General Category => Engine Management => Topic started by: kamilk69 on July 13, 2009, 09:06:47 PM
anyone good with megasquirt, im trying to get it to run in my focus. so far i got the injectors to pulse, iat working and coolant temp to work. but now the fucking car work produce a spark.
my setup uses a vr sensor and edis-4, ive switched my polarity and vr sensor and i still get fuck all.
the way i have it set up,
vr sensor - edis with 2 wire sheilded. then edis produce a base timing without any help from megasquirt and fire the coil but still nothing.
what version of MS is it???
IIRC the EDIS unit should spark without even being hooked up to the MS. When i tested mine, i just benched the edis unit with the VR sensor. Try switching the VR wires, its a common mistake. It should spark regardless of MS, it will just run at base EDIS timing with I think is 10 deg. double check your wiring something is up.
Also, a heads up, put the capacitor on the coil and run a stereo voltage filter on the power wire going to the MS. I found it cleaned up all sorts of fuckery.
Do you get an RPM reading in megatune?
