General Category => Fabrication => Topic started by: gooseman on January 06, 2010, 12:26:06 AM
http://autospeed.com/A_110860/cms/article.html (http://autospeed.com/A_110860/cms/article.html)
Ran across this in my search for intercooler piping. This would be sweet since I have access to a torch and solder/flux, but not a welder.
Antone here done this?
Copper is usually more expensive than aluminum (depends how you acquired it) :evil:
Copper is a great conductor of heat even more efficient than aluminum.
Besides everybody know PVC intercooler piping is where is at. ;D
BTW the article on the site are entertaining. Some cool ideas on there. :yes:
i haven't, but there is no reason you can't if you have the materials and tools to do it
if the stuff cheaper then i thought, and i could map gas solder it, id try it
buy a rope and tress are free
copper is NOT cheap......why do you think all the hoodrats are breaking into vacant homes and ripping out the piping......but I've no problems sweating the connections.
Damn right, thats what I used on my first kit, I had painted it flat black! :noel:
Yeah if you look at Specter Performance intake piping kits in parts stores that cater to the ricers.
They make a chrome painted piping kit that locks together. ;D
Already main stream sort of.
Looks cool on the surface, but it's not needed. I run steel pipes that are painted and my AIT's post IC are 4-8*F over ambient when in boost, cause the IC isn't 100% effective, maybe 90% effective. My hotside IC pipe might drop 5*F from the charge before it goes in the intercooler. But even if I put a copper one that dropped 20*F from it, once the IC takes away 90% of the temp delta, the result would be 3-7*F above ambient probably. Negligable.
i thought maybe with years of stolen copper being recycled + the fact newer houses use less copper and more snap together plastics plumbing shit, maybe the prices took a dump?
prices took a dump when china had the olympics. they shut down industry for like 3 weeks to clean the air up and thus every bit of scrap that goes to the slant eyes got backed up in the states. then theres this recession thingy
damn, i was just thinking abou this the other day. not that i planned to do it, but it seemed like a very easy way to make charge pipes.
it is, if you can find a cheap source of copper.
yea, cost was the big factor in why i wouldnt do it.
High thermal conductivity is not always good. If its hotter under the hood than it is in the intake pipes, I see no reason you'd want to use aluminum/copper. On the hot side, in theory, always use a material with a high thermal conductivity. On the cold side, it's a questionable choice. I'd personally use whatever is cheapest.
Scratch it. I got some pipe from a buddy. I will use PVC for what ever pipe I don't have.
I bet you could use alumiweld and a tailpipe expander to sweat aluminum charge pipes. Whos going to be the first to try it?
I thought about using baby seal foreskin for couplers and hollowed out whale bones for charge piping.
Mink on the seats, snake skin on the wheel.
Pimp.
I couldn't see any reason to use copper charge piping when you can use brake kleen cans......
