General Category => Forced Induction => Topic started by: turbohf on March 19, 2009, 10:05:19 PM
Title: quite bov? or way to make them silent?
Post by: turbohf on March 19, 2009, 10:05:19 PM
so yeah whats the most quite bov? or is there a decent way to make them quite without killing the performance of it? car will have a smaller sized turbo (46 lbs/min 588cfm) at like 10psi, so it wont need a fat ass TiAL 50mm...
Title: Re: quite bov? or way to make them silent?
Post by: turbohf on March 19, 2009, 10:25:11 PM
recirculate it back into the intake.
its speed density, it will most likely not have an intake, just a filter... :-\
Post by: Dweezil on March 19, 2009, 10:30:04 PM
Route the recirculate tube in after the MAF or put the BOV before the MAF and recirculate it back into the turbo. Just add an intake to the turbo inlet.
Post by: stealthiskey on March 19, 2009, 10:35:20 PM
well i guess you could put some kind of foam over the outlet of it.
like the sound proofing eggshell stuff.
that would slow down the air coming out, but probably not restrict it enough to cause problems.
There's an idea, try building your own silencer.  You don't want to block the opening in any way though. look at dirtbike silencers/mufflers for inspiration.  Don't know how quiet it would be though.
2 diameters of pipe, small one fits inside larger one.  Drill holes in smaller, wrap lightly with fiberglass insulation, and seal up openings on either end of the larger pipe, leave smaller open.  Route bov through smaller pipe.  Could probably make this with a trip to the hardware store or some leftover charge piping.
Post by: widebody93 on March 19, 2009, 10:35:31 PM
SYNAPSE BLOW OFF IS QUIET
trust me.
Even on dyno at 15psi you could hardly hear it on my h22 at 470horse with the 6262e turbo
Go to my thread in the forced induction section and watch my videos you cant hear it.
Post by: Robb on March 19, 2009, 10:46:14 PM
This is what I agree with...
trust me.
Every car ive seen/heard with that bov on it wasnt quiet.  Yours must be a fluke of combination.
Post by: widebody93 on March 20, 2009, 12:17:36 AM
Fluke or whatever it may be. On the dyno you could clearly see it was operating 100percent on and off the throttle. All you heard was a little whoosh  followed by a large stream of air you could feel about three foot in front of bumper.
Post by: brine04 on March 20, 2009, 03:11:04 AM
One of the miata guys on the old site had pics of his wrapped in packing foam.
Post by: 88dx on March 20, 2009, 03:18:41 AM
Tial 50mm out the hood. and Wear ear plugs super quiet  O0
Post by: HiProfile on March 20, 2009, 03:22:54 AM
I've also seen someone with theirs wrapped in foam, I almost thought it was on OHMT. I think it was an SSQ, which can be very loud with that piercing whistle. Another solution is to hook a tube to it, run it for 2-4 feet, then end it with some foam at the end. Its generally the first second or three that you let off the throttle that your turbo will be most likely to surge. A poorly performing BOV is usually noted by opening late, not by flowing too little.
FYI the Tial's I've heard are actually rather quiet, since it has a large amount of area to escape w/o making much turbulance. The only loud Tials I've heard are with giant-turbo setups like a single-turbo Supra.
Post by: Urban Indian on March 20, 2009, 03:44:50 AM
those niggers
Post by: j.h.christ on March 20, 2009, 04:23:05 AM
dustin i've got a bosch one from a 1.8t you can have
Post by: patsmx5 on March 22, 2009, 07:54:48 PM
It was me.  :D I wrapped my knockoff tial 50mm BOV in foam. Makes in very quiet. Before, it was loud as balls. Now you don't hear it at all unless it's a full boost pull and I slam the throttle shut, and you barely hear it and just for like 0.1 seconds at that. Basically you don't hear it anymore.
Bought the foam at walmart for 12 bucks I think. Zip tied it on. Put a random hose clamp around it too for good measure.  :noel:
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi231.photobucket.com%2Falbums%2Fee155%2Fpatsmx5%2F100_2165.jpg&hash=14ccabc0c7ead348de5d10e5d54b96ee6c0d6e0c)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi231.photobucket.com%2Falbums%2Fee155%2Fpatsmx5%2F100_2164.jpg&hash=67946b143756db51482d36e17e9fe5ae40b60558)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi231.photobucket.com%2Falbums%2Fee155%2Fpatsmx5%2F100_2259.jpg&hash=a3b3875f8e925bdb7573021141c7a3846e2cb9af)
If you think it's gay, you're right. Have a cookie. And cry when your fail wheel drive honda gets waxed by a seemingly stock quiet gay miata.
Post by: Colin on March 23, 2009, 12:58:50 AM
Swiss cheese it a la project cheap slut
Post by: Blacksi on March 24, 2009, 01:30:25 AM
i can make your bov silent give me a call
Post by: widebody93 on March 24, 2009, 04:00:14 AM
What about dumping the flow of the BOV towards the back/underside of the battery tray into the duct of fender frame rail?
Post by: crttaz on March 24, 2009, 06:03:45 AM
heard you swallowed to keep the IN jailbait quiet!
Sleep!
Post by: clwtwizted on March 24, 2009, 01:54:37 PM
Duck call ftmfw!
Post by: 5thgenlx on March 25, 2009, 04:15:28 AM
diverter valve. you're welcome.
Post by: j.h.christ on March 25, 2009, 05:48:20 AM
yup. like i said, i have one you can have, jew-bait.
