Author Topic: finaly started but need help  (Read 16627 times)
« on: January 07, 2010, 08:16:06 PM »
b18b:
wiseco -12cc pistons
eagle rods
stock crank
mostly stock head
stock cams
Fuckin thing I got fuel and spark but it will not start. 93 dx chassi auto sub harness. the damn thing just keeps turnin but wont fire I checked timing three times and it's fine. I did a comp test and it was 120 118 123 98 the engine has never been ran so i figured that the comp was low due to rings not bein seated and sealed yet. brand new ignition every thing I am out of ideas anyone got a shot that might work.
« Last Edit: January 07, 2010, 10:31:26 PM by jdmhatchracer94 »
Re: damn car wont start
« Reply #1 on: January 07, 2010, 09:00:51 PM »
most likely the tune
new injectors?
try jacking up the offset.
« Reply #2 on: January 07, 2010, 10:19:52 PM »
no tune stock ecu. got it running idle is good but when it decels it wants to die. I turned the fp to 45psi and that seemed to help but I dunno
I need a tune if anyone wants to help out I got a chipped ecu and log and burner but I have never tuned before and dont want to blow this thing up
« Last Edit: January 07, 2010, 10:21:45 PM by jdmhatchracer94 »
Re: finaly started but need help
« Reply #3 on: January 07, 2010, 10:36:33 PM »
Is it idling smooth? Vacuum leaks?
lilpooh21186
« Reply #4 on: January 07, 2010, 10:39:07 PM »
Pm me specs and ur email I'll send u crome bin that might help
Ecu chipping
basmaps
« Reply #5 on: January 07, 2010, 10:52:07 PM »
idle is decent. I adjusted the tps I got 4.5v at wot and .43 at close
« Reply #6 on: January 10, 2010, 09:49:57 PM »
get it tuned and stop complaining.
« Reply #7 on: January 11, 2010, 03:39:30 AM »
Got to get it to move and stop b4 you can tune it. Like fix the clutch, and brakes.
« Reply #8 on: January 11, 2010, 05:25:07 PM »
brakes done clutch still working on but the fucking thing keeps dieing on me and I dunno what the fuck it is. Dies on decel idles fine when u decel from driving it drops off and dies and suggestions
« Last Edit: January 11, 2010, 05:34:44 PM by jdmhatchracer94 »
« Reply #9 on: January 11, 2010, 05:48:29 PM »
With the car running, Unplug your iacv, and adjust your throttle blade untill its at where you want it to idle. Shut off the car. Reset your tps, reset your ecu plug iac back in and call it a day. (This is if you have one of the pbt tb without the idle screw.)
« Reply #10 on: January 11, 2010, 06:06:56 PM »
that could be it yeah mine doesnt have idle screw
« Reply #11 on: January 11, 2010, 07:35:48 PM »
Try it man. Thats how I set mine up. I bet if you unplug your iac, while your car is idling It will want to die.
« Reply #12 on: January 11, 2010, 10:35:36 PM »
nice she is runnin good now I could only get the tps to read 4.45 at wot though .51 closed
