at them wrong. It's the bernzomatic kit that comes with everything for $60, although I paid much less. I figure if jb weld can hold, brazing will be no prob. JB weld just looks like ass, but usually nobody will ever see it.
Post by: NoPistons! on August 20, 2012, 11:43:58 AM
Jb weld is plenty strong for alot of shit.  I'm a believer.    Thanks.   It doesn't have to be pretty, just do the mundane job of holding oil.
Post by: NoPistons! on August 28, 2012, 08:47:45 PM
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi1236.photobucket.com%2Falbums%2Fff457%2Fpotatoesbarnaby%2Foilpan1.jpg&hash=236f173443ee37f6ee71137b374742aefcdc17eb)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi1236.photobucket.com%2Falbums%2Fff457%2Fpotatoesbarnaby%2Foilpan2.jpg&hash=072dfef3ff690b5a294a184e63ee0b0a91f954d4)
Probably never doing this again with a mig.  Ever.  Fuck that.....  *edit: would just buy the now existing swap kit pan, something from moroso, pay someone else, etc....  This shit sucks.  Nothing has been enjoyable about it..... Floor n doors aren't burned in yet. Haven't thought of turbo oil drain.  I may just cut my rear sump (xtralongz) pickup tube apart just for turbo oil drain so i can clamp maybe 2-3" of hose from the pan to hardline.   Buddy needed my oil kit.  I'm improvising....  Anyway....
Pickup tube 1" cut out and rewelded back up.  Filter basket was told to gtfo after slag and crap fell into the tube and wasn't coming out any other way....
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi1236.photobucket.com%2Falbums%2Fff457%2Fpotatoesbarnaby%2Fpickuptubemod1.jpg&hash=0c8e818628199bc2721267d8d94a7760883ba096)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi1236.photobucket.com%2Falbums%2Fff457%2Fpotatoesbarnaby%2Fpickuptubemod2.jpg&hash=3f1f0d76a2f226352caa39cbbe3594fe023bce5f)
Tip:  When re-loading your mig, DO NOT EVER do it pissed, hot and bothered.   Stabbed about halfway through my thumb into the joint with wire.  Feels fantastic right now.   I bled for you faggots.....
Post by: HiProfile on August 29, 2012, 10:35:40 PM
Maybe I should have mentioned before this - brazing does not melt the pan's metal, nor the sheet metal of the new sump.
The other part is how it seals holes. When I MIG'd my fuel rail, I recall the small parts & welds loved to develop holes. 2/3 my time was finding and fixing leaks.
Post by: DasPoop on August 29, 2012, 10:42:29 PM
why did you paint your pickup tube  ??? Are you afraid its going to rust?
Post by: NoPistons! on August 30, 2012, 05:14:21 PM
Sitting outside, fuck yeah.  Southeast humidity is no joke.....  I left a brand new turbo in my basement for 3 months, brought it up today and casting is flashed all over it.  It's not climate controlled.  Damp enough to where crickets blanket the damn walls getting their hydration on all day......
Hiprofile, i'll have to go the jb weld route at this point to make sure i'm sealed up but i'm confident that if the pan does take a hard hit it will buckle instead of bust and piss all over the place.    Different strokes though.  I simply had an idea and ran with it.  Skin it however you want.
Post by: HiProfile on August 30, 2012, 07:19:03 PM
Get some CRC SP-350 or SP-400, even WD-40 will work.
I feel ya with already-fucked problem, I know that feeling. I recall a HF manifold someone had a flange brazed onto it that took a lot of abuse. COnsidering the manifold would get dull read, it did very well. I know if I had a TIG I wouldn't bother with brazing.
Post by: rawr on August 30, 2012, 10:17:30 PM
brazing is really strong, can be done on thinner material than welding can and is a clean process.
The only reason it is not that common is it takes more time and energy to do.
Post by: stealthiskey on August 31, 2012, 08:43:07 AM
brazing is a pita, and that 60$ comes with oxy acetylene 1lb bottles right?  The replacement o2 bottles arre like $10 a pop and you will go through them like crazy, uses 16x as much o2 as acetylene.  Totally not worth it unless you get a bigger refillable o2 tank.
Flux core is great. Get yourself one of these for grinding the welds.  http://www.homedepot.com/h_d1/N-5yc1v/R-202830904/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=flap+wheel&storeId=10051#.UECweKCQlc4 (http://www.homedepot.com/h_d1/N-5yc1v/R-202830904/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=flap+wheel&storeId=10051#.UECweKCQlc4)
It's flexible unlike a regular grinding disc so it conforms to the surface you're trying to smooth up.  Also removes steel just as fast as ordinary grinding wheel.    Weld around it, doesnt have to be perfect, -> grind the shitty spots down  -> weld again > grind > weld >grind etc
Post by: 92CXyD on August 31, 2012, 10:09:01 AM
Good info., I may havr to give some of this a try over the winter.  :noel:
Post by: Phate on September 01, 2012, 11:22:53 AM
We use these in the shop at school, they're great.
Post by: crxvtec91 on September 06, 2012, 09:20:12 AM
Well done, man up and go weld something else up!
Post by: JaredKaragen on September 06, 2012, 10:12:40 PM
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi26.photobucket.com%2Falbums%2Fc115%2FJaredKaragen%2Fphoto-1477.png&hash=304e3acb9b5049c0e3767133b87e89dfc23ec195)
This is how much I stand behind brazing.  Been whoring out this custom fitting for banjo'd oil feed turbos for many years.  Has yet to be a problem.  Was a SS barb and brass auto meter copper hose fitting.
Post by: HiProfile on September 07, 2012, 12:32:20 AM
If you go that far, I'd suggest getting SS nuts - drill & braze a 1/8" union to the side of them. With crush washers they seal great. I have one on a honda fuel filter in place of the banjo fitting to convert from banjo to NPT.
Post by: NoPistons! on September 08, 2012, 07:00:03 PM
@crxvtak9juan:   Been welding like a motherfucker on shit.  There's more to be done.  I'll either post in this section or in my build thread.  Patience brother.   :noel:
I've heard that brazing is very comparable in strength to a weld.  For sure wanna check out some flap disks.  Overdue for a trip to both the junkyard, harbor frieght and lowes/home depot.   Sometime in october.  WIll try to get some work done on this pan during the week.  I also have to extend my steering shaft on the same car.  Whatever i feel like starting on after i wake up and have my coffee.
I would have rather brazed the fittings i used on an fmu one time than jb weld.  The jbweld held up tho!  (https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi26.photobucket.com%2Falbums%2Fc115%2FJaredKaragen%2Fphoto-1477.png&hash=304e3acb9b5049c0e3767133b87e89dfc23ec195)  Anyone hates on that and i will personally punch them in the jeans.  Hell fucking yeah!
Post by: JaredKaragen on September 08, 2012, 08:34:32 PM
As soon a I install my greddy oil line, that exact fitting will be for sale :) lol. Nothing like an auto meter gauge tube for a feed line :)
But if the pieces are hot enough, the braze takes well and is strong as hell!
Post by: NoPistons! on September 09, 2012, 05:09:01 PM
Shit so i take it in order to have a good bond you need to pre-heat both peices much like you would arc welding cast stuff?
Post by: JaredKaragen on September 11, 2012, 12:25:21 AM
Not exactly, but that would give the best results.
It's more like (actually exactly the same as) soldering.  Heat is needed for the flux (glass in this case) and brazing material to bond to the surface.
Post by: NoPistons! on September 17, 2012, 12:51:31 PM
Glass?   Would be a fair bet to say tacking the walls to the sump and stitching using a welder and then sealing the seams up with brazing would be an excellent way in the future to tackle a job like this?  I'm too far gone to re-do it but if this one eats it hard and busts open you know what it is.  I appreciate the insight no doubt!
Post by: JaredKaragen on September 17, 2012, 02:22:47 PM
ya, the stuff that ends up on it after flux and braze is more like glass than all else....   i believe the old can of flux we used was a soda ash/silica type.
very ancient stuff we used.  his dad left him a wealth of old skool goodies.
Post by: NoPistons! on September 18, 2012, 05:06:12 AM
My dad fucked my mom.  counts for something, right?
Post by: JaredKaragen on September 19, 2012, 10:54:21 AM
hopefully for you, if not the mailman =)
Post by: HiProfile on September 20, 2012, 11:29:26 PM
Brazing usually needs a gap comparable to what a TIG needs. However I've seen people build up material when brazing that makes some of our flux-cored birdshit welds look downright professional.
The smaller the gap, the easier it flows and the stronger it holds. In your case it will mostly do sealing duty, and partly hold it together.
Post by: NoPistons! on September 23, 2012, 09:06:55 PM
Goddamn i miss tig welding.  =(
 Going the low buck as fuck jb weld route because i still have stuff i need to order for my build tomorrow morning. I'm pushing pretty hard to turn the motor over in a few weeks...not months thank fucking god finally and see if i can take it around the block.  Decisions were made, corners were cut.  This is RHMT and the low standards just seem to work out for the best more often than not.
Yeah.  I'm glad to be alive for the most part.    Aside from the typical oil drain line...anyone else care to show off their pans?  I made the thread so we could see other peoples shit.  Not just mine....unless you are too super secret street racer to post up?
Post by: 92CXyD on September 24, 2012, 12:19:53 AM
From my build thread, nothing labor intensive as yours, but that is how mine looks
Chose to have the return come in above the baffle and in between reinforcement ribs of the pan.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi653.photobucket.com%2Falbums%2Fuu254%2F92CXyD%2FIMG227.jpg%3Ft%3D1333368992&hash=0dcfd25bf3b86db3707dc8e88c0690631cd9078c)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi653.photobucket.com%2Falbums%2Fuu254%2F92CXyD%2FIMG228.jpg%3Ft%3D1333368995&hash=25ca03a0b286fca527773de265650015913a637f)
I was looking for an aluminum 1/2" or larger tube for the return.
Then I remembered the line to the old a/c condenser I have laying around.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi653.photobucket.com%2Falbums%2Fuu254%2F92CXyD%2FIMG232.jpg%3Ft%3D1333369004&hash=12495df7a6034b4a2860a1c75615a6afbdf292bd)
Positioned the line pointing to center and up, while making sure it is in no position to make it hard to tighten the oil pan to block fasteners.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi653.photobucket.com%2Falbums%2Fuu254%2F92CXyD%2FIMG230.jpg%3Ft%3D1333368995&hash=03a8e23e116fd22b343307195a9bec3e41848b64)
Post by: JaredKaragen on September 25, 2012, 03:04:39 AM
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi26.photobucket.com%2Falbums%2Fc115%2FJaredKaragen%2FIMG_0837-1.jpg&hash=9ad90f94de1906ea310f51d63d6837f2ca4dd3ba)
cheap wirefeed: leaked.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi26.photobucket.com%2Falbums%2Fc115%2FJaredKaragen%2FIMG_1511-1.jpg&hash=49184fe3ba928a108b7b58e302a0b150bb3d065d)
waterwelded after wirefeed: seeps.
Post by: NoPistons! on September 28, 2012, 07:39:28 PM
But did you try jb weld fucker?!
Did some work yesterday.  Put pandora on the laptop, plugged my portable speakers in and just kept going til i had nothing left.   Bout 90 percent.  Just gotta seal the damn thing, weld this oil drain thingy shit on after i figure out where i want to cut the rest of the tube.  Going to run a bead....or birdshit....however the machine wants to do it around the lip of it so a clamp will actually seal without the hose blowing off.   You're going to love the oil return flange i'm working on for the turbo.  Cut the flange, just haven't cut and welded the tube yet....
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi1236.photobucket.com%2Falbums%2Fff457%2Fpotatoesbarnaby%2Foilpan7.jpg&hash=cc51d78673c50d6027191f324bafce0664594fb5)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi1236.photobucket.com%2Falbums%2Fff457%2Fpotatoesbarnaby%2Foilpan6.jpg&hash=398fec7b538c74138eebb81031bb0f6aeeb083e3)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi1236.photobucket.com%2Falbums%2Fff457%2Fpotatoesbarnaby%2Foilpan5.jpg&hash=09d6fa3877f0038410815c6f2d00eaff6a4b3828)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi1236.photobucket.com%2Falbums%2Fff457%2Fpotatoesbarnaby%2Foilpan4.jpg&hash=bf945daddbe4c9f6544100b9f8575e62f07edd2f)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi1236.photobucket.com%2Falbums%2Fff457%2Fpotatoesbarnaby%2Foilpan3.jpg&hash=d9100040c8c0b2533f7836089f3c5c427443eb17)
This was labor intensive as fuck.  I hate i spent as much time as i did on it....      I burned through so much.  Tried to keep most of the heat on the thicker plate and just washed it onto the thin pan metal and did ok.
Post by: NoPistons! on October 01, 2012, 11:19:06 AM
I should add that if you bend 90* tabs you can overlap/interlock every single plate to make the thing bulletproof, bead the outside, no risk of burn through, zero worries of stray slag boogers from a flux core in hard to reach spots......
  Brazing would be awesome for the inside plates.
You tig having ass sheet metal brake having ass motherfuckers have it balls easy.  You lazy people can just pay for moroso or an accusump....
