Pages: 1 2 [3] 4 5 ... 21   Go Down
Author Topic: my rwd crx project CRX2000!  (Read 742783 times)
Re: my rwd crx project CRX2000!
« Reply #60 on: April 04, 2009, 09:52:10 AM »
i had a pontiac 400 that had sit for god knows how long and it was seized.  we dumped a gallon of kerosene down the IM, came back a month later, put it in gear and pushed it and the fan moved.  changed the oil, started and ran like a champ
IF that engine had the ability, i would prim the oiling system by just rotating the oil pump, then install everthing except the plug wires and the fuel pump fuse and build oil pressure with the starter for a bit.  i think that woudl be the safest route.  but it doens't look like thats possible
SgtB
« Reply #61 on: April 06, 2009, 12:18:40 AM »
You can prime the pump, but it's a major PITA. You have to pull the crank pulley, chain covers, chain, etc to unchain it from the crank. It does run off of its own small chain, but it's behind the timing chain.
rsmith2786
« Reply #62 on: April 06, 2009, 12:55:09 AM »
You could just get a pump and plumb into the oil pressure switch.  It wouldn't be that difficult.
Random Hero
« Reply #63 on: April 06, 2009, 08:13:04 PM »
Or you could just stop listening to these guys and run it. If it runs like shit then rebuild/build.. I've had jdm engines come with low tests and right after running for 15-20 minutes they test out fine.
weirtech
    • Weir Technologies Inc.
« Reply #64 on: April 06, 2009, 08:30:53 PM »
that is what i'm going to do.
« Reply #65 on: April 07, 2009, 10:29:39 AM »
you could install an oil accumulator...
Random Hero
« Reply #66 on: April 07, 2009, 04:51:16 PM »
You could stop posting in this thread and it would be alot nicer.
« Reply #67 on: April 07, 2009, 05:33:33 PM »
The mystery jdm smoke. I agree I have gotten plenty of jdm motors that on start up were hardly beauties. After a couple hard runs the mystery jdm smoke goes away and they run fine. I agree just throw it in.
trevor72
  • trevwhore
« Reply #68 on: April 07, 2009, 06:52:05 PM »
right now there is no fluid in it at all.  we sprayed a bit of wd40 in the cylinders and the compression seemed to go up a bit.  i suppose it could use some oil in it.
you mean no fluid in the cylinder at all....right? of course you do....you must
fwiw, when i picked up my 92 si it had been sitting outside behind a casino for 2+ years.
- Changed oil to royal purple, pulled plugs put some oil in each cyl.
- let sit for about an hour and then put in a bit more.
- craked it loose by hand then cranked the starter till the oil light went out on the dash.
- reassembled and she fired right up smoked lots then cleaned up not long after.
not sure why your compression numbers would vary like that... how many revolutions did you do during the test?   Is there any way you can run it for a while then recheck the comp?  I realize that might be a dumb question given the photos.
Rob.K
« Reply #69 on: April 10, 2009, 04:55:13 PM »
This build is top notch, nice welding mask too... :noel:
3tc, tin can, holset, trailor wheels
« Reply #70 on: April 11, 2009, 01:31:50 AM »
updayyyte this shizz weir
Blacksi
« Reply #71 on: April 13, 2009, 11:37:48 PM »
i was under the impression that the exporters oil the cylinders when they pull/hack the engines out
« Last Edit: April 14, 2009, 10:12:09 PM by Blacksi »
Random Hero
« Reply #72 on: April 14, 2009, 06:21:21 PM »
A good importer will put oil in the cylinders, but I've only came across 2 engines that where oiled down.
TheMadScientist
  • I'm like Batman and Shit
« Reply #73 on: April 16, 2009, 09:41:59 AM »
Let's see some CRX drifting already! or at least a start up. Something anything please
« Reply #74 on: April 16, 2009, 09:56:59 AM »
I've been looking forward to seeing this get finished for a long time :noel:
Rosario4124
  • HATE HATE HATE
« Reply #75 on: April 16, 2009, 11:29:27 AM »
sweet build good to see it really comming along
the 13th round
« Reply #76 on: April 18, 2009, 08:13:36 PM »
fucking sweet to see all the progress, last time i saw this shit is was just a hacked up rex. shit is top notch as usual.
BoostForLife
« Reply #77 on: April 19, 2009, 02:25:52 AM »
This needs more progress.
weirtech
« Reply #78 on: April 19, 2009, 07:50:43 PM »
i've enlisted the help of a few good friends, so hopefully i will have some progress to report before the end of the month.
green91
  • OG
« Reply #79 on: April 19, 2009, 08:22:53 PM »
I love this build. Glad to see it move over to this site!
BoostForLife
« Reply #80 on: April 20, 2009, 03:24:50 AM »
awesome
hotrex
« Reply #81 on: May 03, 2009, 09:13:41 PM »
link to v8 crx
« Reply #82 on: May 03, 2009, 11:11:46 PM »
BoostForLife
« Reply #84 on: May 05, 2009, 01:53:08 AM »
In the last video you can see that his front end is a little too heavy.
This dude is now a dumbmestic ricer.
That thing needs a lot of boost to make up for gay paint and body kit.
« Reply #85 on: May 05, 2009, 04:33:21 PM »
looks slow, too much noise and not enough go? maybe its just me
hotrex
« Reply #86 on: May 24, 2009, 01:00:44 PM »
fuckin slow as fuck
« Reply #87 on: June 03, 2009, 02:29:45 PM »
looks liek it would have been faster with the a6 in it lol.
« Reply #88 on: June 03, 2009, 08:03:50 PM »
« Reply #89 on: June 04, 2009, 05:42:31 PM »
whats with everyone getting banned now? i see white names all over the place..
but yeah, weir, whats up, we need updates!
Pages: 1 2 [3] 4 5 ... 21   Go Up
