General Category => Engine Management => Topic started by: shogun on June 10, 2009, 08:05:54 PM
hey, im trying to plug my widband to the ecu so ectune can read afr, but i cant seem to find a pinout diagram, thank you for your help
same as a P28, or anyother OBD1 ECU....
D14
D14
Usually its a thicker wire than the rest and it's WHITE at pin as stated in the quote.
I like using D12 better.
any reason why?
thanks, it doesnt change even if it is a jdm car, its a 95 sir
any reason why?
Already has a pull down resistor and filter cap, signal is smoother. Notice EGR lift/ELD/etc don't float high without a signal run to them.
found the diagram, thanks jd for the tip d14 it is
will free log see d12?
