Pages: 1 2 3 [4] 5 6   Go Down
Author Topic: about to place my first order at ace stainless  (Read 144979 times)
jay
Re: about to place my first order at ace stainless
« Reply #90 on: February 23, 2010, 02:24:40 AM »
electrician coming out tomorrow to wire up the 220 line..
id do it myself but im a pussy
I want you to die
« Reply #91 on: February 23, 2010, 03:01:11 AM »
do you own a mig welder?
jay
« Reply #92 on: February 23, 2010, 03:50:02 AM »
no.. but if this works out ill prolly pick one up :noel:
I want you to die
« Reply #93 on: February 23, 2010, 04:43:59 AM »
Buk don't hotrex yourself. He is proof that even if you are a halfway decent welder things won't work out.
« Reply #94 on: February 23, 2010, 05:48:41 AM »
Mig welding is
1. Much easier to learn
2. Can do manifolds just as well
3. Fuckin faster
4. Welds not as pretty
Now they guys on here who have 5 years under their belts with a tig in their hands will disagree with me but your trying to make a buck day one. Tig welding from the little practice I have had is pretty time consuming imo.
Go buy a nice hobart mig.
« Reply #95 on: February 23, 2010, 06:56:37 AM »
I learned how to weld on a TIG first and then I used a MIG. The MIG is more useful but people pay for TIG.
Jay there is a guy on Turbo Options that bought a manifold from me. Now he did like you. Just bought a welder and got down to it. He still needs lots more practice but he has steady customers locally where he lives.
jay
« Reply #96 on: February 23, 2010, 09:02:25 AM »
imo hotrex fucked up when he took orders for manifolds that didnt exist lol
then when he rushed to make manis and half assed them it let to cracked manifolds
I want you to die
« Reply #97 on: February 23, 2010, 01:01:32 PM »
I think everyone should learn to TIG or Stick weld first. Mig is too fast, and it "looks" welded, but in fact can be cold lapped. Both TIG and stick move much slower, and you can really see when it is wetting in, it makes you a much better mig welder. Laying down a bead with a mig anyone can do, making a good weld with a mig, takes a lot of practice just like any of the other welding process's.
« Reply #98 on: February 23, 2010, 03:10:35 PM »
I learned how to braze before anything else. Then stick, then mig. I havent ever picked up a tig. :'(
« Reply #99 on: February 23, 2010, 03:16:16 PM »
Bring yourself down to PO!
« Reply #100 on: February 23, 2010, 03:29:30 PM »
I did a similar path: Braze, oxy-acetylene weld, then stick, then mig, then tig.
« Reply #101 on: February 23, 2010, 05:08:24 PM »
oxy-acetylene and coat hangers!!! FTW!!
Done that a few times in a pinch!
« Reply #102 on: February 23, 2010, 05:37:18 PM »
I have about 10 years of mig under my belt and about 3 hours of tig. I would like to buy a hobart tig this year though.
« Reply #103 on: February 23, 2010, 05:57:30 PM »
if you can oxy weld, you can tig weld, very similar.
jay
« Reply #104 on: February 23, 2010, 07:19:15 PM »
just ordered my flanges
fucking electrician didnt come this morning like he was supposed to im fucking pissed
I want you to die
« Reply #105 on: February 23, 2010, 07:42:07 PM »
Dude, he's an electrician.  What do you expect, promptness???
« Reply #106 on: February 23, 2010, 08:25:26 PM »
Dude, he's an electrician.  What do you expect, soberness???
fixed
SgtB
« Reply #107 on: February 23, 2010, 09:52:07 PM »
Dude, he's an SHITTY electrician.  What do you expect, promptness???
jay
« Reply #108 on: February 24, 2010, 10:53:34 PM »
metal shipped. still no sign of electrician.. i might wire it up myself lol
I want you to die
civiceggturbo
« Reply #109 on: February 25, 2010, 01:56:57 AM »
generator ftw O0
bigwig
« Reply #110 on: February 25, 2010, 02:16:01 AM »
jay
« Reply #111 on: February 25, 2010, 02:29:52 AM »
generator ftw O0
lmao! the first welder i Almost bought was a thermal arc tig welder generator
http://www.xomba.com/how_to_wire_a_220v_wall_outlet
It's pretty fucking easy.
yup!
i think ill give it a shot tomorrow lol
i got the lowes write up
http://web.archive.org/web/20080312064412/http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/220outlet.html
will i need a higher rated amp breaker for the welder
I want you to die
jay
« Reply #112 on: February 25, 2010, 09:36:18 AM »
ok so heres what i have laying around the house
is this wire thick enough..
its wrapped in a metal spiral conduit or whatever it is..
and a 220v plug...
« Last Edit: February 25, 2010, 09:38:10 AM by jay »
I want you to die
jay
« Reply #113 on: February 25, 2010, 09:57:26 AM »
the write up says 12 gauge minimum and im pretty sure what i have is 12 gauge wire so ill go take a look at the box now :p
I want you to die
jay
« Reply #114 on: February 25, 2010, 10:13:24 AM »
hmmm i see some prewired 220v lines back from when we had a ac unit hooked up before we got central air..
its farther then id like but i think ill just stick the plug there and have the welder itself outside the actual room im welding in.. heh well see
would it be a problem if i spliced the wires to extend it or should i just replace it with a new wire from the panel
I want you to die
« Reply #115 on: February 25, 2010, 12:00:46 PM »
Dude, your gona catch your house on fire!! Run a new line from your panel and make it 8gauge. The shorter the run the better. My panel is in my garage and my 220 outlet is right under my panel. I wouldnt run any wire smaller than 8gauge. 6 would be best.
« Reply #116 on: February 25, 2010, 02:17:45 PM »
True nig nog would cut an extension cord into 3 pieces, combine them all,  twist all the matching wires together and use that O0
« Reply #117 on: February 25, 2010, 04:14:53 PM »
A true nig nog would take 2 extention cords and run one on one outlet and another from a diff outlet and use a hot leg from each to make there 220v power supply!!
buk9tp
  • i know nuthin bout nuthin
« Reply #118 on: February 25, 2010, 04:16:43 PM »
Don't tell him to do this shit. He'll try it.
« Reply #119 on: February 25, 2010, 04:41:25 PM »
Fuck it, just have another electrician do it.
Pages: 1 2 3 [4] 5 6   Go Up
