General Category => Hybrid/Tech => Topic started by: 98vtec on March 07, 2009, 05:07:58 PM
Cranks
F22 - 50mm mains, 95mm stroke
F23 - 55mm mains, 97mm stroke
H23a1 - 50mm mains, 95mm stroke
H22a/a1 - 50mm mains, 90.7mm stroke
H22a4 (1997) - 50mm mains, 90.7mm stroke
H22a4 (1998+) - 55mm mains, 90.7mm stroke - some 98 motors were produced in 97 and have 50mm mains so be weary of what you are buying
H23A - 55mm mains, 95mm stroke
all use the same rod journal diameter at ~1.8890"/47.98mm besides the F23
Crank pulley bolts
* 92 F22 - 14mm
* 93 F22 - 14 and 16mm
* 94 F22 - 16mm
The F22 and H23 cranks are going to have the same bolts between the years since they have the same part numbers....right?
* 1992, 14mm F22/H23 crank part number is 13310-PT3-315
* 1993 has options for both cranks
* 1994, 16mm F22/H23 crank part number is 13310-P0A-000
Rods
Length
H23/F22 - 141.5mm
H22a - 143.0mm
Pistons
Compression height
H22a (non type S) - 31.01mm
Intake Manifold/Throttle Body
F20b (auto)
Throttle plate - 55mm
Manifold inlet - 58mm
H22a
Port ID - ~53mm (each one is a little different)
Port spacing - 40.26mm
Throttle plate - 60mm
Throttle Inlet - 62mm
Manifold Inlet - 62mnm
Injector port Diameter - 11.56mm
Primary runner length - ~11"/279.4mm
I've got some more stuff in storage to measure and I'll get to that the next time i go out there.
Automatic f20b manifold/throttle body combo is uber gay
55mm sohc throttle body
57mm plenum manifold
Theres your loss in power. Add h22a manifold/throttle body you have a 5spd f20b thats all kids.
interesting. Do you have any idea why they decided to limit the auto so badly?
thanks for the addition, i'll slide it in there
I have no idea
I mean a sohc 55mm throttle body on that motor is a joke. The plenum is just has bad. I dont get it its the only automatic motor I have ever seen from honda where they really messed with the intake/throttle body so much,killing the top end power of the f20b head.
Bottom half plenum has same bolt pattern has all 3 piece h series manifolds so a top half off a h22a can be interchanged.
i take it the manifold inlet was just reduced and they left the rest alone? I was just looking through some pictures, externally it looks the same as the h22a.
Just went and measured it the inlet is actually 58mm hadnt looked at it months. Ill do some measuring here in a couple days along with pics of the auto f20b manifold vs the h22a jdm manifold
