General Category => Hybrid/Tech => Topic started by: Tim on June 24, 2012, 06:19:43 PM
Now that my integra is on the road I think its time I drag my camaro out of the barn.
Right now it has a 400 with a holley 4150 on top and a 700r4 trans.
But there's a van for sale with a 5.3 I think I could pick the entire thing up fairly cheap and part out anything I don't use.
Thoughts?
Some year I may want to boost it, that's why I'm thinkig the fuel injected ls would be a good idea.
I just missed a 6.0 bit it was just a long block so it would have needed a ton of buckle and dime shit to swap.
Gne III+ and don't look back.
;DDD
I have what is basically a new 355 for my current truck project, and I don't really even want to use it. No budget, so I will most likely use it.
Snag the van for sure. Parts vehicle is the best way to go about the swap IMO.
LS motor hands down.
Ford FE boat anchor :noel:
I was too slow, its gone.
Probably drag this out of the barn soon anyway. It needs to run again.
i would just consider a decent rotating assembly cam and heads for your 400. to make 500-600hp is not a whole lot of work. i see WISSOTA which is a restricted dirt latemodel with spec heads make 600 no prob. stock block. there nothing to write home about just decent parts.
