Author Topic: what fuckin sensor is this?  (Read 15300 times)
El Beefo
  • tongue punch my fart box
« on: February 15, 2010, 11:03:26 PM »
Found this in a box of nuts and bolts a few months ago and Im a fucking idiot and have know idea where it came from? No engine I took appart.
« Last Edit: February 15, 2010, 11:13:55 PM by El Beefo »
Re: what fuckin sensor is this?
« Reply #1 on: February 15, 2010, 11:06:50 PM »
its the LOL sensor it detects the number of LOL's  :mexi:
El Beefo
« Reply #2 on: February 15, 2010, 11:10:26 PM »
apparently... $5 shipped
« Last Edit: February 22, 2010, 07:41:50 PM by El Beefo »
« Reply #3 on: February 22, 2010, 05:02:01 PM »
Looks sort of like a knock sensor, but also a oil pressure sensor?
ifly87
« Reply #4 on: February 22, 2010, 11:48:45 PM »
I would say oil pressure but its kinda short and the plug on the back is kinda wierd.
Lol...Fags
Ravage70
« Reply #5 on: February 22, 2010, 11:53:28 PM »
looks like garbage
« Reply #6 on: February 23, 2010, 01:53:27 AM »
reverse switch.
Knock sensors are 1 wire sensors. That thing has 2 posts.
« Reply #7 on: February 23, 2010, 05:40:50 AM »
reverse switch.
Word and knock sensors are almost never in one piece. That glue to hold the plastic together is wack.
« Reply #8 on: February 23, 2010, 03:45:29 PM »
They are easily breakable, and they are $$$$$ I broke mine removing my IM
rudebwoy
  • tripple OG
« Reply #9 on: February 23, 2010, 04:22:36 PM »
thermostatic fan switch
test it by hooking up a multimeter to it while heating it in a pot on the stove until you get continuity.
« Last Edit: February 23, 2010, 04:24:50 PM by rudebwoy »
2000 civic SI daily driver
« Reply #10 on: February 23, 2010, 09:10:56 PM »
Not to mention you need a deep 27mm socket to get the fuckers off or a pair of vise grips for the trailer park style.
« Reply #11 on: February 23, 2010, 10:04:28 PM »
uh..no.
« Reply #12 on: February 23, 2010, 10:07:28 PM »
It looks like there is a hole in the end of it, so I would bet on a pressure sensor or switch of some sort.
« Reply #13 on: February 23, 2010, 10:13:37 PM »
Vtech pressure switch edm cdm jdm usdm hybrid
« Reply #14 on: February 24, 2010, 01:05:22 PM »
pressure sensor for muffler bearings or the blinker fluid
« Reply #15 on: February 25, 2010, 04:43:49 PM »
I used the vise grips, couldn't find my deep socket.... and then I bought a new one to install the new knock sensor.
El Beefo
« Reply #16 on: February 26, 2010, 12:45:30 AM »
Deff not, This has a 2 prong plug. Been a looong time since ive seen one but it kinda looks like the thermostatic switch on an old Honda Valkyrie but they have one prong.
end does have a dimple/hole like a knock sensor. I figured it was a pressure sensor also but from where?
Well Im pretty sure this isnt a honda sensor at this point so i feel better, Just wish I knew where it came from. I know now where its going, in the trash.
« Last Edit: February 26, 2010, 01:23:47 AM by El Beefo »
« Reply #17 on: February 26, 2010, 01:04:24 AM »
For sure not any honda sensor I have seen before
« Reply #18 on: February 26, 2010, 02:25:47 PM »
Thermo Switch = as above
Temp sensor = variable resistance based on temp
Pressure switch = think about it...
I think it's actually an A/C system pressure switch. I recall seeing that pin style on OBD0 Hondas/Acuras. If so, it would either be a low pressure (couple psi) or higher pressure (~45psi) activation pressure.
« Reply #19 on: February 26, 2010, 08:38:08 PM »
...I think it's actually an A/C system pressure switch. I recall seeing that pin style on OBD0 Hondas/Acuras. If so, it would either be a low pressure (couple psi) or higher pressure (~45psi) activation pressure.
Now that you mention it, that is exactly what it looks like.
