		General Category => General Discussion => Topic started by: rudebwoy on October 29, 2009, 10:26:51 AM
				I made this thread before but got lost because of the forum wars. here goes again.
1999 HONDA CIVIC HATCH, (German specs goal 600whp)
HEAD:
*B16A2 Cylinder head
*Crower valves springs, and retainers
*Crower stage 2 turbo cams
*Golden Eagle 84mm Headgasket
*Golden Eagle adjustable cam gears
*JG edelbrock intake manifold
*JG edelbrock 65mm throttle body
BLOCK:
*Golden Eagle sleeved B20 block
*Manley turbo tuff rods
*Arias 84mm 9.15.1 compression pistons
*Arp main studs
*Arp head studs
*Gsr main Girldle
*ACL Race main bearings
*ACL Race rod bearings
*Moroso street and strip oil pan
*T1 Racing development catch can/modified valve cover
TRANSMISSION:
*B16a2 S4C
*LS B18 5TH Gear
*Gearspeed carbon synchros
*Mfactory Helical LSD
*DSS 2.9 axles
*Competition twin disc clutch
SUSPENSION/WHEELS/TIRES/BRAKES:
*Ksport full coilovers
*Avid aluminum torque mounts
*Prothane motor mount bushings
*Pothane Shifter bushings
*B&M Short shifter
*EDT front traction bar
*ASR Rear sway bar and subframe bar
*BLOX front and rear camber kits
*BLOX toe in/out adjusters
*BLOX rear control arms
*Rear eb strut bar
*Password JDM front 3 point strut bar
*Nippon F2 16" /yokahama
*M&H racemasters/ 15" kosei k1
*NSX 11.1 front brake conversion
*RSX 10.2" Rear brake conversion
*Goodrich SS brake lines
*Blox extended wheel studs/nuts
TURBOCHARGER
*Garrett T04R big kahuna(T67HO)
*Blox Velocity Stack
*Peak boost Topmount manifold
*Tial 44mm wastegate/open dump
*Tial 50mm BOV
*Apexi Turbo timer
*Hondata boost controller PWM kit with MAC boost valve
*3" downpipe
*QTP E-cuotut
*Magnaflow cat/3" test pipe
*Kteller 3" catback
*2.5" Peak boost charge piping
*CX racing bar and plate 700hp FMIC
*CX racing engine oil cooler
*Nitrous Xpress Ntercooler sprayer
*CX racing aluminum radiator
*Flexa lite Fan
FUEL/ENGINE MANAGEMENT/IGNITION/MSC ELECTRONICS:
*Precision 1600cc peak and hold injectors
*FJO peak&hold injector driver
*Edelbrock fuel rail
*Russel inline fuel filter
*8AN feed SS line
*6AN return SS line
*Fullblown motorsports dual fuel pump hanger
*2 Walbro 255lph HP fuel pumps
*Aeromotive fuel pressure regulator
*Hondata s300 EMS
*Zeitronix wideband with display, integrated AFR, Egt, boost gauge.
*AEM 3.5 bar map sensors one for map, and one for boost signal
*Devil's own progressive methanol injection
*MSD digital 6
*MSD HVC coil
*MSD modified cap /honda distributor/
*NGK 8mm wires
INTERIOR GAUGE/ DISPLAY
*EK9 Recaro seats (red)
*EK9 rear seat
*EK9 door panels
*EK9 type R headlights
*EK9 Momo steering wheel
*Sabelt 3" camlock harness
*TDA harness bar
*Autometer Carbon fiber oil pressure gauge
*Autometer carbon fiber water temperature gauge
*Autometer Pro adjustable shift light with Rpm
*2000 civic SI cluster
*Zeitronix display
*Kenwood CD player
APPEARANCE/AERO AND COSMETICS:
*Type R front lip
*Type R rear lip
*Type R grill
*Type R wing
*Spoon style power mirrors
*Password JDM cooling plate
*password JDM radiator stay
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg88.imageshack.us%2Fimg88%2F8498%2Fdsc00768d.jpg&hash=5099bc88e6122befc62579e424dcf9f554440083)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg682.imageshack.us%2Fimg682%2F1053%2Fdsc00773b.jpg&hash=922b615d0157c9c74211c4c02abe83832e18c941)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg213.imageshack.us%2Fimg213%2F795%2Fdsc00767w.jpg&hash=9af139ee789c13e874811588b9be7e2103f3925c)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg88.imageshack.us%2Fimg88%2F4029%2Fimg0169g.jpg&hash=7b05caca4371593b825a10fda6b0208a9646c206)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg526.imageshack.us%2Fimg526%2F4506%2Fimg0170e.jpg&hash=faf64cce39d56ac2c64300c2f5d3008bb48f4e60)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg363.imageshack.us%2Fimg363%2F382%2Fdsc00013po6.jpg&hash=1fb348c41010d925deea0c6c77faba69f1550877)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg502.imageshack.us%2Fimg502%2F6636%2Fdsc00071fq1.jpg&hash=a7ee070168bbedbae0ec2de2b4f45c47213d2be0)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg165.imageshack.us%2Fimg165%2F7204%2Fdsc00079du9.jpg&hash=a3cad7b7f8d1d66efaec79a40a6736573139040d)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg94.imageshack.us%2Fimg94%2F5171%2Fdsc00772.jpg&hash=ff98f97c1eba07ada7cde42544c732ffd1923177)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg215.imageshack.us%2Fimg215%2F7523%2Fdsc00753x.jpg&hash=41f24d9a0168b8c03c4b6b4c0a4f595e7dd093f5)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg27.imageshack.us%2Fimg27%2F5715%2Fimg0168ul.jpg&hash=06ae2c560f7ed13584242b599cb34e7792ec4208)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg11.imageshack.us%2Fimg11%2F8297%2Fdsc00524wxz.jpg&hash=130b4e937bfc5f06826ef92f09aa9bfc545a0e47)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg27.imageshack.us%2Fimg27%2F120%2Fimg0172gx.jpg&hash=1fbb629855dc38bd01aa7ae8c8ec079d67bb096c)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg11.imageshack.us%2Fimg11%2F3406%2Fdsc00523lia.jpg&hash=154f7511601feffcb5448de3ddd3186bbee5bc98)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg6.imageshack.us%2Fimg6%2F3277%2Fdragpic.jpg&hash=178903e3252aa6139e0a36ae255d1fd0621133b6)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg146.imageshack.us%2Fimg146%2F1025%2Fdsc00019h.jpg&hash=cd77890f89a1ef2b06d26749fb5c205a55da69f0)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg30.imageshack.us%2Fimg30%2F7849%2Fdsc00022oqg.jpg&hash=b8b006d5470fb8c36e22ce86a6e9eeb3c563c717)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg27.imageshack.us%2Fimg27%2F1403%2Fimg0145el.jpg&hash=4578b430f16b7f92e25e9cd27dc70b029116c8a7)
 have at more pics upload is time consuming.
old ride
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg82.imageshack.us%2Fimg82%2F350%2Fdsc00062sw5.jpg&hash=94acdc7b8f9cf10aac7640c00e6274d87eb7ed3e)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg299.imageshack.us%2Fimg299%2F8996%2Fdsc09274jd3.jpg&hash=a3627b3f488ade5db79f6b959be170d146077773)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg266.imageshack.us%2Fimg266%2F3687%2Fdsc09160vv6.jpg&hash=7f2c27896bc9edca8b3be320df725261957c9c94)
				solid as usual. clean as fuck too thats JDM
you need to change your custom title to "autobahn assassin"
				got enough money in the setup?? if you didn't buy a house before this, i'd call you foolish.
Just because your broke doesnt mean spending money is bad.
				Nice shit as always!
				i like your setup clean ride
				nice build man  O0
				thanks ya'll. now tag that shit in the project section.
				$ Nice build $
				damn, thats a clean build.  Nice upgrade from the old car.
