General Category => General Discussion => Topic started by: darksol2005 on October 29, 2009, 04:15:18 PM
I've had the idea of doing this for the past couple days. It's a fairly simple design. Heating element, box/container for "tobacco", and tube. I'm thinking I could actually make something decently nice too, instead of paying 100+ bills for one. Just curious if anyone has any input or pics of what legit ones are using on the inside of em
go vaporize your face
Angry much?
Your avatar require a login from performance-dont-know-what. Remove that shit.
when i built mine for the boba costume... i used
1 soldering iron with a stainless steel spoon screwed into the iron(i cut off the handle because it just would not fit in the jar), a dimmer switch because the iron on full blast will approach the "tobacco's" ignition temperature. then i just contained it with a glass jar and piece of wood that the iron was fixed to. i used a broken nebulizer air pump to blow the "tobacco smoke" into the helmet. i mean i didnt want to get light headed from the oxygen, fuck that. hook it up to a nice size battery and your mobile. or use the wall socket with the dimmer and booya grandma
i will sell you mine for 50.00 plus shipping its a hot box brand i paid 200.00 for it pm me
Not a bad idea.... Only thing I need to know now is, do you NEED to have some kind of pump incorporated as well?
i seen a nice write up on this when searching google back when i smoked. kinda the same idea that was stated above with the dimmer switch and soldering iron but they used a mellon baller thing with the hole already in it and its deeper then a normal spoon. looked pretty simple to make, i just decided to not smoke weed anymore so i didnt make one
i guess buying a 200dollar vaporizer for 50 dollars would be to easy...then you wouldnt have to make a thread about making one though
Are you that much of a broke crackhead that you have to slang your belongings on forums? Thanks for the offer, but I'll pass
no, you dont NEED the pump, oh, and make sure you use a new soldering iron, because you dont want to inhale that other shit you would use an iron for.
Never liked em.
step one: take glass light bulb, clear one, not a white one
step two: smash off the metal part so you have a bulb
step three: put weed in glass light bulb and get lighter and glass shards
step four: use glass shards to cut wrists and lighter to burn down house
=profit
well duh after buying my 2005gsxr,new turbo,material for new turbo manifold,rent,plus im married fuk yeah im broke so where do you want me to ship this vaporizer to?
The thought of seeing your fatass on a bike is hilarious.
