Pages: 1 ... 3 4 [5] 6 7 ... 21   Go Down
Author Topic: my rwd crx project CRX2000!  (Read 762206 times)
weirtech
    • Weir Technologies Inc.
Re: my rwd crx project CRX2000!
« Reply #120 on: August 26, 2009, 03:45:32 PM »
Looking good. How are you going to set up your gas peddle Assembly?
the brake pedal arm will be bent/modified, and so will the gas.  i already knew i was going to have to do that when i first test fit everything.  it might make it easier for heel/toe action!
« Reply #121 on: August 26, 2009, 04:26:21 PM »
Ahhhh lookin' good.
josh19wrc
« Reply #122 on: August 26, 2009, 04:47:34 PM »
man, that is a serious trans tunnel!
speedjunky01
« Reply #123 on: August 26, 2009, 04:50:55 PM »
so will with CDM ebay pedals
« Reply #124 on: August 26, 2009, 06:10:30 PM »
With the transmission tunnel being so high the shifter should be at a great hight and if you set it up you can rest your arm on the tunnel of the driveline. Ive driven a few s2000's and I love the shifter hight and how close it is to the stearing wheel.
« Reply #125 on: August 26, 2009, 11:54:45 PM »
yeah the seating and shifter/wheel position of the s2000 is pretty much perfect.
toyolla86
« Reply #126 on: August 27, 2009, 12:11:26 PM »
nice. i like. this is way better than that other kids midengine setup.
twin50 son. get some
and stop acting like a muslim
Emperor
« Reply #127 on: August 27, 2009, 03:25:11 PM »
For Drag?
what for a waste :?:
but awesome work
RHMT Boost everything
-Cars
-Bikes
« Reply #128 on: August 27, 2009, 03:45:56 PM »
For Drag?
but awesome work
I see this car doing better in a road race than built fwd crx. I bet it will have a better dist. of weight vs the fwd setup. If he can get all of the suspention stuff setup right it will handle great.
weirtech
« Reply #129 on: August 27, 2009, 04:13:48 PM »
actually, the weight distribution should be pretty good... although a bit heavier than an oem crx, the fwd setup has the whole engine/tranny between the front wheels.  the tranny on this setup will sit behind them giving the car a much better center of gravity.  but yeah, i don't really know how the car is going to handle until i get it on the road.  the car is not being built for drag, it is being built for the street first and foremost.  i may drag it, drift it, autocross it or time attack it... they way i see it, the car will be able to do just about anything i want it to.  as long as it puts a smile on my face, i won't care.
« Reply #130 on: August 27, 2009, 05:36:33 PM »
Im sure it will put a smile on your face.  ;D
I know it would put one on mine. On another note I realy wish that the 97-01 preludes were rear wheel drive. They just look like a rear wheel drive car.
« Reply #131 on: August 27, 2009, 10:28:50 PM »
And if it doesn't he can give it to me.  :D
« Reply #132 on: August 27, 2009, 11:33:43 PM »
Awesome.. An update. Sucks about the gas/brake pedal issue. But the craftsmanship on the tunnel is top notch. How are you going to work the trans mount?
PS; Why the fuck isnt this stickied?
Whitey
« Reply #133 on: August 31, 2009, 05:17:34 PM »
Why did you go so heavy duty on the trans tunnel?  Some bent sheet metal would saved some weight and money...
« Reply #134 on: August 31, 2009, 09:32:58 PM »
if i was a dope fabricator and access to all of what aaron has, i would of done the same shit...only cause i could
Rob.K
« Reply #135 on: September 01, 2009, 07:04:49 AM »
This is what's so great about this build, this car can do pretty much anything and be very good at it. I'd expect this to thrash people in autox and even lap days on a bigger circuit. I'm sure suspension set up will take some time to get right but that's fun stuff.
ps. super jealous of your fab skills, fucken dope.
3tc, tin can, holset, trailor wheels
weirtech
« Reply #136 on: September 01, 2009, 09:32:15 AM »
because i value life.  removing that section of the original exhaust tunnel is like taking out a key structural portion of the car.  if i were to get into any kind of collision, a plain sheet metal tunnel would fold up like paper without proper reinforcement.  you have to remember, i still have to cut out the e-brake section too for the driveshaft... basically i'm cutting the belly of the car in half.  without some sort of rigid support it would make it pretty weak and prone to flexing.  eventually there will probably be a cage put in, but not right away.  also, keep in mind the tranny mount is part of the tunnel as well, so it needs to atleast hold the ass end of the drivetrain without moving excessively.
i don't think weight will be much of a factor in a car that is 2100lbs to begin with and is going to have 450whp on tap.
as for saving money, $25 worth of steel is a good investment for piece of mind.
« Reply #137 on: September 01, 2009, 09:41:30 AM »
Any proper spaceframe car has a transmission tunnel built like that.
Emperor
« Reply #138 on: September 01, 2009, 12:27:05 PM »
 ;D pussy
life is overrated!
DIE LIKE A MAN :noel:
-Cars
-Bikes
weirtech
« Reply #139 on: September 04, 2009, 03:47:12 PM »
the tranny tunnel is complete.  for now it is just tacked in place.  i want to pull the mockup drivetrain out to weld it in fully.  i'm going to have to patch up a couple spots where there are small gaps, but i don't think it is too serious.
i threw the dash and the steering wheel back in just for reference.  if i can modify the center console to fit over the tunnel, i will.
FreshDA9
« Reply #140 on: September 04, 2009, 04:14:49 PM »
Simply amazing work! cant wait to see this finished.
« Reply #141 on: September 07, 2009, 01:32:51 PM »
fucking pimp right there.  i love the fab work you do.
« Reply #142 on: September 07, 2009, 02:00:00 PM »
this should be the official RHMT car when it's done.
« Reply #143 on: September 07, 2009, 02:00:25 PM »
better yet, this is how the CRX should have come from the factory  :noel:
toyolla86
« Reply #144 on: September 09, 2009, 01:12:27 AM »
are you welding the tunnel in or are those tabs just to bolt it in.
toyolla86
« Reply #145 on: September 09, 2009, 01:13:12 AM »
ope nevermind. i see now. haha
7808
« Reply #146 on: September 09, 2009, 12:59:48 PM »
cool ass project.  crx and preludes should of came this way.  fwd sux
da9wonder
« Reply #147 on: September 10, 2009, 03:28:58 AM »
crazy project cant wait to see this finished
« Reply #148 on: September 10, 2009, 02:26:40 PM »
What are you doing for exhaust stuff?
I vote CRX2000 of Death style. S362 sticking out of the hood. O0
weirtech
« Reply #149 on: September 15, 2009, 03:35:16 PM »
not much of an update, but the tunnel is 99% welded in.  i've been doing some body work on smoothing out the engine bay.  i really dislike doing this stuff.  i'm not very good with bondo, but here is the bay all primed up.  i still need to smooth over a couple spots, then the primer sealer will go on and some paint.  i'm planning on further reinforcing the firewall once the paint is dry.
and here is an intake manifold that i'm building to go on someone else's f20c, but will probably make a second for my own.
Pages: 1 ... 3 4 [5] 6 7 ... 21   Go Up
