General Category => Hybrid/Tech => Topic started by: walter on March 28, 2016, 07:10:27 AM
Hi! 2 weeks ago a customer came to me for replace a o2 sensor, i installed a B18C4 (B18C1 in US) into his EG5 , everything was good, the weird problem is that when i tried to install a universal NTK o2 sensor, solid cel and car didnt start it up..main relay doesnt works.., tried a oem o2 sensor, same problem, only works good with the o2 sensor that he has installed, i tried to remember when i did swap, it worked as normally, even without o2 sensor startet up, i dont know what the hell he did in his car.. only withs with that universall o2 sensor..any idea?
btw, tried my ecu, made another basemap with o2 dissabled, samething..didnt start with solid cel..what the f..
Did he some how use the main relay ground re-routed to the added o2 sensor, then mess with the sensor wiring? Try jumping each of the o2 plug's ground wires to ground, then both, then checking if the other 2 wires have continuity to ground (shorting out).
