General Category => Engine Management => Topic started by: FreshDA9 on November 07, 2009, 01:57:01 PM
Title: Vacuum Issue??? NSFW!!!
Post by: FreshDA9 on November 07, 2009, 01:57:01 PM
Ok just started up a map with BRE in a PR3 ecu. the problem is at idle it is sitting at 16-14 inch vacuum. i can not get it to sit in 23 or 21in.v... Also the distributor is all the way retarded if we set it to 16 degrees it will sit in 14-13in.v...
We have checked timing its on. We changed map sensors to a know working 1 nothing. changed ignition timing in the map still nothing??
The car is a 91 crx PR3 ecu with a B16a. stock map sensor, tps, also a distributor king dizzy. when he had this motor in his integra it would idle at about 37-35Kpa in ectune?
I tried to attach the maps but said i exceeded limit every time.
And for your effort i give you some Porn for my gratitude.......
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg.crocostars.com%2Fariella-ferrera%2Fmilfs-like-it-big%2Fariella-ferrera-during-her-workout%2F10.jpg&hash=0d6586ffd07cc28b50d7817b77cea0d98bfa6a9a)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fgalleries.payserve.com%2F1%2F31891%2F20340%2Fimages%2F9.jpg&hash=0bba216a72f781ae67bf6ed6005ad73a3d85f92e)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fwww.bravoerotica.com%2Fals-scan%2Ffranziska-shoot-2-als-scan%2Fhay-there--cowgirl%2F12.jpg&hash=50b8f5da9fe2e29c5c8d8fd0667440dca271534f)
Title: Re: Vacuum Issue??? NSFW!!!
Post by: JACER63 on November 07, 2009, 03:53:25 PM
compression test to see if all cylinders are good?  could have a compression problem causing the low vacuum.
Post by: FreshDA9 on November 07, 2009, 04:35:25 PM
Steady idle. will have him do a compression and leak down to confirm..
Post by: Joseph Davis on November 08, 2009, 04:41:04 PM
Last BRE car I did behaved similarly.
Post by: Teg2boo on November 08, 2009, 05:57:22 PM
Mine was working well, but it was a OBD0 PR4.
Post by: FreshDA9 on November 08, 2009, 10:32:53 PM
Really do you by chance know why? i got the map and a couple logs but RHMT keeps saying im exceeding the upload limit even if i try to upload just 1 that is way below the limit.
Post by: Joseph Davis on November 09, 2009, 01:36:35 AM
It was the second BRE car I've done, the other was ~4 years ago.  I really know jack shit.
Post by: FreshDA9 on November 09, 2009, 01:42:49 AM
Damn... gotta be something simple im over looking.
Post by: Joseph Davis on November 09, 2009, 01:47:44 AM
Runs fine = runs fine.  What are you overlooking?
Post by: FreshDA9 on November 09, 2009, 01:57:22 AM
Just seems to be running to low of vacuum at idle. thats what caught my attention.  that and the starting issue but that should be an easy fix.
Post by: Zeniceguycrx on November 09, 2009, 01:58:52 AM
thread jack
Iv been trying to get bre to run on my computer
Where did you get a copy from and anyone got a stock pr3 in for it?
Post by: Zeniceguycrx on November 09, 2009, 01:59:39 AM
I would dbl check you timing
it could cause low vac if a cam is out
Post by: Joseph Davis on November 09, 2009, 02:01:05 AM
Nope, low "vacuum" according to datalogs and cold start issues - mostly when in the 90-140 degree range after start - are what I experienced.
Post by: FreshDA9 on November 09, 2009, 02:13:58 AM
Hmm good to know.. ok ill give it a shot and see how this ends up.
As far as BRE mr thread jacker try pgmfi.org
