General Category => Fabrication => Topic started by: toyolla86 on August 27, 2009, 02:40:58 PM
Title: when building a twin scroll......??
Post by: toyolla86 on August 27, 2009, 02:40:58 PM
so ive been reading some stuff saying that when you build a twin scroll you need to pair the runners.
how important is this.
say i wanted to build a log manifold, would that be totally stupid on a twin scroll turbo.
you typically want 1-3 and 2-4 together right.
Title: Re: when building a twin scroll......??
Post by: toyolla86 on August 27, 2009, 02:48:26 PM
maybe ill eliminate the twin scroll. and run it like a single scroll.
Post by: turbob16hatch on August 27, 2009, 05:40:42 PM
yeah the point of running divided is to increase the pressure on the turbine wheel by separating the exhaust pulses. running a log is not separating pulses.
Post by: BRIAN MP5T on August 27, 2009, 05:54:14 PM
The Twin is normally used with a tube style equal length manifold.
If you don't use a Tube mani, it's defeating the point of the housing.
Post by: ratcityrex on August 27, 2009, 06:02:07 PM
But you dont need to have a twin scroll to run a twin scroll. Look at joes (d16y8-z6) holset on his log that hes running mid 10's in on his civic.
Post by: turbob16hatch on August 27, 2009, 06:03:39 PM
yeah but what would the gains be if he did it correctly?
Post by: ratcityrex on August 27, 2009, 06:08:34 PM
I would imagin faster spool time. But this dude is talking about running his twin on a log, so just slap it on.
Post by: klyph on August 27, 2009, 06:15:40 PM
 I thought SPLOG stood for split pulse log...
Post by: ratcityrex on August 27, 2009, 06:18:00 PM
I thought it stood for split log.
Post by: ratcityrex on August 27, 2009, 06:53:07 PM
log
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Flsdmotorsports.com%2Fpictures%2FturboManifold_log.jpg&hash=6d5de955c29a3c71d21a35ec2d4f208cb8a3f61a)
Splog
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Ft3.gstatic.com%2Fimages%3Fq%3Dtbn%3AIZhbW_KYNAm9UM%3Ahttp%3A%2F%2Fi268.photobucket.com%2Falbums%2Fjj2%2Fkevo1586%2FDSC05121.jpg&hash=86c230eefa9e7c7df17ffcf512bd3c6bbc832874)
Post by: patsmx5 on August 27, 2009, 07:09:17 PM
I'm running a twin scroll on what's basically a cast log manifold. It works fine. Yeah, it would spool better if I had a 4:2 header for it, but this works good enough. If I had to redo it I would make a weld-ell 4:2 manifold for it.
Post by: toyolla86 on August 27, 2009, 07:49:34 PM
but technically that SPLOG isnt even correct if it is supposed to be
1 and 3
2 and 4
right?
eh i dont think it really matters that much. its all pumping exhaust. hahah.
it would really only make a huge difference if when it hits a certain rpm a second scroll opened up like
that old thread was talking about on ohmt. where it had a flapper that would open a whole new port to the twin scroll
Post by: ratcityrex on August 27, 2009, 08:24:21 PM
1342 is honda firing order isn't it?
Yep, at least the ones i work on.
Post by: Corey on August 28, 2009, 12:49:42 AM
no.
on a honda you pair 1+4 and 2+3 on divided housing setups.
Post by: turbob16hatch on August 28, 2009, 01:00:27 AM
no.
^^^this
Post by: toyolla86 on August 28, 2009, 02:08:14 AM
i was thinking this may be the actual way.
and i think most cars would be 1-4 and 2-3
so i am corrected.
but i will have to research for a ka24de
Post by: Corey on August 28, 2009, 02:18:53 AM
ka is the same as a honda
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi19.photobucket.com%2Falbums%2Fb152%2Fonefast240%2FMotorBuild022.jpg&hash=ca9ebcaf7720f762a5ef5e198744bbc0eab39eac)
Post by: toyolla86 on August 28, 2009, 12:36:57 PM
very well. 1and4 it is.
that obviously takes much more tubing. which we dont have. hahah. and they would definitely be unequal runners.
Post by: turbob16hatch on August 28, 2009, 01:15:57 PM
equal length is not all that important.
just order up some bends there dirt cheap $5/e
Post by: ratcityrex on August 28, 2009, 01:27:43 PM
Like said b4, unequal  length is not a huge deal. I would take setting up the runners for a split over equal length any day.
Post by: kgx on August 28, 2009, 04:09:53 PM
tell me you're using an EVO turbo and not a CT26! CT26=doorstop.
Post by: toyolla86 on August 28, 2009, 04:58:23 PM
tdo5hr
Post by: Toysrme on August 30, 2009, 05:06:54 PM
truth
Post by: toyolla86 on August 30, 2009, 08:57:57 PM
maybe that'll have to be done.
