General Category => General Discussion => Topic started by: highroller54 on June 25, 2012, 11:59:30 PM
Title: Any of you cock lovers had a valve adjuster that wont stay tight?
Post by: highroller54 on June 25, 2012, 11:59:30 PM
God dam thing comes loose with some hot a sweaty rev limiter action. One intake valve on my ls, thought maybe I didnt get it tight enough when I did a adjustment but I just reset it and its getting loose again in 20 minutes.  :mexi:
Title: Re: Any of you cock lovers had a valve adjuster that wont stay tight?
Post by: snm95ls on June 26, 2012, 12:33:35 AM
LS valve train is fail.
Luckily parts are dirt cheap or free.
 ;DDD
Post by: turbohf on June 26, 2012, 12:38:07 AM
tack weld that negro in place...  ::)  O0 :Jew:
Post by: highroller54 on June 26, 2012, 12:45:33 AM
I have parts, swap rocker and retry?
Post by: snm95ls on June 26, 2012, 12:52:10 AM
That's what I would do assuming you aren't wiping out a lobe.
Post by: jdmhatchracer94 on June 26, 2012, 01:42:40 AM
Either way fucker will run. Should have heard mine at the dyno day thought there was a diesel in it.
Short answer locktite. Not the heavy shit just the medium had to do that to my old ls worked fine.
Post by: Teg2boo on June 26, 2012, 09:29:22 AM
Never had problem with any of my 4 LS motors. I would go with locktite too.
Post by: highroller54 on June 26, 2012, 10:01:58 AM
what are you reving it to? I have fuel cunt at 7200, I'm going to swap the ball stud and rocker as per The grand wizards advice and retry.
Post by: jdmhatchracer94 on June 26, 2012, 10:13:13 AM
Mine revs 8500. No prob
Post by: 92CXyD on June 26, 2012, 10:21:57 AM
+1 on this, and not because the GW says so, but from experience.  :noel:
Post by: Teg2boo on June 26, 2012, 12:31:51 PM
The cut off was at 7500, but I'm not the kind that hit the cut off just for fun so I would say between 7000 and 7300.
Post by: highroller54 on June 26, 2012, 11:20:37 PM
swaped that shit out, so far so good and it just went through more limiter action then any car should have to put up with lol, all the old parts look mint though. Who knows.
