General Category => Fabrication => Topic started by: dvst8r on September 23, 2009, 11:46:45 AM
Well I really haven't done anything in the last forever, so last night I took 2hrs out of my busy couch sitting schedule and drank 3 beers (the beers were just MGD in a bottle, so I didn't bother taking pics) and tacked this together. If I think about it I will take some pics as I finish it up, but it will be completely tacked together and fitted this evening.
I would have done the connector pieces last night, but I don't have a chop saw at home, and don't trust myself to cut straight with an angle grinder. With any luck this will be on the dyno on Saturday in Red Deer.
As you will be able to see, I still have to square the end of the collector. It is a completely divided setup. There will be an external gate still to be added tonight.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2Fmikesmani1.jpg&hash=fea731e24e355224dbee127e060c025d7556b5cf)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2Fmikesmani2.jpg&hash=8b93c34fbb79339179b127184551d380639a9141)
What's it for?
I suppose I should have put this in the Fab section... :P
2001 Dodge.
so where are the finished pics
Finished pics will be Saturday, going to fit it tonight, and finish tacking.
Is that an SSautochrome mani cause it looks like it's gonna crack
Is that an CCFag mani cause it looks like it's gonna crack
id like to see how you expect to do those 2 inner cylinders, me thinks you wasted 2 good elbows.
That collector is just laying on the flange, that's why he said he needs a chop saw.
do work son, the tripple charged cummins better be next :evil:
It is all tacked now, but I was too lazy to find the camera, so I will take pics on Saturday when it is done.
The head will crack before a mild steel sch 40 pipe splog will.
On another note, I make horrific plasma cuts after 7 beers, I have lots of hrs on the die grinder tonight. :-[
looks good so far. in for finished pics!
very nice, i like
Well tonight it was whiskey and some ginger ale.
All tacked sitting on a 12v head.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2FMikesMani4.jpg&hash=02b86b252160b62dec0862caa7f0a5c93ffecda8)
Same thing different shot. Can you spot the three holsets in the box? Bonus points if you can tell me which each one is.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2FMikesMani5.jpg&hash=98e34f7fde5384a8b3c2ec18f7618581d2eb38d6)
Flange broken off for finish welding (poor order of operations lead to some fun putting it back together, what can I say I'm kinda rusty.)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2FMikesMani6.jpg&hash=f7b7e6089f6202e2cdc21ed6238965f42930ee11)
Manifold with Flange broken off, awaiting finish welding.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2FMikesMani7.jpg&hash=368310c83f8502475b65e4ba572f58e1ba041a85)
All welded sitting in front of a 72mm, and a 74mm turbo. Yes I collect turbo's
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2FMikesMani8.jpg&hash=48eb674e9e34397b1360c1c8985886e12729714f)
Couple more shots of the same thing.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2FMikesMani9.jpg&hash=a85323da227636841064c4d1c34a56988c4002cf)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2FMikesMani10.jpg&hash=45b0f264b7230cc8e339ab0e3df4e9c5f14cb24c)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2FMikesMani11.jpg&hash=30472c10f311e44f26ae4297ead5ec6ff76e1c8c)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2FMikesMani12.jpg&hash=8518b0c1ccb1fb5f581bb642c091f295835f1aed)
Other then drilling and taping an egt probe, it is done and will be installed tomorrow. Next week it will be all pulled back apart, another 5 egt ports and 2 drive pressure ports will be drilled and tapped, and an external gate will added. Then when I get back from Ecuador in Oct. I will begin building 2 more. One with the same T3 flange but with sch 40 1.25" runners, and one the same but with a T4 flange. These will all be extensively data logged against a stock 24v manifold, and against a commercial available after market T3 flanged ATS manifold.
At the end of the day 4 years since doing fab on a daily basis sure shows... :-[
2 hx35's and an he351vgt?
You don't count, you have seen them in person. Your only bonus points are if you can tell me how many blades each of the compressors have, and the size of the turbine housings.
sell me your tig if your not going to use it :P
I do use it just not for dirty sch 40 pipe. :P
Trick question they all have 7 blade compressors and the hx's have 12cm^2 turbine housings but one is vgt :-*
So close, two have 8 blades one has a 7 blade, the rest is correct. :P
good shit, came together nicely
i have the same big turbo as you do the one on the right, idk wtf id ever use it for, kind of looks inefficient for a gas motor... i want that dam garret, what are the specs nog
The big turbo on the right is a Holset HT-60, with any luck it will be on Trevor72's cleavland over the winter.
The one on the left is a GT-4294, it has a 1.32 T6 exhaust side.
hmm i think a gt42 would go good on my pos fox i will just crank the boost to nog and wait til the block cracks
It would take about 7psi to crack a stock sbf block with the GT-42. :P
They are easy to find as they came on a ton of detroit diesels.
ya no shit, actualy my buddys that i put a 8pt cage in i will also have to post has 617whp 347 stroker with a paxton supercharger at 14psi. hes waiting for it to brake but nothing yet haha he rapes the fuck out of it too...
ya i got a gt40 off a detroit. my buddys running it on his rotary :-X
looks good. nice work bench. :noel:
One day the "bench" will run again, and I can build a proper work area where it is...
The worst part about the "bench" is that it leans, and I couldn't find bolts to fasten down the flange on the head while I welded it, so it was a lot slower then I wanted.
Did those drawings I re-sent you open this time?
Why?
Looks good.
Looking sweet.
Hey, a guy I know has a minty new GT4594LR, it's a T6 flanged baller bearing diesel jobber. 1.38 (?) hotside and a GT42 compressor. You need?
Why?
Because I was asked / paid to.
Looking sweet.
I don't currently need it, but at the same time... How much ?
Here it is on the truck, twins installed. Got it started up today, but didn't make it to the dyno event in Red Deer, we fought an oil leak off the primary all morning. The truck is supposed to attend another dyno event in Oct. While I am away.
*** Note I did not fabricate the cold pipe, or take this set of pics, the owner of the truck did.****
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2FMikesTwins4.jpg&hash=5635461acba5446f7491eef44b723c1fd811dfb2)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2FMikestwins2.jpg&hash=4444d72252151a9a26281f44eed746969fe265b6)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2FMikestwins3.jpg&hash=eff4aa61339b6a26cf4c8239bfbe4c757af29ec5)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb382%2Fdvst8r%2FMikestwins1.jpg&hash=f4b3e0f56786a02f6687b7d3652783706fb7ce65)
The turbo's used in this setup are a GT3788R T3 (with an internal gate, that we will be replacing for an external one) Over an S474 T6.
The owner is shooting for 700whp+ on #2. He made 680, on a slightly smaller slightly less efficient setup.
Why?
I figured that much, is it just because he needed t4 flange?
Nope it was a T3 flange. He just wanted to try something else. The owner has a stock 24v mani, and an ats mani. I think the biggest reason is that we will be adding an external gate to this, and he really didn't like the idea of that spacer deal that E.D does, especially not for $1000.
Cool curious to see some numbers and hopefully a vid or three.
I see, adding external gates to cast manifolds isn't favorable.
Your fab has gotten especially O0 ish there buddy. :yes:
Looking sweet.
Fuck if I know. A friend got it for practically free, then sold it for $400 or something to a local dude with a bit of money. Using it on his Mustang was shot down, and it's been collecting dust for over a year. I think he understands it's not worth much (in a gas application) but IDK how reasonable he'll be about selling it.
The fucker weighs a shit ton, it might be cheaper to drive your truck down to pick it up. :-X
ummm remember the horenet?
Yes it most certainly has.
Looking sweet.
My truck is currently on the same schedule as Chads HT build, but if you were to do that dyno event gtg, before it disappears, I would drive my TDI wagon out. :P
Brett, i went out and checked my jetta, and yes that down pipe is there along with a tool kit.
Want me to send it, or are you going to wait for me to come in october?
Looking sweet.
You bought a tdi wagon?
Yup, put the rod through the block of the honda, and needed something ASAP. I am probably going to be a dealer for Mark, but we will see how things go. Got the TDI wagon for the extra space, and because I can tow the dirt bikes with it.
Sweet, wanna sell some diesel truck parts while you are at it? I am making EGR kits for the fords like a mofo.
The only person I know that drives a ford diesel is Chad, but I am always pimpin your products. :noel:
Chad has a Ford because he is a glutton for punishment.
Someone is buying my egr deletes in AB, at least thats where I hear they are all going. I hear its the promised land of big diesel trucks out there.
There are lots of Ford diesels around here, just don't know any of the guys driving them. You should hit up NADP in Edmonton.
Goforth has an 06 that needs a delete. $5?
Make it $6 and receive free shipping via Hotrex.
Paypal? :noel:
Paypal? :noel:
Sales@ccfab.net
Looks good, build me something for my Ford now :P
