General Category => Hybrid/Tech => Topic started by: buk9tp on May 20, 2009, 06:33:07 PM
Title: quick question bout dsm 450 install
Post by: buk9tp on May 20, 2009, 06:33:07 PM
do the dsm o rings fit into the honda intake manifold???
Title: Re: quick question bout dsm 450 install
Post by: buk9tp on May 20, 2009, 06:55:54 PM
i don't know if they fit, but the dsm injectors do fit into the stock honda o rings
they fit in the stock o rings but id have to force them into the fucking car...
which doesnt seem like a smart thing to do
Post by: buk9tp on May 20, 2009, 07:13:30 PM
you take a drum sanding attachment for a dremel and sand out the inside of the o ring a little. they will fit great after that.
nice... im so retarded...
whats your aim faggot
Post by: Teg2boo on May 20, 2009, 08:31:01 PM
Haha Buk can't install dsm 450  :P
Post by: onlyflash944 on May 20, 2009, 08:46:22 PM
remember the i can't get the axle nut off episode?
Post by: 89hatchsir on May 20, 2009, 09:27:16 PM
Don't take out too much material when sanding the o-rings. It will cause a vacuum leak. Just jam them in and tighten them down with the fuel rail. It works good.
Post by: buk9tp on May 21, 2009, 12:09:20 PM
ok so i got them in and maybe put 50 miles on them then driving this morning the car started dumping fuel like crazy...
could the resistor box have taken a shit?
Post by: onlyflash944 on May 21, 2009, 04:11:14 PM
i doubt you messed up one of the resistors.  probably wiring or the injector is stuck would be my guess
