General Category => Forced Induction => Topic started by: AJxr on September 08, 2009, 09:27:58 PM
are you mofos running an oil restrictor on your average honda engine with dsm turbo?
didnt with my t28, no smoke
didnt with my t25 smoked on decel, think it was my shitty return line b4 i changed it tho.
There seems to be a restrictor built into these things in the oil feed hole, correct if wrong??
Im pretty sure all the mitsu turbo's have a restrictor built into the oil feed
They have some minor restrictors built into the bearing, same as journal bearing Garretts. The stock oil feed line has an 1/8" restrictor built into it. Balance shaft delete (raises the oil pressure through the roof, at or over 100 psi in the higher rpms) and an unrestricted -4 AN feed line is known to cause oil smoking problem in a very small handful of cars.
I say run the thing as is, but if it smokes install a restrictor in there before you put ANY miles on it and destroy the turbo with coking, which in turn can damage your engine too.
thanks guys, starting off with no restrictor, and a -3 feed. unsure of what fitting im using to go from -3 to the CHRA.
no problems with -3AN lines and 14b's
my 16G has the restrictor right in it.
I put my restrictor in your MOM.
Wait, you mean like a 1/8" wide...penis? I hope not... :-X
That's the ID, anyway.
lol, that makes sense. ;D
I had to use one with my 14b or it would smoke. Was a tired old turbo tho.
