General Category => Fabrication => Topic started by: nock on December 21, 2009, 06:44:29 AM
Title: sweet ass tubing bender
Post by: nock on December 21, 2009, 06:44:29 AM
http://www.thefont.info/tube_bender.htm (http://www.thefont.info/tube_bender.htm)
this is about the only part off a fiesta that is good for anything
Title: Re: sweet ass tubing bender
Post by: CSaddict on December 21, 2009, 07:49:52 AM
Well I suppose the same theory would apply for larger tubing. With larger tubing the sides probably would deflect though. Nice find.
Post by: onlyflash944 on December 21, 2009, 06:29:26 PM
i don't know if i would want to make a cage using that method, but i would have to try it first and see how much it crushes the pipe.  wonder how thich of a material you could do that way
shit would be tite for bumpers and such tho
Post by: Joseph Davis on December 21, 2009, 06:43:12 PM
I've wanted to make my own mandrels for some time now, it shouldn't be too hard with my lathe.  That's an excellent source of base radiuses to weld material onto/lathe off.
Fill with sand, same as sand bending with heat.
Post by: nock on December 21, 2009, 08:43:45 PM
i have a big old lathe to. if i ever get around to building one of these things i'll do just that, fill the shoe in with weld bead and cut it nice and round on the lathe.
Post by: ADSR on December 21, 2009, 08:58:44 PM
here's the bender i built. Bends pretty damn close to a mandrel.
http://www.gottrikes.com/Tube_Bender.htm (http://www.gottrikes.com/Tube_Bender.htm)
Post by: CSaddict on December 21, 2009, 11:04:28 PM
I call trick tools and buy mandrels for mine. Its easier.  :-*
Post by: mandrel-bends on December 22, 2009, 04:06:06 PM
Are you guys referring to bend dies as mandrels? I'm lost.
Remember anything over 3*diameter, with a relatively decent wall thickness doesn't need to be mandrel bent. It will make no difference. If we bend it here on a mandrel bender, we would only run 3 of 5 tools. (no mandrel and no wiper) as they would make no difference. So even some of the simplest benders will work just fine for this type of work.
This is a mandrel:
http://www.bendtooling.com/product%20mandrel%20assy%20aluminum-bronze%202.JPG (http://www.bendtooling.com/product%20mandrel%20assy%20aluminum-bronze%202.JPG)
This is a bend die:
http://www.bendtooling.com/sidebar%20bend%20die%20inserted%20platform%202.JPG (http://www.bendtooling.com/sidebar%20bend%20die%20inserted%20platform%202.JPG)
Post by: CSaddict on December 22, 2009, 04:55:10 PM
yeah I meant dies.
Post by: Joseph Davis on December 22, 2009, 11:39:25 PM
And I meant sandrels.  :P
Post by: HiProfile on December 31, 2009, 03:11:06 AM
I was just wondering, instead of making a die with a lathe and welder, couldn't you just bend up a larger, thick pipe as the base? If it has the same ID as your target pipe's OD, you'd bend it to shape and cut it in half (on the sides). You'd only need a few changes on that 1st link to accept a larger pipe as the first bend.
Post by: onlyflash944 on January 02, 2010, 07:48:32 PM
it would work, but it would be rather difficult to do right, i would imagine
Post by: NoPistons! on January 15, 2010, 12:00:18 AM
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=97468 (http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=97468)
