General Category => General Discussion => Topic started by: Minor Threat on December 10, 2009, 01:12:06 AM
Title: Calling all DAS AUTO guys dvst8r, etc
Post by: Minor Threat on December 10, 2009, 01:12:06 AM
Buddy's 01 TDI takes forever to heat up, I know diesels don't keep their heat nearly as well as gassers do but his car takes no joke almost 20 mins of driving to get halfway to operating temp. He did the thermostat last year, but it didn't really get any better.
Any hints for heat now that winter is here?
Title: Re: Calling all DAS AUTO guys dvst8r, etc
Post by: onlyflash944 on December 10, 2009, 01:13:40 AM
cardboard in front of the rad
Post by: Hotrodlincoln on December 10, 2009, 01:24:19 AM
This/
Post by: Minor Threat on December 10, 2009, 01:50:04 AM
Um, the car loses heat if you're stopped at light too long/stuck in traffic not moving, more so than if it's moving.
Post by: highroller54 on December 10, 2009, 02:12:38 AM
flush heater core really good and some card board might be needed but watch that you dont over heat it.
Post by: Joseph Davis on December 10, 2009, 02:20:42 AM
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi256.photobucket.com%2Falbums%2Fhh166%2Fjoeymisanthropy%2FGREASY.jpg&hash=654b399d8f8e79a168b49db617e9058fc30fe74c)
Post by: Minor Threat on December 10, 2009, 02:29:11 AM
No, it's only got a busted MAF but we just unplugged it and it works fine. :-X
Post by: Joseph Davis on December 10, 2009, 02:31:02 AM
FUCK YOU!!
Post by: highroller54 on December 10, 2009, 02:34:11 AM
and a plugged egr system blocking off 3/4's of the intake manifold ports.
Post by: Robb on December 10, 2009, 10:51:24 AM
"signal too slow when greasy"
Only a vw.  :P
Post by: Lowerit on December 10, 2009, 10:54:31 AM
I put over 100K on my TDi , it was always slow to heat up. Even my friends 07  TDi takes forever. I thought it was just a diesel VW thing.
Post by: Minor Threat on December 10, 2009, 12:57:26 PM
This is what I'm trying to figure out.
Yeah but it runs so who cares. We'll fix it when it blocks off 4/4
Post by: Passenger on December 10, 2009, 02:42:41 PM
This.
Post by: Minor Threat on December 10, 2009, 02:46:20 PM
Best way to unplug it and keep it that way?
Post by: Robb on December 10, 2009, 02:56:50 PM
Pull teh egr and manifold and clean that shit out manually or soak it in something to get it cleaned out.
Also, Ive had 50/50 luck with that mass air cleaner on vw/bosch MAFs, its worth a shot.
Post by: Minor Threat on December 10, 2009, 03:00:13 PM
Will it not plug back up though or is it a long process?
Post by: dvst8r on December 10, 2009, 04:26:42 PM
Get a "race pipe" and have get get it chipped so it won't throw the code after.
My 03 TDI heats up in about a mile of driving, and stays right at operating temp (90c) even when it was -35c last week. No cardboard.
Post by: Minor Threat on December 10, 2009, 05:47:08 PM
Diesel geek lists a race pipe and just a plain vanilla EGR delete. This is RHMT budget, aka 0$
Post by: dvst8r on December 10, 2009, 05:53:24 PM
Gut the stock egr piece ($0), but you will still have to get it chipped to get rid of the code it throws.
Post by: Minor Threat on December 10, 2009, 06:08:14 PM
Does the code trigger anything? Or is it just a code?
Post by: dvst8r on December 10, 2009, 06:32:50 PM
Just a code, and the light. Doesn't effect performance at all, doesn't throw limp mode or anything silly like that.
Post by: Minor Threat on December 10, 2009, 06:41:21 PM
Awesome, hopefully this will cure the no heat situation.
Post by: dvst8r on December 10, 2009, 06:44:07 PM
Don't just gut the EGR, you will have to pull the intake manifold and clean it too. Gutting the EGR will just keep it from coming back.
Post by: Joseph Davis on December 10, 2009, 10:30:06 PM
On Fords (primarily 6.0's) I like to disable the EGR valve in the code.  Given enough time shut it carbons closed (as opposed to open) and you never have to worry about it again.   :mexi:
Post by: Robb on December 10, 2009, 11:02:25 PM
No worky on this car.  EGR valve is what a layman would call the throttle body on this setup, hence it clogging and causing issues.
Post by: dvst8r on December 10, 2009, 11:05:35 PM
Oh and gutting it is worth about 2hp...  :P
Post by: Minor Threat on December 11, 2009, 10:17:53 AM
What's fixing the busted maf worth? 20?
Post by: dvst8r on December 11, 2009, 03:02:39 PM
At least, and fair bit of fuel millage too.
Post by: Minor Threat on December 11, 2009, 03:27:06 PM
The mileage went up after he unplugged the MAF, go figure. Was probably dying for a while before it finally stopped working.
Post by: Robb on December 11, 2009, 04:28:46 PM
Most modern MAF cars respond in this way.  If you can unplug the MAF and it revs smoother and runs cleaner, the MAF is bad.  VW dealer will charge you $75+ for this fyi.
Post by: dvst8r on December 11, 2009, 06:00:25 PM
I am thinking about doing a maf delete at xmas, we will see how much time I have down on the coast.
Post by: Minor Threat on December 11, 2009, 07:53:13 PM
I'm gonna try it on the Taron, my mileage sucks ass and it's pretty gutless.
Post by: dvst8r on December 11, 2009, 10:11:27 PM
To do a Maf delete, that actually works, you need to do chip it.
Post by: Minor Threat on December 11, 2009, 10:34:11 PM
It's ok, I was kidding.
Post by: Robb on December 12, 2009, 06:06:50 PM
www.ds-map.net (http://)
Its free.  Going to use it on the colt very soon.
Post by: Minor Threat on December 12, 2009, 07:08:51 PM
www.ds-map.net (http://) (http://) (http://)
I was only kidding about just unplugging it and letting it rip.
I'm missing a GM IAT only because I have exams to study for, and no time to get to a junkyard. All the other parts are sitting on the desk beside me right now.
