General Category => Hybrid/Tech => Topic started by: onlyflash944 on March 22, 2009, 09:24:07 PM
Picked up a 96-00 EX P4A B000 tranny with the STEEL shift forks seeing how all the aluminum ones from the P20 92-95 ones I have are broke as shit.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi91.photobucket.com%2Falbums%2Fk295%2Fonlyflash944%2FRed%2520CX%2FTransmission%2FP1010258.jpg&hash=faacbe681de6fdbf08759cc7e4aea019ee9ee185)
Was going to throw in the OBX LSD I've got and these two balls fell out
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi91.photobucket.com%2Falbums%2Fk295%2Fonlyflash944%2FRed%2520CX%2FTransmission%2FP1010259.jpg&hash=2e224f81c15fee2be96c434721f6391a0fcf11b3)
every bearing on the main and counter shaft is just fine. WTF are these in the case? The VSS was missing when I got it, could they be from something else and just got dropped in there?
Those are the detent balls. There are notches on the shift forks that those sit into. There are two bolts (12mm i think) on the case that you pull out and they have springs in them. Reassemble the case then put those balls in then the bolts.
ill have to download a manual
thanks for the heads up
Counter shaft lower syncro appears to have been hot at one time or another
countershaft bearing in the clutch housing had walked out a bit or i moved it trying to get it apart
CSB is now staked, and for the record, there is 3 steel balls and a 12mm does remove the plug and spring associated with each ball. they go in after you assemble the transmission and casings.
another 4 or 5 years messing around with these POSes and i might give bone a run for his money
thanks for the help, nogs
Since that piece is not visible your Superman powers of vision must be awesome............except if Del Slo's are involved.
doubt you can reach my higher plane of knowledge.
I'm not one to brag, but damn seems like I have something to brag about!!!!!
Went past Bobby's shop, no one home, everyone was at Sebring or enroute back to Ohio.
