Author Topic: is there any other way..... its just too ghetto.  (Read 29949 times)
yamaha6611
« on: February 10, 2010, 11:02:55 PM »
im a big fan of doing shit right, but sometimes, i need to make shit work... lemme know what you think i can do...
i dont want that hose to kink up when it gets warm, braided shit just kinks real bad...
which sucks, cause the oil pan has a -10AN fitting on it, and so does my oil drain out of the turbo, both ported...
will it work, too ghetto?
« Last Edit: February 10, 2010, 11:05:36 PM by yamaha6611 »
Re: is there any other way..... its just too ghetto.
« Reply #1 on: February 10, 2010, 11:09:09 PM »
ditch the an fittings.
put a hose barb on the return flange and call it a day
« Reply #2 on: February 10, 2010, 11:09:17 PM »
Is that heater hose? That shit is going to swell up and split once it gets oil in it.
yamaha6611
« Reply #3 on: February 10, 2010, 11:10:24 PM »
its not heater hose its just that general advanced hose
not sure what heats going to do to it
« Reply #4 on: February 10, 2010, 11:11:35 PM »
Crack and leak. Do what flipnog said
/thread
« Reply #5 on: February 10, 2010, 11:13:03 PM »
Go to hydraulic shop and get some real hose. Then do the spring thing.
Or do a piece of hard line, and use small bits of the hose to clamp it on.
yamaha6611
« Reply #6 on: February 10, 2010, 11:15:13 PM »
well heres what else i can do... to get rid of that rediculous 90 deg. braided hose deal, i can just move the -10AN fitting down about 6 inches to the left, it will get rid of all that kinking, but i dont know if that will be too flat of a drain then
« Reply #7 on: February 10, 2010, 11:15:39 PM »
House of hose FTW
« Reply #8 on: February 10, 2010, 11:21:00 PM »
that setup is fine. ive used heater hose for return line before. it gets soft after a bit but just replace it every 6 months and youll be fine. ive never had one actually fail and leak.
« Reply #9 on: February 10, 2010, 11:41:50 PM »
+1  my experiences exactly.
bigwig
« Reply #10 on: February 10, 2010, 11:57:31 PM »
I'd rotate the CHAR a bit so the the oil line was directed more towards the pan.  Then you are stuck with barbed fittings, hose clamps, and line.
I will say, I really don't like hose clamps and SS braided line.  I had to put 2 or 3 clamps on the damn line at the oil pan for it not to leak.  It was pretty trashy and I wasn't pleased with it.
skaterdudz02
« Reply #11 on: February 10, 2010, 11:59:57 PM »
+2 I've used heater hose several times. It has never bursted on me before. It'll be fine.
theidealone
« Reply #12 on: February 11, 2010, 12:28:54 AM »
+3 This is the first I have heard of this, but I wouldnt doubt it. Ive been running heater hose from Lowes for the past 2 years. Although, I seem to change my set-up every winter, so it keeps getting replaced.
« Reply #13 on: February 11, 2010, 12:45:46 AM »
Honestly dudes, I know heater hose works and everything, because I've used it as a temp fix, but go to a real hose shop and get something rated for gas/oil use. You will thank yourself later on.
« Reply #14 on: February 11, 2010, 01:40:21 AM »
WTF to ghetto do you know your at  heater hose + ducktape wrapped around ftw
« Last Edit: February 11, 2010, 10:58:33 AM by lilpooh21186 »
« Reply #15 on: February 11, 2010, 01:57:09 PM »
This is rhmt there is no suck thing as to ghetto!
« Reply #16 on: February 11, 2010, 02:22:32 PM »
On one of my old dsm's the flex section broke on the drain, so I cut the pipe in two and patched it with heater hose, smeared RTV on the inside of the hose to prevent the oil from killing it.  I drove it like that for 2 years, and saw quite a few 1/8th mile passes before I sold it. No leaks.
« Reply #17 on: February 11, 2010, 03:16:32 PM »
I've done it too, but it makes such a fucking mess as it deteriorates.  There is oil and temperature rated rubber hose you can use for $6-8 a foot, and frankly the cool coil spring sheathe will protect the hose from most of the shit that makes me not willing to run a rubber drain on any car of mine.
Also, you just need to get a certain quantity of oil away from the turbo.  This is not hard.  You can make a box of a certain VOLUME right underneath the turbo with a shallow angle drain shooting back to the oil pan.
nock
  • pro... muther fuckin pro...
« Reply #18 on: February 11, 2010, 07:45:31 PM »
that shit is close,
if you want to get rid of the kink, just go down to shucks (or what ever the fuck its called) walk strait in the back like own the place, and grab whatever oem radiator hose that has a 90 in it and looks like it will fit.
if you want oil rated hose, just get some parker push-lok (cheap) a hose barb turbo outlet, and a hosebarb 90, i dont know what else you could do without pulling the pan off.
« Reply #19 on: February 11, 2010, 08:29:38 PM »
Order silicoln hose that flexes, problem solved. Fuck ill even ship you some for shipping charges
yamaha6611
« Reply #20 on: February 12, 2010, 12:15:25 AM »
yea imean its all good but i dunno, my shit has to be done right right, so, in my mind, i should be using AN line and fittings.. im thinking of fabbing some metal line thats 5/8in or something and just tacking it on to the AN fittings right over the tapered part... that way, no cracks, no leaks, no worrying about loose clamps and shit, thats oil , im way too worried lol
just dunno how the metal hose it going to take engine movement...
bigwig
« Reply #21 on: February 12, 2010, 12:59:39 AM »
AN fittings are not that great.  They don't use them in any OEM turbo'd cars that I know of....
Barbed fittings are fine.  Just use high quality return line.  I just had to put 2-3 host clamps on the SS line because it was so stiff....
ifly87
« Reply #22 on: February 12, 2010, 05:10:27 AM »
Its because of the price, AN fittings/lines/hoses are the best way to go. I work on $60million jets where prices dont matter and all the hydraulic and engine oil/fuel lines are all AN/MS shit. Its easy(ish) to make, remove/install and can hold 3000+psi without leaking a drop.
As for the OP's problem, making a hardline would probably be the best but if you can get that auto parts store shit to make the bend you can get some AN hose ends for that hose. That picture doesnt really do justice since is still hard to tell how much room you have.
Lol...Fags
ifly87
« Reply #23 on: February 12, 2010, 05:13:51 AM »
I was thinking about that, you just have to have the metal line, make the correct bend, slide the nuts and the flare stop on and flare the tubing, it will be very professional like :-\
Lol...Fags
« Reply #24 on: February 13, 2010, 03:34:11 PM »
Holy fuck! Its not brain surgery here! Keep it simple!
2slow
« Reply #25 on: February 14, 2010, 08:45:30 AM »
yeah your making this harder than it needs to be. who gives a fuck what the guy at the quick lube thinks of your setup
« Reply #26 on: February 15, 2010, 03:55:48 AM »
Green garden water hose FTW O0
« Reply #27 on: February 16, 2010, 07:11:33 PM »
+1
Or very large vacuum hose
Ghetto_D
« Reply #28 on: February 19, 2010, 04:43:49 AM »
garden hose + aluminum foil  DP was an inch away.
it held together longer than the engine lasted.
« Reply #29 on: February 19, 2010, 07:45:44 PM »
i used heater hose for a drain on every setup pussys
